Question about Whirlpool Duet GHW9150P Front Load Washer
Where is the water sensor, how to replace it - Whirlpool Duet GHW9150P Front Load Washer
  • 472 Answers
IF you are referrring to the inlet water sensor it will be on the top ....looking at unit it will be on the left hand side...you have to remove top cover which requires removing the screws in the back of unit and then taking the top off... make sure all power is off to unit or it is unplugged... you will see the part as i hopeyou can match it up with your replacement part. requires a little time and patience but is fairly easy to replace.... i have found alot of times this is a faulty code and it ends up being something else like the pcb board or drain pump ...the erc (main control) will throw all kinds of codes ..make sure before you go through all this you start the washer 2 or three different times and see if you get the same fault each time in the same area of run time.... good luck to you
Posted on Jan 03, 2011
Lg wf-t1022tp gives a PE error code.
Try this first before replacing any parts or disassembling your LG washer:
- Unplug the washing machine for 1 minute.
- Plug the washing machine back into power.
- Restart the wash cycle.
- The washing machine may now have cleared the PE error code, if not see below...
You will need to check the wiring harness that connects the water level pressure sensor to the main control board.
- Check for a loose wire harness, a damaged wire harness, or a burnt faulty wire.
- Check that you get continuity through the wire harness by checking it with a multimeter.
- If the wire harness from the water level pressure sensor to the main control board is found to be faulty, replace it.
- If you get continuity and the wiring harness is securely connected to both the water level pressure sensor and the main control board, then proceed to the step below...
LG WASHER PE ERROR CODE - FIX METHOD #2
Water Level Pressure Sensor Switch Is Faulty And Needs To Be Cleaned Or Removed And Replaced.
Most commonly, if the wire harness is secure, tight, and not damaged, the part that needs to be checked is the water level pressure sensor.
- First check to be sure the water level pressure sensor is not caked with hard water or other debris.
- If the water level pressure sensor is not clean, the PE error can display.
- Remove the water level pressure sensor from your LG washer and clean off any hard water or debris.
- Clean out the tube that connects to the
- If you found the water level pressure sensor was caked with debris and you have cleaned it, replace it back into the washer and run a test.
- If the washer runs without the PE error code displaying, the washer is fixed and the PE error has been cleared.
- If you find that the water level pressure sensor is faulty, remove it and replace with a new OEM part.
lg-electronics-washing-machine-water-level-sensor-pressure-switch-hth0u4ums0hor52ud1sodlv4-2-1.jpg
Replacing the water level pressure sensor simply involves locating the sensor in your LG washer. Remove it from the washer and replace it with a new genuine LG washer part. Test washer to be sure the PE error code has cleared and the washer is now working properly
Mar 20, 2017 | LG Washing Machines
How do you replace the water level sensor?
Samsung Dishwasher Repair oE code_CRICKET in Water ...
? 3:23
https://www.youtube.com/watch?v=YOvFYcaLp8w
Jun 22, 2014 - Uploaded by Mgionfriddo
Samsung Dishwasher failed less than a year old. ... Removedwater level sensor to inspect and found a dead cricket blocking the float inside of it. ... worst, it'll throw that error right after 2mins of power on, any ideas what to do next? .... Dishwasher HeaterReplacement - Samsung Dishwasher Repair (part ...
Dishwasher Water Fill Sensor Replacement - LG ... - YouTube
? 6:28
https://www.youtube.com/watch?v=JjM-4FAg0Nc
Jan 24, 2013 - Uploaded by RepairClinic.com
Dishwasher Water Fill Sensor Replacement - LG DishwasherRepair (part #6501DD2001A) ... instructions ...
Nov 24, 2015 | Dishwashers
Why is my water sensor open
Do you mean your heater is saying water sensor open? Or your control?
Whichever one it is , simply replace the sensor, if it's the system giving you this msg the. Find a probe with a bandclamp on your plumbing and replace it .
If it's the heater giving the code then depending on what type heater you have, the temp sensor is located around the header area
Mar 07, 2015 | Jandy Aqualink Rs4 One Touch Control...
I was receiving an F3E2 Error code which states something to do with the water temperature sensor. I got a new water temperature sensor and replaced. Now the washer will run fine without any clothes in the...
WATER TEMPERATURE SENSOR ERROR
If the water temperature sensor (NTC) value is out of range (23°F to 217°F
[-5°C to 103°C]) during the water-heating step of the WASH cycle.
Possible Causes/Procedure
- Unplug washer or disconnect power.
- Make sure that connections to water heater & CCU (TH2 & HE2 cavities)
connectors are not broken or with wires detached, and that connector internal
pins are visible.
- Check continuity from the water heater sensor (black wires) to CCU
(TH2 cavity) connector.
- If the continuity diagnosis failed, the Main Harness must be replaced.
- Check the resistance of heating element.
- Check the resistance of the water sensor.
- Plug in washer or reconnect power.
- Verify the washer operation by running the Diagnostic Test cycle.
- After the diagnostic test has finished, unplug washer or disconnect
power and wait for 15 seconds.
Water Temperature Sensor
1. Unplug washer or disconnect power.
2. Disconnect the wire harness from the water temperature
sensor and measure the resistance of the sensor. Use the
following table. An abnormal condition is an open circuit =
infinity; Water Temperature Sensor must be replaced.
Temperature Results
32°F (0°C) 35.9k ?
86°F (30°C) 9.7k ?
104°F (40°C) 6.6k ?
122°F (50°C) 4.6k ?
140°F (60°C) 3.2k ?
158°F (71°C) 2.3k ?
203°F (96°C) 1k ?
Nov 25, 2014 | Washing Machines
MV450 Scotsman Ice machine
1. bin full when bin is empty means that the bin control sensor is dirty or need to be replaced. But since your having problems with water over flowing also i would bet that your machine needs a good cleaning. is you water full light on or off? if off and water sump try is full then you need to pull water sensor out and clean or replace it. if water sensor light is on then you need to replace water inlet valve.
Jun 26, 2013 | Kitchen Appliances - Others
E10 error code on Frigidaire affinity how to repair it
Your fill time, water fill time, is too long. Have a professional complete the following:
. Is the incoming water flow normal? Yes, go to step (4). No, go to step (2). 2. Are the incoming water faucets turned on? No, turn water faucets on. Yes, go to step (3). 3. Is the incoming water pressure above (30) psi? No, have customer correct pressure problem. Yes, check for kinked or blocked incoming water hoses, clean incoming water screens. If problem still remains, replace the water inlet valve assembly. 4. Does the fill water continue to enter the washer? Yes, go to step (5) no, go to step (6). 5. Remove power from washer. Did the water fill stop? Yes, go to step (6). No, replace the inlet valve assembly. 6. For Better models, check the electronic pressure sensor. For Good models, check the pressure switch. Pressure sensor checks good. Go to step (7). Pressure sensor checks incorrect. Replace pressure sensor. 7. Replace the Main Control Board
Aug 16, 2012 | Frigidaire Affinity ATF7000ES Front Load...
Two of the baffles broke replaced them now getting a code f05 and washer beeps and wont finish wash cycle
https://secured.whirlpool.com/Service/.../Duet%20Job%20Aid.pdf
Above is your service manual, look in the area of the NTC sensor,it needs to be replaced, the service manual will show you how.
You need to replace the ntc sensor, most likely.
F/05 Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
  • Check the Water Temperature Sensor, Heating Element and Element Relay
  • Check connections to the Sensor, Heating Element and Relay
Aug 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Where on the engine is the location of the crankshaft position sensor? What is the time required to change it?
Crankshaft Position Sensor Replacement - Removal Procedure
1. Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnect/Connect Procedure in Engine Electrical.
2. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
3. Remove the starter motor. Refer to Starter Motor Replacement in Engine Electrical.
4. Disconnect the crankshaft position (CKP) sensor electrical connector.
5. Remove the CKP sensor bolt (1).
6. Remove the CKP sensor (2) from the engine block:
• Remove the sensor by pulling on the sensor connector. DO NOT pry on the bracket.
• DO NOT rotate or twist the sensor or damage the mounting bracket if the sensor is being reused.
Installation Procedure
Important: When replacing the CKP sensor with a new sensor or reinstalling the original sensor, use the following recommended procedures:
• Ensure that the CKP sensor bore is completely free of any foreign material, such as old O-ring, dirt, burrs, etc.
• Ensure that the flange on the CKP sensor bore is not damaged.
• Clean all the mounting surfaces before re-installing any components.
• Inspect the CKP sensor and replace the sensor if any of the following conditions are present:
- The bracket is damaged.
- The bottom of the brass housing exhibits any damage.
- Never install a sensor that has been dropped.
• Lubricate the O-ring on the sensor with clean engine oil prior to installing the sensor .
• Inspect all the connectors for any damaged terminals.
1. Install and fully seat the CKP sensor (2) into the engine block.
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
2. Install the CKP sensor bolt (1).
Tighten
Tighten the bolt to 9 N·m (80 lb in)
3. Ensure that the CKP sensor mounting flange is contacting the engine block.
4. Connect the CKP sensor electrical connector.
5. Install the starter motor. Refer to Starter Motor Replacement in Engine Electrical.
6. Connect the negative battery cable. Refer to Battery Negative Cable Disconnect/Connect Procedure in Engine Electrical.
7. Lower the vehicle.
8. The CKP System Variation Learn Procedure must be performed after replacing the CKP sensor. Even if the original sensor is reinstalled, the Learn Procedure must be performed.
9. Engine Coolant Temperature Sensor Replacement
Removal Procedure
Notice: Use care when handling the coolant sensor. Damage to the coolant sensor will affect the operation of the fuel control system.
1. Partially drain the cooling system. Refer to Draining and Filling Cooling System in Engine Cooling.
2. Remove the exhaust gas recirculation (EGR) inlet pipe. Refer to Exhaust Gas Recirculation (EGR) Inlet Pipe Replacement .
3. Disconnect the ECT sensor (1) .
4. Remove the ECT sensor.
Notice: Replacement components must be the correct part number for the application. Components requiring the use of the thread locking compound, lubricants, corrosion inhibitors, or sealants are identified in the service procedure. Some replacement components may come with these coatings already applied. Do not use these coatings on components unless specified. These coatings can affect the final torque, which may affect the operation of the component. Use the correct torque specification when installing components in order to avoid damage.
1. Coat the sensor threads with sealer GM P/N 12346004, (Canadian P/N 10953480) or equivalent.
2. Install the ECT sensor (1).
Tighten
Tighten the sensor to 20 N·m (15 lb ft).
3. Connect the ECT sensor electrical connector.
4. Install the EGR inlet pipe. Refer to Exhaust Gas Recirculation (EGR) Inlet Pipe Replacement .
5. Fill the cooling system. Refer to Draining and Filling Cooling System in Engine Cooling.
6. Engine Coolant Thermostat Replacement
Tools Required
J 38185 Hose Clamp Pliers
Removal Procedure
1. Partially drain the cooling system. Refer to Cooling
System Draining and Filling .
2. Use the J 38185 to remove the radiator hose clamp from the water inlet housing.
3. Remove the radiator hose from the water inlet housing.
4. Use the J 38185 to remove the heater hose clamp from the water inlet housing.
5. Remove the heater hose from the water inlet housing.
6. Use the J 38185 to remove the surge tank inlet hose clamp from the water inlet housing.
7. Remove the surge tank inlet hose from the water inlet housing.
8. Remove the water inlet housing bolts.
Important: The water inlet housing (2) and the thermostat are replaced as an assembly.
9. Remove the water inlet housing and the thermostat.
10. Inspect and clean the water inlet mating surfaces.
1. Install the thermostat and the water inlet housing (2).
2. Install the water inlet housing bolts.
Tighten
Tighten the bolts to 9 N·m (80 lb in).
3. Install the surge tank inlet hose to the water inlet housing.
4. Use theJ 38185 to install the surge tank hose clamp to the water inlet housing.
5. Install the heater hose to the water inlet housing.
6. Use theJ 38185 to install the heater hose clamp to the water inlet housing.
7. Install the radiator hose to the water inlet housing.
8. Use theJ 38185 to install the radiator hose clamp to the water inlet housing.
9. Fill the cooling system. Refer to Cooling System Draining and Filling
Time Estimated: 4.5 hours.
Hope helps.
Jul 23, 2010 | 2002 Oldsmobile Intrigue
Water overfills on our front end loader model wm1832cw. Is it a water level sensor issue?. Is there a way to confirm that its the sensor. In the troubleshooting guide it also states that it can be a...
The problem may be the inlet valve or the pressure starter may be defective first replace the inlet valve then check it
If problem exists kindly replace the pressure starter
Jan 02, 2010 | LG Washing Machines
Water overflow
when u replaced the sensor was it the round one that has a clear pipe going to it if ti wasnt u will need to replace it if it was then take the clear pipe off and blow down the pipe this will reset the wayer pressure sensor and should stop the washer from overflowing m8
Aug 19, 2007 | Maytag PAV2300 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
23 people viewed this question
Dan Webster
Dan Webster
Sal De
