Question about Garden
Hi, My glidermatic gts keeps going open once it reaches the bottom, everything works; it?s just it keeps going open. I have to close open, close open until it stops in the close positions. Thanks, Werner
The Glidermatic GTS 2000 has limits that are stored electronically.
The problem you have is the closing limit is set too low and needs to be adjusted so the door is just resting on the concrete - currently it is trying to drive through the concrete, the motor detects and obstruction and reverses.
If your Glidermatic GTS 2000 was supplied & fitted prior to April 2010 you can download the 'Limit Setting' procedure on the Gliderol website. If the unit was installed after April 2010 it MAY have a revised PCB known as the NGTSv2 PCB. Contact your local branch for limit setting procedures as they are not yet available to download online.
The combination of a mechanical door and electric motor means periodical adjustment is required to esnsure the travel limits and - most importantly - the sensitivity is set correctly. A service to your DOOR is strongly recommended every 12 months.
I hope this helps
Posted on Mar 08, 2011
How are you supposed to heat up the green egg
There are you tube videos. I temporarily take daisy vent cap off top of egg, open bottom vent door wide open, light lump coal 2-3 spots with a loof lighter (from ace hardware) and then close lid. I have one section of galvanized dryer vent from Lowes that I stick on top which accelerates preheating of egg. Once the temp gets to 500, I remove the section of vent by grabbing it with a glove or hotpad. Wait a minute or two for smoke to die down. Place daisy back on top and close bottom vent door down to 1/2" and close daisy 1/2 on top and this should drop temp to 175-250. Use fine adjustments 1/6-1/8" until desired temp is reached. Your food can go on at any time after removing dryer vent. Just burp lid by slightly lifting to allow any heat burst to escape. I also have a gas conversion that works awesome. I just add a small smoke ox over burner that provides enough smoke on front end of cooking process. Advice- keep the butts and ribs on for 6 hours.
May 01, 2014 | Big Green Egg Extra Large - XLHD...
Vespa gts300 gas tank removal
- the easiest way is to unmount the rear shock absorber (1 screw at the bottom) and rise the Vespa to reach the spark plug....
this is far better than to reach it from above....
dee2bc6d-8882-4228-827d-32557b1fd622.jpg e2891d67-3a19-4cc3-b8ca-3b5d4267fd29.jpg
Feb 16, 2014 | 2011 Vespa GTS 300
Can't open anything on the phone keeps saying maximum limit of applications reached
Hello There! Go to the task manager and close all opened applications. If you can't find it, try restarting your phone & that should do it.
Then, once everything is closed you could be able to open any application you need. Try not to open to many application you don't use at once.
I hope that I have helped you & that this is post helpful to you at most! Don't Forget To Rate! :)
Jan 14, 2011 | LG GD510 Cell Phone
Security system went off after replacing battery now car wont start nor fuel pump will turn on.how do i fix
You might just need to reset it. Roll the drivers window down and close all the doors. Lock all the doors with the key ) turn the key to lock twice, The electric locks should lock all the doors. wail a few minutes and unlock and open the trunk with the key. relock the truck or just close it. unlock the drivers door with the key, twice. all the doors should unlock, get in and start the car. Now this does'nt always work. If it does'nt we'll make the system think it's running. Close and lock all the doors. open the hood and disconnect the battery, one ccable will be fine. wait a few minutes. Reach in though the open window and turn the key all the way on. Don't open the doors, go around and connect the battery hard so it does'nt jump or skip. Reach thought the window and start the car/ once it's running. turn it off remove the key and unlock the door from the inside and open the door ( as if you were inside.) get in and start the car and everything should be back to normal.
Nov 26, 2010 | 1997 Infiniti.5 J30
The work of the thermostat
it has to ways of water circulation. 1 remains off as the thermostat is closed which is the main outlet to the radiator and the 2nd way is for the heater matrix. so as long as the thermostat is closed the water will keep circulating within the engine only. once 82c degrees reached then it'll open and have the water go to the radiator and back to the engine...
Jun 24, 2010 | 2002 Land Rover Freelander
I need to change the cooling liquid to my cars radiator
First, on a COLD engine, locate the drain on the bottom front or rear of one of the end tanks on the radiator. If you can't find it, remove the lower hose from the engine at the radiator (does the same thing only faster). Catch the coolant in a pan. Put the old stuff in a closed container where pets and kids can't get to it.
Re-connect the hose, re-fill the radiator with water and run the engine for a minute or two, then drain again. Then, connect the hose (or close the drain) and add new coolant. Run the engine while filling and keep the heater on high heat. When the engine reaches operating temp, turn it off, wait about three to five minutes and re-start and continue filling.
Close the system and let it cool down, check everything over for leaks and then add enough coolant to reach the full hot mark on the reservoir. Re-check level after your first trip anywhere to make sure the level remains correct. You can actually use "normal" coolant instead of "lifetime" coolant, providing you change it every two years without fail. Once the fill cap has been closed, do not open it again unless the engine has cooled down...the system is under pressure.
Jun 10, 2010 | 1997 Pontiac Trans Sport
My daughters facebook keeps appearing
Hi
Sign out from your daughters facebook, then login to yours.
if your daughters facebook details keep appearing or it sings in on its own constantly, then you should empty the cache of the browser, to do that, really the easiest way is to download CCLEANER and run it to clean up
http://www.filehippo.com/download_ccleaner/
the download link is on the right "download latest version"
install the program and then run it. when the program opens up, all you need to do is to close your internet browser programs, close this page and everything else. now on the window of the ccleaner, you have a button on the bottom right corner "Run Cleaner" click on it and it will clean up temporary files and other useless content from your computer that builds up over time.
once its done, try opening facebook again, it shouldn't login on its own anymore, if it still does, then most likely you didn't close the program, restart your computer, run ccleaner again and try again.
Jan 01, 2010 | Facebook Social Network
I am the user of LG Renoir kc910 8GB handphone. I
hi, this probably just means that you have too many applications open at once. If you press the middle 'hard' button, then press the triangle arrow tab at the top of the screen you should be able to see everything you have open and close everything at once. then your video shoudl work.
Feb 23, 2009 | LG KC910 Renoir Cell Phone
Battery replacement
not sure about US spec cars but in uk your radio is coded and you will need to put code in to radio once power is disconected.also you will need to do basic settings on electric windows if you have them??.lower the window all the way ,when it reaches the bottom keep button pressed until you hear motor click.repeat process with window closing .your widows wont auto open and close without doing this.
Feb 12, 2009 | 2004 Volkswagen Beetle
Garden Logo
2,065 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
