Question about Kenmore Dishwashers
We have a 7 month old Kenmore Elite dishwasher model #66513123K703. Was working fine this am .After using the rinse cycle which was ok the machine is now not operating .The normal wash cycle light keeps blinking sporadically.It will be on for a few minutes ,then stop only to go back on again.we have tried the cancel cycle which will attempt to drain the machine. It is unable to move to another type of wash cycle .This cancel cycle will operate for 2 minutes or so and then stop.We had shut the power off by the breaker for 5 minutes in hopes that it would reset itself , but that was not usefull. I am not happy .Thank you Bonnie
    Habit-Forming:
    New Friend:
  • 25 Answers
Had a similar problem on a year old kenmore elite and had to replace the control panel. yours should still be under warranty
EAP11748201.
Posted on Apr 07, 2017
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
  • 1214 Answers
I suspect for either of these units that the timer control boards are bad.
Posted on Jan 24, 2009
  • 172 Answers
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Posted on Feb 22, 2009
  • 15 Answers
SOURCE: Panel not working on Electrolux Dishwasher
CONTACT ELECTROLUX. YOU EITHER HAVE A FAULTY TOUCH PAD OR A BAD RIBBON CONNECTION.
Posted on Apr 07, 2009
arikrom
  • 528 Answers
SOURCE: I have a Kenmore Elite Dishwasher, Model #
replace this:
Bi-metal Number:661663 20-30$ at sears parts direct
i had the same problem and this part is in the door part on the controll panel you can take it apart with the 6 screws i think on the door...
good luck let me know...
Posted on Jan 22, 2010
A kenmore elite washer won't spin on rinse cycles. Does fine on first wash cycle, fills up for first rinse and then won't spin after that either on first or second rinse.
There are two plastic gears on each end of the motor inside the washer. One of them broke. These gears make the tub spin. They are inexpensive. it is rare that both gears broke but have both of them replaced. Then you don't have to worry about the second gear breaking in a few months.
Dec 31, 2014 | Kenmore Washing Machines
I have a Kenmore Elite Dishwasher, Model # 665.13119K701 that is just over a year old. It does not cycle through the washing/rinsing/heated dry cycles. It continually runs in the ''washing'' mode. It only...
replace this:
Jan 21, 2010 | Kenmore Dishwashers
Kenmore 300 washing machine does not leave rinse cycle
This sounds like a bad timer. If the machine is several years old, the timer could be in need of replacement.
If you are handy, you can replace this device yourself and you should be able to obtain the part from any local Sears parts store or from the internet.
If you are not familiar with this kind of work, it would be best to have a technician replace the timer.
Jan 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite dishwasher 655.16463300 not cleaning dishes
The inlet screen is at the bottom of the unit. Clean it out and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 08, 2009 | Kenmore 24 in. 16463 Built-in Dishwasher
Problem with Kenmore Elite 45986 Front Load Washer
machine stops before rinse and spinig. and then H and F flasing
Feb 18, 2009 | Kenmore Elite 45986 Front Load Washer
Rinsing detergent from dispenser
Use gel run a few cycles and help clear and then don't overfill w gel soap
Nov 13, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
71 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
