Question about Pioneer Car Audio & Video
How do i connect a pioneer car equalizer model bp-540? it has several wires on the back and i boutgt it used and just curious if some1 can help me get this hooked up, would be greatly appreciated. thank you.
5 Suggested Answers
rteemon
  • 578 Answers
SOURCE: how do I wire an car stereo to an equalizer
from what you have explain you have a no experience to do so get your system installed by an audio installer safety come first and u have no clue for your safety seek a qualified person to do it
Posted on Jul 07, 2009
rteemon
  • 578 Answers
SOURCE: wiring ID- Pyramid SE808ECHO 200watt amplifier/grapic equalizer
THE UNIT YOU ARE USE HAVE SPEAKER IN AND OUT WIRES LOOK AT THE INSTRUCTION AT THE BACK OF THE EQ AND DECIDE HOW YOU WANNA USE THE EQ
Posted on Aug 07, 2009
SOURCE: power supply connection for pioneer eq-6500
top left - orange.....goes to aux or memory wire
top right - blue.......goes to the remote wire used with amps
bottom left - black.......goes to the ground wire
bottom right - red........this goes to your hot wire
Posted on Aug 13, 2009
HitWizard
  • 67 Answers
SOURCE: Hi! Looking for a manual on hooking up the speaker
Hey there ninja. I was not able to find a manual in English(Spanish only!!!), but I did find this site with a few PDFs that may help you out. It has the Features, Installation, Operation, Specifications, and Wire Connections, so it should help you out.
Posted on Sep 25, 2009
How do you connect a home pioneer graphic equalizer sg-9 to a sansaui r-7 receiver?
Use the tape monitor loop. Connect from the TAPE REC output on the receiver to the INPUT on the equalizer and from the OUTPUT on the equalizer to the PLAYBACK input on the receiver. YOU can then switch the equalizer in and out using the TAPE MON switch. I think the Model Seven had two tape loops, so just keep everything on the same loop.
Aug 03, 2014 | Audio Players & Recorders
I need data sheet or user manual for my pioneer graphic equaliser
If is a parametric equalizer is zero watts. ,pionner should have a front, rear and subwoofer connections. If i remenber correctly, a single rca going to your stereo and the rest from eq to amp or amps. Hope this helps ,hope you get WIRED.
May 15, 2013 | Pioneer EQ-6500 9-Band Car Equalizer
Using graphic equalizer on a Pioneer CD player
try to connect it in tape in-and confirm that you select the right input in the receiver(in our situation you will select tape as input source).
Sep 14, 2009 | Audio Players & Recorders
I'm searching for a visual diagram to show the power hook up on the Pioneer DEQ 7600. I need a description of each wire and how to connect.
go to crutchfield.com and type in your model.on the right side of the screen it lists whats in the box.from there you can print a diagram.
Sep 06, 2009 | Pioneer DEQ-7600 15-Band Car Equalizer
DEQ 9200 does nothing but blink
check your remote and ground source make sure remote power have enough ampirage for signal source that can cause it to blink
Jun 28, 2009 | Pioneer DEQ-9200 3-Band Car Equalizer
Power supply connection for pioneer eq-6500
May 31, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
I have a Pioneer SG-540 stereo Graphic Equalizer that only works in the right channel, but more importantly puts out a large amount of excess humming moise and other unwanted sounds when the controls are...
I use the sg 540 equalizer for cd and tuner. (I have two of them) I also use the sa 940 to power my sound. On the tuner input of the amp, i used standerd rca cables and connected it to the output of the equalizer. then i connected rca cables from the input of the equalizer to the output of the tuner. this only works when the top equalizer button is pushed on. hope it works for you.
Jul 18, 2008 | Audio Players & Recorders
How do I install my pioneer stereo?
this way should work : connect the OUTPUT of stereo ( ke-4535) to the INPUTS of GRAPHIC EQUALIZER ,then the speaker outputs of the GRAPHIC EQUALIZER to speakers , in this order you have control to adjust the sound coming from the PIONEER stereo . hope this helps
Apr 25, 2008 | Car Audio & Video
Help
Hi Bdowell,
I usually get my wires to fit the pioneer from Ebay. Several sellers actually offer the connecting wire harness and connector for Pioneers. A lot of the Pioneer models use the exact same wire harness and connector. use a little ingenuity and y search on ebay, you will probably find one.
Nov 08, 2007 | Pioneer DEH-27MP CD Receiver w/ MP3/WMA...
Car Audio & Video Logo
175 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
