Question about Husqvarna 350 18 Inch Gas Chainsaw 52CC Fully Assembled Brand New 18"
Bar oilier not working - Husqvarna 350 18 Inch Gas Chainsaw 52CC Fully Assembled Brand New 18"
    Brigadier General:
  • 4,088 Answers
This saw should be returned for warranty repair or replacement. Good luck!
Posted on Jan 03, 2011
Can you adjust the chain oilier on a Jonsored 2050 turbo chain saw.It runs the oil tank empty before the gas every time
The oil pump on this saw is not adjustable, make sure you are using a quality chain oil and not thinner motor oils.
Feb 20, 2017 | Garden
Instruction on how to start a stihl chainsaw model 014 AV
this is a picture of a 014
looks basic..older model .. no safety features
starting all depends on
carby idle hi /low set correctly
air filter clean
clean fuel....fuel /oil mix
good spark
new spark plug if required
chain oil in oilier section
correct chain tension on the cutting bar
being a two stroke
and the engine has good compression
crank casing seals are in good condition
never have your body in line with the chain
it could run off the bar at startup ..flick .onto your arm or face
choke on
trigger lock on
hold the handle and pull cord handle ..firmly
let the weight of the chainsaw start itself
let the chainsaw go downwards till motor splutters
choke off
trigger lock on
drop the chainsaw downwards a few more times
and it should start
other way is put foot in the foot plate of the handle
and start sequence is the same
if not something is out of adjustment or needs servicing
Oct 14, 2016 | Stihl Garden
Oil is not getting to the chain with a stihl 012av chainsaw.
I'm almost sure you have to remove the oil tank and then the oiler
Nov 26, 2014 | Stihl Garden
How does the oilier work?
The oiler is driven by the clutch,so when the chain moves it then starts to oil
Sep 23, 2014 | Homelite Xel Electric 8 10 12 Chainsaw...
How do you put a new chain on A 3516
The first thing you need to do is clean up the saw with air,be careful around the bar oilier because they get plugged up if your not careful.
Look for two studs on the right side of the saw, there should be nuts holding the bar down.They may be under a cover.Loosen them up but don't take them off.Look for an adjustment screw on the back of the bar and back it off about 1/2 an inch.Those bar nuts should be just loose enough so the bar can be slid back 1/2 an inch.Look at the chain on the bottom of the bar the sharp part of the teeth should be pointed back at the motor.Take the old chain off with gloves.The saw should be on its side with a block holding the tip of the bar up level.Put the new chain on the drive sprocket first then have someone hold the saw while you put the chain around the nose of the bar.There is a groove in the bar that guides the chain as it moves around the bar.At this point turn the saw upright and grab the nose and pull until the chain slips into place and tighten the adjusting screw while moving the bar up and down so it will be straight when you get ready to tighten the bar.The chain should have 1/8 of slack in the chain when pulled away from the bar.Pull the chain by hand with a stick(the way it moves when you cut) to see if it binds any where on the saw or bar. You can do the whole operation with the saw in an upright position if you want.I hope this is clear enough for you.Thank You for choosing FixYa.com.
May 15, 2011 | Garden
BAR OILER NOT WORKING GEARS OK .WILL THE TANK PLUG UP . HUSKY 340
Hello slehman629,
Take off the chain and bar and you can clean out the oilier tube with a piece of wire or a dull drill bit a small screw might work.It is just saw dust that gets packed in there. Thank you for using fix ya.
May 11, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
What oil do I use in my mccullough em250 chain saw?
I use just standard 30 weight in the chain oilier, u can also use Marvel Mystery oil available from any auto parts store, it penetrates the chain better
Dec 03, 2010 | Garden
When I top up the chain oil it runs out of the opposite side really rapidly, I don't see how to fill it in the instruction booklet
Are you using bar oil? Is it less than 2 years old (warranted)? Did the chain come off and hit the tank?
I think your saw may have been impacted and the oil tank is broken. I didn't see an oil vent on the IPL but if the filler is on the bottom of the saw and you must lay it on its side to fill there must be one. Take it and your bar oil with you and stop by your friendly neighborhood Husky dealer. Ask what they think the problem might be. You might be pleasantly surprised. Purchase some 2 cycle oil, a new chain, some bar oil, something. When time for a new saw remember how they treated you.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Oct 15, 2009 | Husqvarna Forest & Garden No.967012396 345...
Can't pinpoint bar oil adjustment on 08 445 husqvarna
There is no externally adjustable oiler on a 445. From your manual:
"If the chain lubrication system is still not working after
carrying out the above checks and associated measures
you should contact your servicing dealer."
HusqvarnaUSA.com
06 1500198
Oct 14, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
My husqavara saw wont oil tthe chain .. what should i do
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Oct 12, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 350 18 Inch Gas Chainsaw 52CC Fully Assembled Brand New 18" Logo
44 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
