Question about Convair Heating & Cooling
I purchased my convair aircon in 04/08. It has been in storage and I have only just started using it. When cooling it starts to cool then starts beeping and has E1 on the display. this can only be stopped by turning aircon off at the power supply 0448027111 Trevor
  • 2,133 Answers
E-1 Indoor blower motor mechanism locked or Indoor sensor problem. Rotate blower wheel manually. If not rotate, replace bearing. If motor good, replace sensor.
Posted on Jan 03, 2011
My car said "engine hot
Full coolant level does not mean your engine cannot overheat. You need to fix the problem as overheating will destroy the engine if not addressed.
The radiator cooling fans must be working, as must the water pump. The thermostat must also be working properly.
There must also be no air in the cooling system as air locks will impair water flow. When cooling systems are drained fully or partially and re-filled air in the system must be bled out using the correct bleeding procedure for the particular engine/cooling system. Failure to do this properly will lead to overheating.
If you ONLY see the overheating warning when running your aircon you need to check that the electric radaitor fans are kicking in at idle when you switch on and run the aircon and the engine has been warmed up some. If they do not start operating when the a/c is running you will get an overheating condition in normal driving conditions.
If the radiator fans are operating normally and you still get an overheating warning when the aircon is on or off the most likely culprit is a faulty thermostat in the engine's cooling system which will need to be replaced.
If you have either a faulty thermostat or if the water pump in the cooling system fails you will get continuous overheating whether the aircon is on or off.
Sep 05, 2011 | 2006 Chevrolet Impala
I had the aircon thermostat on cold then my friend just transfered it to warm without turning the aircon off because it was too cold. in the afternoon when i tried to use the aircon theremostat to...
Problem is the thermostat.The heat/cool selector switch might not be making try back and fourth from heat/cool to make a good contact.In heat mode make sure the temp is set LOWER than your cooling temp.If it is too cold in the future just RAISE the cooling temp up and not the heat/cool switch.
Jun 04, 2011 | Heating & Cooling
My car overheat when im using the car aircon,it doest overheat when im not using the aircon,so how can i use the aircon with out overheating my engine,i already clean the radiator,condenser,check the...
The cooling fan should run continuously when the A/C is on. If it does then I suggest you drain and flush the cooling system, and replace the thermostat. Fill it with a fresh supply of a 50/50 mix of antifreeze and distilled water.
May 16, 2010 | 1999 Suzuki Vitara
My LS-H186 VML 1Metal Art Cool 12000 BTU Air Con does not heat up
You should also check the outside unit to make sure the coil is not clogged with dirt or grass clippings and the fan is working. The reversing valve that switches it from cool to heat could also be a problem. If it isn't shifting it will not switch between heat and cool.
Apr 29, 2010 | LG Art Cool LA181CNW Split System Air...
My convair millenia is not working well
we drained the water and fill it up again and started to worf fine. we think that maybe we filled it up too much. thank you
Jun 29, 2008 | Dryers
Heating & Cooling Logo
177 people viewed this question
Top Convair Heating & Cooling Experts
Pete Norton
AJMAL KHAN
David Payne
David Payne
Are you a Convair Heating and Cooling Expert? Answer questions, earn points and help others
