Question about Canon PIXMA iP90 Mobile Printer
The waste ink absorber is full. I removed the sponge, rinsed and dried it and put it back in printer and reset the ink counter. I cant get the printer light to change off orange. Unable to finish the second step to resetting the counter.
    Sergeant:
  • 194 Answers
Waste Ink Counter Reset.
(1) Turn off the printer.
(2) Press and hold the RESUME button, then press and hold the POWER button.
(3) Release the RESUME button, Next press and release the RESUME button two(2) more times in
succession. Note: you are still holding the POWER button). The printer's carriage will "reset"
or move momentarily. If the above was properly performed the printer will enter the
"Service Mode".
(4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp
will alternate (change) color with each key press.
1. Service/Factory test printout, including ink sensor check.
2. EEPROM - Info printout.
3. EEPROM - Initialization.
4. Reset the Waste ink counter.
5. Printer model setting.
(More selections beyond this point) - However it is best to leave them unaltered - You have been warned!
After selecting the desired mode (eg 4), press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
Posted on Jan 03, 2011
How do I empty the ink absorber on a Canon Pixma MP 800
This message means that the Waste Ink Absorber (Where all the ink that is used during Printhead Cleaning goes) is nearly full.
This will require the ink counter to be reset and the Waste Ink Station to be cleaned out. Resetting the counter and not cleaning it out will cause it to eventually overflow creating an enormous mess and damaging property.
If you are unfamilure with dissasembly and reassembly of printers I advise you to take it to someone that has experience with this process.
The Waste Ink Station is effectively a large sponge sitting under the chassis of the printer once you have disassembled the machine enough to get this sponge material out and cleaned it out and put it back in (Or replaced it entirely) then follow these instructions to reset the waste ink counter:
1] Turn off; hold Resume (red triangle in a circle)
2] Press and hold the Power button
3] Release Resume while still holding Power
4] Press Resume twice then release Power,
5] Printer will start in Canon Mode, wait till 'Idle' is displayed
6] Press Resume 4 times
7] Press Power to confirm
8] Press Power to turn off
Once restarted the machine will function as normal.
I stress again. If you do not clean out the waste ink station it WILL overflow and cause damage. Do this at your own risk.
Oct 09, 2014 | Canon PIXMA Office Equipment & Supplies
Where do I Find the ink absorber bottle
Inkjets do not have a bottle for the waste ink. Instead there are two sets of rubber pads that act like sponges. One set of sponges is directly below where the ink cartridges "rest" when the unit is not in use. They absorb the ink from the print head cleaning routine. The other set is at the bottom of the printer. You basically have to disassemble the printer from the top to reach the pads. The pads are in little plastic trays that hold some of the excess ink. If you remove the pads, blot the bulk of the ink off the pads and the trays on some paper towels.
The pads can be replaced or cleaned by rinsing under running water until the water runs clear. Let the pads dry before replacing them. Then you would need to reset the counter for the ink absorber. This involves entering the maintenance mode and depends on the printer model. The most common steps are: with the printer off, press and hold the Resume/Cancel button. Then press the Power on button. Hold the Power button and release the Resume/Cancel button. Press the Resume/Cancel button twice and then release all of the buttons. When you see a green light, press Resume/Cancel 4 times. Turn the printer off and then back on.
However, the components of most inkjet printers are near their expected failure point when the number of pages printed reaches the value that triggers the "ink absorber full" message. If your printer is under warranty and gets this message, contact Canon.
I hope this helps.
(resetting the ink absorber full counter without cleaning or replacing the pads will eventually lead to ink spilling out of the printer.)
Oct 21, 2012 | Canon PIXMA MP180 All-In-One InkJet...
E8 Waste ink absorber full, or platen waste ink absorber full WHAT MUST DO?
I am told that this will reset your counter and eliminate the full absorber warning that you are getting.
Cleaning the pads is messy, sending the printer to Canon is expensive,
I used a simular reset code for my MP470 and haven't had any problems.
1. To clean physical pads:
Open cover (as if replacing ink cartridge).
Locate waste ink pads, they are far right under cartridge slider.
Pry up waste ink pads (inky, might want to wear gloves).
Rinse pads in sink or with alcohol, dry.
Replace pads. Make sure pads are fully seated.
2. To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
Jan 14, 2011 | Canon PIXMA MP190 All-In-One InkJet...
Waste ink absorber is full - replace What is procedure to replace?
The first thing to do is remove the plastic covers on your printer, usually 2 to 6 screws. When you take some-thing like this apart it is always best to use some sort of screw divider, so as not to get them mixed up or get them lost.
The ink tanks are normally located on the rear of the printer, behind the ink head. The waste ink tank consists of 4 or 5 sponges. I suggest at this stage to put on a pair of those disposable gloves and wear old clothes. There will be ink every where.
Place the ink pads on some old news paper for now, then using tissue paper clean out the plastic hovel from which they came. Now rinse out the sponges under running water, squeeze them out, to get out all the ink. Dry them off in the sun for the day.
Reinstall them and put the printer back together.
Now click here to download the counter reset software.
Click here for more information.
Turn on your printer and install the software, run the software and reset waste ink counter.
Presto your printer is working again.
Happy printing
damnor01
Nov 15, 2010 | Canon PIXMA MP150 All-In-One InkJet...
The waste ink absorber is almost full what do I do? I can't find my manual.
The absorber is like an ink blotter... Disassemble the unit take it out and rinse, rinse, rinse till it is a very light grey and dry thoroughly and re-assemble. It may take an hour to adequately rinse the ink out, but finding a new ink absorber can be a nightmare. Find maintenance software for the printer to reset the ink counter in the printer.
Nov 05, 2010 | Office Equipment & Supplies
MP 610 is leaving black ink streaks the length of the page on back of paper. I have used the printer maintenance to clean the rollers, ink head etc several times and have installed a new black ink...
That sounds like the ink is coming off the waste ink absorbers. Try blotting the excess ink off the bottom of the printer with paper towels. The ink absorbers are small pads at the bottom of the paper feed path. With work, you can pull them pads and rinse them clean and then reinstall them when dry. Unfortunately, this can take almost disassembling the printer. Simply absorbing some of the excess is a temporary step.
I hope this helps.
(there is a counter that indicates when (based on average use) the waste ink absorber is full. The printer will stop working when that number is reached. Unfortunately, I haven't seen a reset for this model that actually works.)
May 17, 2010 | Canon MP610 Photo All-In-One Printer
Waste ink absorber is full and need to be replace unable to print
The waste ink absorber is a pair of pads at the bottom of the printer paper path (one on each side). You can order replacement pads from a service center. Alternatively, you can resuse them. First, you need to pull the old pads (have plenty of paper towels handy). This can take nearly disassembling the printer. Then rinse the pads with running water until they are clean and then let them dry, if you want to reuse them. Once dry, reinsert them and reassemble the printer.
Next you need to reset the counter for the waste ink absorber. With the printer plugged in but off. Press and hold the Stop/Reset button then press the power button. Once the Power light is lit, press the Stop/Reset button twice while holding the Power button. Release the buttons in any order and the printer is in a service mode. With the lights Green, press and release the Stop/Reset button four times (the light will go orange and green alternately and will be green at this command). Set the counter to zero. Press the Power button to save the setting. Then turn on the printer normally.
Do not reset the counter until the waste ink absorber is cleaned/replaced, you will get ink everywhere.
Please note that the printer was designed to fail about the same time that the waste ink absorber counter hits the point that locks the unit. (ie the waste absorber doesn't get full while the unit is under warranty), the printer may have additional failures soon.
I hope this helps.
May 08, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Spillbläck full? What to do
It means that the pad that absorbs the ink when the heads are cleaned is full and if you use it more it will spill the ink over your desk. The official way to deal with that is to take the printer to a dealer and they will clean the absorbing pad and reset the warning.
You can do both yourself:
1 - to clean the ink pad: remove the cartridges and unplug the combo - the carousel should remain in the middle, leaving the pad in the right side visible; take the printer to your sink and pour water over it thru a pipe (try not to splash it everywhere) until the pad becomes white and the water that flows out colourless; allow it to dry thoroughly (at least 2 days in a hot environment).
2 - Reset the Waste Ink Volume Counter
1) Press Menu + Copy + # to enter SERVICE MODE.
2) Select TEST MODE.
3) Select 8 - PRINTER TEST in TEST MODE.
4) Select 3 - EEPROM CLEAR.
5) Select 0 - INK COUNT.
6) Press the OK key.
7) Press the Stop/Reset key (returning to the state of 3) and then press the ON/OFF key.
May 01, 2010 | Canon SmartBase MP360 All-In-One InkJet...
Waste full
The waste ink absorber is a piece of sponge that (as its name implies) absorbs waste ink. On many Canon printers it an be removed if you are fairly dextrous. Wash it out and dry it and then refit. It may well be a fiddle but it will go back in.
The difficult bit is resetting the printer so that it knows the absorber is empty.
Do a google on resetting the waste ink warning for your particular printer (it's not the same for every Canon). It's done with various combinations of button pressing and light sequences and generally works first time (though one of mine took 4 or 5 goes before it actually reset).
Jul 26, 2009 | Canon Office Equipment & Supplies
Canon ip 1000 waste ink reset
want the software tool to reset the waste ink level for canon inkjet printers
Apr 20, 2006 | HP LaserJet 1020 Printer
Canon PIXMA iP90 Mobile Printer Logo
47 people viewed this question
old marine
old marine
