Question about Poulan Garden
Weed Eater edger PE550: What is the size of the retainer nut that holds on the blade? I know it have to turn it to the right to loosen it, is this a special nut? I have stripped the original nut.
slohry
  • 87 Answers
SOURCE: how to change an old edger blade
Take a pair of vise grips and clamp the blade to a 2X4 for more leverage. Some old edgers had a left hand thread.
Posted on Apr 09, 2009
  • 10865 Answers
SOURCE: can't remove the nut holding blade on. Which way do I remove
Get some WD-40 and spray the area around the nut then let it sit for a few hours. This will get into the threads and loosen any rust that is compounding your problem. Now get a good wrench and look directly at the nut. Left is loose and Right is tight.
Posted on May 21, 2009
moretons
  • 155 Answers
SOURCE: can't get the nut off.. is there a secret to blade removal
Hi these are usually the opposite way to which the blade turns but you may have to use a rattle gun to remove this. If you have a look at the thread you should be able to determine which way it comes off. Just remember to fix the blade so it wont turn and take your fingers off.
Posted on Aug 04, 2009
  • 59 Answers
SOURCE: weed eater PE550 runs only on full throttle and
Your carberator is messed up. Buy a new carb for the unit.
Posted on Sep 23, 2010
rycgl
  • 1545 Answers
SOURCE: why does my primer bulb when pushed stay push in
You may have a clogged in tank fuel filter, lines in the tank broken off of the fuel filter and line fragments clogging the fuel lines. . Fuel lines get flaky when they deteriorate. Your primer bulb may be leaking also. The check valves in the carburetor control the flow of fuel in and out of the primer bulb. The carb may need cleaning. In other words, a complete fuel system assembly inspection will be needed. If the bulb is on the carb, the check valves in the base assembly below it may be sticking. Remove bulb and spray in there with WD-40 to free frozen or sticking check valves. The valves are very small and malfunction occasionally
Start your inspection at the fuel tank and work your way to the carb. Pull the cover off the carb on the end opposite the end with the vent hole in the cover. You will be pulling off the fuel pump cover. Inside the carb body you will find a very small round fine mesh screen. Clean it well with carb cleaner and when you reassemble, spray some WD-40 in that area too.
Posted on Nov 11, 2010
To change the blade which way does the nut turn to get it off? Clock wise or counter clock wise?
Most weed eaters are opposite to conventional thread. So they are CLOCKWISE to take off
Apr 30, 2016 | Weed Eater PE550 8-1/2-Inch 22cc 2-Cycle...
Excessive Vibration in Echo PAS-230 edger accessory
Sounds like the Edger blade is unbalanced/off centre/unevenly worn or loose.
Jul 27, 2013 | Echo Garden
How do I change the blade
The blade bolt is normally 9/16, you will need a good socket and long tommy bar to remove the bolt, an impact wrench will take it out very quickly if you have or can borrow one,
Jun 16, 2012 | Poulan WEED EATER PE550 711431 22CC 2 Cyc...
I have a poulan weed eater edger. It will start and run but when I move the choke it stalls. I want to clean the air filter but I don't know where it is.
I am not familar with all models of all things but you will find the air filter in the close area of the carburator intake. The filter cleans the cumbustion air prior to entering the carb. Good luck...Lee
May 28, 2010 | Poulan Pe550 Gas Edger
Weed Eater PE550 - How do you change the spring that operates the cord pull. Cord not rewinding. Spring broken
Lay the unit on it's side, carborater down. Removed the 3 screws holding hold the gear assembly housing. Hold the clutch assembly inside a cloth with a wrench and remove the nut. Left from the starter cup as a stack and set aside. There is a starter retaining ring on the shaft. Pull this with a long nose plyers. If it spings free, it is easy to loose. Then left out the starter pully. The starter spring is under the pully. Remove it with a sharp pointed tool. A broken one is crusted in rust and will be snapped off inside the coil.
Jul 31, 2009 | Poulan Garden
Weed eater starts, runs 5 min. then cuts off
The gas cap may be clogged.
The next time you run the trimmer and it starts to die, loosen the gas cap. If it starts running again, then you know that it's a clogged gas cap.
You may also check the air breather, it may be dirty as well.
Just let me know if you need further assistance.
Jim
Jun 28, 2009 | Poulan Pe550 Gas Edger
Where can I find a manual for the PE550 weed eater
You can download one online at... http://www.poulanpro.com/poulanpro/indexAction.do?id=default Scroll down the right side to 'Download Manuals'...then enter your model #.. you can then download the owners manual or parts manual. Dwain
May 21, 2009 | Poulan Garden
Screw cap to reel head of ryobi ss30 weed eater will not come off
The spool retainer nut loosens when you turn it clockwise . The opposite of " normal ".
Apr 05, 2009 | Garden
Garden Logo
117 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
