Question about LG WM-2277HW Front Load Washer
I have a leak at the front bottom of my lg front load washer
  • 472 Answers
This most likely is coming from the pump assembly which is located on the front... make sure the clean out filter lid is tight and nothing is leaking from there... make sure you have no tears in the door liner /rubber boot... your going to have to gain access to inside of unit to inspect and see where exactly the water is coming from ....it could even be comning from one of the hoses that go to your dispenser area as water does go through there during operation..... good luck to you....
Posted on Jan 03, 2011
I have a LG front load washer seem to leaking front area. Hoses OK Need o see what causes it to leak
you will need to narrow down where the water is leaking from. under the door...? behind the bottom drain door..? underneath machine..? behind machine..? leaks can be found in many areas.
May 16, 2011 | LG WM-2277HW Front Load Washer
Leaking from bottom of front door
hi..
Try checking the rubber boot from the door opening to the drum for signs of hole or cracking..
thank u
rate me!!!
Aug 19, 2009 | LG WM2688H Front Load Washer
LG front load washer -- water leaks out the bottom of the door -- if I push on the door while its running, the water slows/stops leaking...
First, clean off the bottom of the door glass where it contacts the gray tub gasket when the door closes. Any hair or other build up can result in leakage. Second, if that does not completely solve your leak, you can move the location of the spring which holds the tub gasket from the very bottom (6 O'clock position) to the hinge area (9 O'clock position). Third: Sometimes, the reason you get a leak is due to the installation. If the washer was pushed into place by applying pressure in the center front of the washer, the outer front panel can be slightly deformed (inwerd) resulting in leakage from the door. If that is the case, sometimes you can remove the outer clamp and outer part of the gray seal and pull out on the front panel to correct the situation if it is not too severe, rather than replacing the entire front panel.
Jun 25, 2009 | LG WM-1832C Front Load Washer
Front bottom leak from my LG TROMM HE Washer
  • Hi
  • Try these:
  1. Inspect the water supply connections
  2. Inspect the drain hose
  3. Inspect the water pump
  4. Inspect outer tub for cracks or corrosion
  5. Inspect the tub seal
  6. Inspect the tub bearing
please rate my suggestion...
May 22, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Front load washer leak
This could be the rubber seal or the door lock. If the door lock is not pulling it tightly closed then it needs to be replaced. Check the seal really closely and make sure there are not cracks and it does not look deformed
Feb 16, 2009 | LG WM2277H Stainless Steel Front Load...
LG Front load washer
I JUST FOUND THE LEAK ON MINE JULY 5. THE DISCHARGE HOSE ON THE BOTTOM SLOWLY ROTTED THROUGH. THIS GOES FROM THE TUB TO THE DISCHARGE PUMP. ABOUT $9-10 ONLINE- BE SURE TO FIND AND DOWNLOAD THE PDF SERVICE MANUAL. TELLS YOU HOW TO TAKE THE MACHINE APART THE RIGHT WAY.
Jul 04, 2008 | LG WM-2277HW Front Load Washer
LG WD-8016C Front Load Washer leaks from the bottom
Crawls, usually all leaks are visible. Im surprised the repairman did not actually get to the source of it. Your drain pump sits on the bottom and it possibly could be the filter cap, hoses to the pump or pump itself. Another area to check is the despensor. There are a number of hoses to this which could be leaking. The bellow itself could have a cut in it somewhere along the bottom. I would call the repairman back and have him at least get to the source of the leak...Catriver..post back.
Aug 14, 2006 | LG WD-16115FD Front Load Washer
LG WM-2277HW Front Load Washer Logo
197 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
