Question about Genie Company Genie Intellicode GITR-3 Opener for Genie Models 1022, 1024 and 1026
Cannot program multiple remotes to open 2 different garage doors. Only one door opener will program. Can you help?
  • 18 Answers
SOURCE: remote garage door opener
1-800-355-3515
www.homelink.com
1. Position vehicle within 10 feet of garage door- engine off and battery on.
2. Press/hold 2 outside buttons of Homelink transceiver until red indicator starts flashing rapidly, then release button. This should take about 20 seconds. This erases any previously learned codes.
3. Press/hold remote control and press/hold button of Homelink transceiver simultaneously. Slowly move remote control from 5" away to 1" away from Homelink transceiver. Release both buttons after red indicator starts blinking rapidly. This should take about 5 seconds. I discovered that the Homelink in my TL is a bit faulty because it took much longer to accomplish this than when programming the Homelink in my MDX. My TL's Homelink may "unlearn" it's code in the future and the needed proximity of the TL to the garage door may be much closer than desired until I get the Homelink fixed.
4. Press training button on garage door opener unit until the indicator lights illuminates- this should be immediate.
5. Within 30 seconds press/hold the Homelink button for 2-3 seconds until the red indicator starts flashing rapidly. Repeat a second time. It should now be programmed. Check it by pressing the programmed button on the Homelink receiver.
6. When programming more than 1 garage door opener unit, disconnect power from unit before programming more units. By not doing this the programmed unit could conflict with the unprogrammed units commands.
Problems:
1. The Battery in the garage door remote may be too weak to program Homelink. However, the battery may be strong enough to operate the garage door. One of my remote controls had a weak battery- my system was installed today, fresh out of the box. I had to use the second remote control for the programming of Homelink on my 2 vehicles.
2. Antenna on the garage door opener unit must be hanging down, fully extended.
Posted on Dec 08, 2008
  • 3 Answers
SOURCE: garage door opener
I was having a problem with the remotes. Program one remote, and the other stops working and vice-versa. I found the solution to be as follows: Using 61LM single-button remotes for Lift-master WhisperDrive (belt drive) garage door opener, I set the dipswitches (find them by removing battery replacement cover) to identical settings in both remotes. Set the first dipswitch to the neutral (0) setting. Next -- and this is the important part -- press the learn button on the main door opening unit, and, while the small LED light is lit, press the button on ONE of the remotes. DO NOT REPEAT ON THE SECOND REMOTE. Upon doing this, I found that BOTH remotes at last worked. I then went on to program a keyless entry pad, which was accomplished by again pressing the learn button on the main unit, and then entering the number sequence I had chosen for my entry code on the keypad, and pressing Enter. Both remotes continued to function and the keypad functions as well.
Posted on Jan 17, 2009
glenmann62
  • 91 Answers
SOURCE: programing garage door opener remote
ok crystal,calm down this is an easy one! first locate the smart button on your openers , next you will press and hold down the smart button until you see an indicator light above it shut off, while your holding that button the light will be solid ,Now your ready to program your remotes ,first programm one side by taking each of your four remotes and pressing the smart button on machine then pressing the button on the remote you want to program,by doing that you will notice the lightbulbs on your machine shut off and go back on , This is an indicator that your machine has accepted the code , now do it with the other three remotes , after you,ve programmed all four ,go over to the other machine and repeat the process but this time you have to choose another button on your remotes since you,ve programmed all four remotes to the same button on each remote ,just choose the bottom button on your remotes this time to keep them seperated , hope this helps you and it is as easy as 1-2-3 your owners manual will describe exactly the same ,i know because i,ve installed over 27,000 machines working as an installer for sears, please leave a nice feedback rating if i was able to help you, good luck,Sincerely Glenn Mayer
Posted on Apr 01, 2009
SOURCE: Reprogramming a Genie garage door receiver
I ned a akai audio timer DT-100
Posted on Aug 18, 2009
  • 3 Answers
SOURCE: remote missing on old dominator garage door opener
This is the most complicated way I know of coding a remote and I am a tech. who does this all the time.
Turn power off. Wait 3 sec's & turn back on. Quickly press program button on back of box twice. Lights will flash, bottom light will stay on. Press program button twice, & No. 3 light will start flashing. Press and hold your remote button until light stops flashing. Code will be accepted.
Posted on Feb 08, 2010
How so I program the two together? Struggling here
If the opener have the same color learn buttons you can program them on the same remotes using different buttons. If the learn buttons are different then you will have to get universal remote like a clicker to program them. You can get one at most hardware stores.
Jun 08, 2015 | Building Materials
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
My opener opens both garage door I only want it to open one
You will need to erase both openers out and recode.
Press the learn button on the motor head until the led light goes out on it. Wait for 2 minutes. ----- Press and release the learn button and then press the button on the remote 3 times and try. Genie openers sometimes take multiple times doing this to code in for some reason. For multiple remotes repeat from -----. For the other opener do the same thing but with a different button on the remote, unless you have a 1 button remote then use different remotes for the 2 doors. Thanks BB
Aug 31, 2010 | Genie Company IntelliCode GICT390-1BL...
Replaced batteries.changed codes verified not in lock position checked wiring-checked breakers -remotes dont work have 2 different units-one commercial all stopped working on same day -need help
I have the Same Problem...
2 similar but independent 315MHz Craftsman door openers stopped receiving any remote signals at the exact same time. One hour they worked , next hour they didn't, no storms in area.
I know remotes are good because they still open our subdivision gate. the Only way to open door is with wall pad. Verified that they are not on vacation lock. 5 different remotes, 2 different keypads all no longer open door.
I tried resetting codes with learn button but they won't take new programming. Also before when an unlearned remote was used in the area, the learn light would at least flicker (as if it was receiveng a code, but rejecting it) It no longer even does that.
i even cycled the circuit breaker and the vacation lock, no help.
Does anyone know how to fix this?
Oct 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Programming multiple remote door openers I am trying to add a remote key pad to the exterior of the door. When that is programmed and working it knocks out the car remote. I have 2 of those. How do I get...
i think what is happening is the code in your open has a list of different codes it cycles through to keep someone from "capturing" it and opening the door when you gone.Try having someone help you and program the three units at the same time.
Sep 06, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Remotes won't open garage door, keypad will
If you look were the small wires attach to the opener there should be a red program button and instructions on how to program remotes.
Feb 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote garage door opener
1-800-355-3515
www.homelink.com
Problems:
Oct 11, 2008 | 2003 Acura MDX
Programing garage door opener remote
Mar 12, 2008 | Sears Craftsman LiftMaster Chamberlain...
Genie Company Genie Intellicode GITR-3 Opener for Genie Models 1022, 1024 and 1026 Logo
363 people viewed this question
Top Genie Company Home Security Experts
Lawrence Oravetz
Are you a Genie Company Home Security Expert? Answer questions, earn points and help others
