Question about Kirby G4 Bagged Upright Vacuum
Just picked up the vacuum - any idea the dates of production on a G4 Anniversary Edition?
  • 694 Answers
The 10 digit serial number on ALL G series Kirbys (G3, G4, G5, G6, Ultimate G, Diamond Edition and Sentria) is engraved into the aluminum on the side of the Kirby, right above where the cloth bag attaches to the machine. This serial number contains the EXACT manufacture date of the machine.
The first number in the serial number will be a 1, 2, 3 or 4 and pertains to the quarter of the year in which the machine was manufactured. The second and third number is the year of manufacture.
FOR EXAMPLE.... in the serial number 1071104984, the machine was manufactured in the first quarter of the year 2007.
The G4 models were manufactured from 1993-96.
My G4 80th Anniversary edition doesn't seem to fit this, however. It's 8941106700. I suspect it's got a replacement handle.
Posted on Jan 03, 2011
  • 240 Answers
Ignore the first number. The second two indicate the year, the next two are the month, and the third two are the day. The last three are the order the machine finished assembly.
Posted on Jan 19, 2011
Very low suction when I use the hose, but the carpet brush roller attachment works fine. Any ideas?
This style of vacuum has great airflow but does not have great suction, especially at the end of the hose but it still should have enough to pick up most soils. It may have a restriction in the suction tube or emptor. The disposable bag may be full or clogged, the outer bag could also be clogged.
May 04, 2016 | Kirby G4 Bagged Upright Vacuum
Kirby G4 manual
The Kirby manuals are pretty standard. An on-line manual is located on the following site.
http://www.goodvac.com/articles.asp?id=135
Or you can download the manual for the G6 below.
http://ubermanuals.com/product/kirby-g6-8499
Mar 09, 2011 | Kirby G4 Bagged Upright Vacuum
Green light no on
HI There,
When the green lights do not come on when vacuuming with a Kirby, this indicates that your belt2_bing.gif has either broken or fallen off. There is a magnet on the beater bar that activates the LED green light when it's spinning.
Here's a helpful video tutorial2_bing.gif that we recorded, that will show you how to replace the belt, as well as perform basic maintenance on your roller brush to prolong the life of your belt as long as possible.
Video Repair on How To Check The Belt on a Kirby Generation G4:
I hope this was helpful! If you have any follow up questions, please feel free to use the comment field here on Fixya.
If you need to purchase a new roller brush, or belt for your Kirby G4, here are direct links to those parts on our website:
Kirby G4 Roller Brush Assembly:
http://www.govacuum.com/kir108.html
Kirby G4 Agitator Belt:
http://www.govacuum.com/kir143.html
If this repair was helpful to you, please be so kind and rate my repair helpful, or leave feedback for me. This is really appreciated by the Fixya community when someone answers your questions.
Thanks again,
Chris Jones
GoVacuum.com
May 21, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Oreck XL2 does not start.
There could be a problem with the cord. I suggest taking it to a local vacuum shop to have it inspected as that could be the problem
Apr 13, 2010 | Oreck XL2000 Bagged Upright Vacuum
My Hoover U5491900 Anniversary Windtunnel will not pick up very well, there is good suction when I use the attachments, but when I use it on the floor it won't pick up much, what is wrong with it and how...
The reason why it is not picking up well is because the belt is worn or stretched and it can't turn the brush (which picks up debris) against the resistance of the carpet. Here is the belt you need:
Hoover U5491900 Belt
Jan 20, 2010 | Hoover U5491-900 Bagged Upright Vacuum
Doesn't seem like it is picking up very well. Not sure if the roller is working right
Your belt is probably worn or stretched and there for not turning the roller brush the way it should. You should replace that belt at least once a year. If you haven't replaced it recently I would try that. Here is a link to the belt you need:
Girby G4 Replacement Belts
Nov 20, 2009 | Kirby G4 Bagged Upright Vacuum
G4 model is burning
May be the carbon brushes. DO NOT run the vacuum until you check them. If they are worn out, they can damage your armature and that is expensive to replace. Try my troubleshooting guide. It helps with do-it-yourself Kirby repairs. You'll also find links to directions and free repair guides!
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
Aug 22, 2008 | Kirby Ultimate G Bagged Upright Vacuum
G4 kirby
ensure the safety switches are made properly by making sure the front brush assembly is fitted properly, you will see a tag that enters the machine making the front switch, secondly make sure the bag bottom housing is on properly and fully rotated so that its tag makes the switch on the side.
The only fuse is in the plug (UK).
Common fault is the mains lead broken internally, unplug from the side of the machine after removing the little cover where the wire goes in. You can use a kettle lead to test the hoover.
If this does not cure it most likely the motor brushes are worn.
Jul 24, 2008 | Kirby G4 Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
623 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
