Question about Tally Office Equipment & Supplies
Printing Problems Jobsheets are illegible, printing is also showing in italics which isn't the case when jobsheets are printed on plain paper. Need to know how to sort out the problem as we cannot use these jobsheets. Can you help at all ?
Printing no colum
Posted on Jul 15, 2008
I have an e-all-in-one printer. Can I turn this OFF without causing problems with normal printing?
a plain paper setting will print in plain paper normal
go to printer settings and set to normal print
type in --www.hp.com/ctg/manual/c037789822.pdf --for a pdf version manual down load
or go google and type in- can e-all-in -one printers be set to print normally and there are sites that show up including the one I mentioned
Oct 24, 2015 | HP Officejet 4630 e-All-in-One Printer
When printing, if I select any other form of paper than "Plain Paper", e.g. "Photo Glossy Paper", the print (of a photo) comes out with a distinct Magenta overhue. The true colours are...
Hello Landscapeman ,
You need to specify the paper type when the print dialog box appears. Heavy glossy paper needs to spend more time in the fuser so that the toner is fixed.
Mar 25, 2008 | Computers & Internet
HP photosmart C6280 when i printed photo on plain paper the color came out is original color., but if i using same setup and printed on photopaper , the color came out not true...pls help this...
The process is different for photos than for plain paper.
It is likely that one of your colors are not printing, probably one of your `light' colors. You can perform a `nozzle check' by using the menu on your printer. This shows you the colors that are printing, and whether they are printing correctly.
If you are using refilled ink, that could easily be the issue.
Try performing the printhead cleaning, again in the menu on your printer. If that does not work, try replacing the ink tank for the faulty color.
If none of this works, it is likely that the ink delivery system is cracked, a common problem in these models.
In this case, replace the printer.
Sep 20, 2010 | HP Photosmart C6280 Printer
Can't select "Plain Paper" when printing from Excel (2008) on a Mac OS 10.6.2. From the Print dialog box, I select "Paper Type/Quality" and attempt to change the "Paper Type:" from "HP Premium Plus Photo"...
Hello, Jon.
There are some problems reported with the printer driver from the HP site, in case you obtained your drivers, there.
Go to the Apple website to obtain the driver and reinstall the driver.
Hope this helps.
Jan 09, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
When I tryto print 5x7 prints from windows fax viewer my photosmart all in one model C4480 is printing the first 5x7 fine but the second 5x7 also has a small wallet size printed ontop of it
Solution one: Print on heavier paper Try printing on a thicker type of paper. Solution two: Check driver settings If printing on plain paper, make sure the driver settings are set to Plain Paper.
  1. To change the driver settings, click the Properties button in the Print window.
  2. If the Paper Type is not set to Plain paper, click the drop down box and choose More .
  3. Find and click Plain paper , then click OK .
  4. Click OK to return to the Print window and click OK to continue printing.
Jun 18, 2009 | HP Photosmart C4480 All-In-One InkJet...
Borderless printing kodak 5500, clear coating business cards
The paper size must be set to borderless in both the application (MS Word) and the printer driver. To set borderless printing in the application, follow the steps below.
  1. Click File , then Page Setup .
  2. In the Page Setup dialog box, click the Paper tab.
  3. Under Paper Size, select the appropriate borderless paper size.
To select borderless printing in the printer driver, follow the steps below.
  1. In the application, click File , and then click Print .
  2. In the Print dialog box, click Properties , and then click the Paper/Quality tab.
  3. Select the appropriate borderless paper size.
HINWEIS: Under Paper Type, you cannot choose plain paper and print borderless. Choose photo or brochure paper instead. s.gif
Nov 14, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printing to 4 x 6 paper
Hello oyam26,
For any paper mismatch issue, first thing you do is try to set the paper type to plain. This will fix the issue in most of the cases.
gud luck
Nov 01, 2008 | HP Photosmart C4280 Aio Printer
Cartidge jams when trying to print a fax
I use to sell the generic ribbons. they have a lower heat transfer. the ribbon starts melting to the paper & causing all kineds of problums. Sorry to say you need to buy name brand.
Oct 10, 2008 | Brother FAX-575 Plain Paper Thermal
HP 1610 printer
It occurred to me when I was reading your post that photo paper has printing and non-printing sides. If the paper is loaded upside down, it's printing on the non-print side, which would result in what you're seeing. It's just a hunch, but you might want to consider it.
HP.com has a web page that will walk you through the process of checking on this and other potential problems.
Checking image quality problems
Hope this helps. Good luck.
Oct 09, 2008 | HP PSC 1610 All-In-One InkJet Printer
Extremely slow copying
Cartridges may give a very slow printing if internally damaged, or :
When using colored paper in the all-in-one, printing or copying is slow.This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper. The print out takes longer because the unit is printing in Best mode instead of Normal mode.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Double-click Printers and Faxes .
  3. Right-click the appropriate all-in-one, and then click Printing Preferences .
  4. Click the Paper/Quality tab and under Type is: select Plain Paper . This sets the default paper type setting to Plain Paper.
Hope this helps.
Jan 05, 2008 | HP Photosmart 2610 All-In-One InkJet...
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
