Question about Lincoln Electric Century Portable Plasma Cutter - 25 Amp # 82021
My weld pak 100 will not feed the wire - Lincoln Electric Century Portable Plasma Cutter - 25 Amp # 82021
You Ned to check if the voltage selector is in good condition if not replaced.
Posted on Feb 08, 2011
I have no gasflow it sounds as if the gas is leaking at the feed rolls
there is no seal at the feed rollers around the wire as it requires the correct gauge wire and feed hole to slow down the loss of gas at that point ( easier for the gas to escape up the wire housing and out the welding end )
the gas is allowed to flow when the welding trigger is operated as that opens a gas solenoid that allows gas to the welding wire tube to exit past the shroud around the welding point
read you user manual well to be acquainted with the machines operation, and if there is a persisting problem talk with your supplier and consider a warranty service check
Sep 15, 2016 | Lincoln Electric Weld Pak 140 HD Wire Feed...
Lincoln weld pak 100, no heat penatration on the D setting
I believe your voltage control rheostat (potentiometer) must be worn out. Check your owner's manual for the part number and request it, it's not expensive and it is an easy part to replace. If you are doing that would be a good idea to do the same for your speed control rheostat.
Or clean them if you can, take off all the carbon particles that it build up with the time.
Mar 20, 2014 | Welding Tools
Weld-pak 100 Hd Problem
There is a reset button located in the wire feed spool compartment,
check to see it stays in when pushed. It is a safety when the machine
overheats, it normally resets when machine cools off. If it is working properly I suggest contacting Lincoln Electric Dealer for service.
Mar 03, 2012 | Lincoln Welding Tools
Where can I get a gas diffuser for a Lincoln Electric Weld Pak HD wire feed welder?
Gas diffusers are sold at any welding store, look up praxair site for your nearest location. The part number you are looking for is: TWE-35-50 about 6.00 bucks or less.
Jun 13, 2011 | Lincoln Electric Welding Tools
What gauge exstention cord do i use for a lincoln weld pak 100?
Hi:
Weld pak 100 is a 120 volt unit, you will be ok with a gage 12.
Most 120V commercial extensions out there are 14 gage, if you want to buy one, choose no longer than 25 ft long.
With a 12 gage you can go to 50 ft. with no problems.
If this was useful to you please vote. Thanks.
Mar 27, 2011 | Welding Tools
What is the proper range to weld 1/8' stainless steel using Weld-Pak 100 machine and 308 FC-0.035" wire.
Depends - what position?
Try between 160 and 175 amps, and 225 - 250 ipm.
DCEP
21 - 22 volts.
May 11, 2010 | Welding Tools
I have a Lincoln Weld Pak 100 that was working fine. I shut down the machine though and when I came back to it about 5 hours later the wire feed motor wouldn't turn anymore. Has anybody else had the same...
Check the voltage at the wire feed motor when the trigger is pulled.
I had a Weld Pak 100 that with 0 volts at the wire feed motor, and the problem wound up being that 2 of the big power (stud) diodes were shorted.
Feb 26, 2010 | Welding Tools
Lincoln weld pak 100. The wire jams in the hose. it is feeding pro... the wire jams in the hose. it is feeding properly but the wire gets hung up a foot or 2 before the nozzle. More the wire jams in the...
In your other post I had mentioned installing a Teflon liner that would help with the wire.It narrows the gap in the hose and gives it a more easier feed.
Jan 10, 2010 | Saws
Lincoln Weld Pak 100 arc welder troubleshooting
There can be a switch that makes the wire electrically "dead" so it can be fed through the liner. Also suitcase style welders have a sensor wire with a clamp that must be connected for the arc to be able to be struck.
Nov 22, 2009 | Welding Tools
Lincoln Electric  Century Portable Plasma Cutter - 25 Amp # 82021 Logo
317 people viewed this question
Top Lincoln Electric Welding Tools Experts
oleolson
Level 1 Expert
Daryl Gleaton
Troy
Troy
Level 1 Expert
Are you a Lincoln Electric Welding Tool Expert? Answer questions, earn points and help others
