Question about Whirlpool Duet GHW9150P Front Load Washer
Each time i try to start the washer the f 11 code come on .the waher wont start, now there is a great amount of water in the washer, the pump wont start on the drain/spin cycle either
  • 472 Answers
Yes this is common for the whirlpool duet... if you remove the front cover lower cover that is you will see 2 maybe three screws at very bottom of unit.. once you remove this you will see a round shaped clean out that has a handle on it... prior to removing this make sure unit is unplugged and you have several towel in hand because there will be a gallon or two of water come out...if you have a shop vac they come in great hand for this project. vac all the water you can out of the tub and then have it ready when you open this clean out.. look inside for any foreign materials (ie: coins,bobby pins, i have even seen women metal bra linings get it this area) check the hose while your in there for anything and reach up into pump area and make sure nothing is in impellar..hopefully you find you culprit here ..sometimes trash will go through the pump and made out of plastic will damage plastic impellar and requires a new drain pump assembly. maybe you have caught it before that..... good luck give me a feed back thanks
Posted on Jan 03, 2011
How do I reset lg waher 1842cw it started stopped and now wont start
waher 1842cw? Have you looked at the trouble shooting measures in your manual yet? Check that first.
Feb 02, 2015 | LG WM-1832C Front Load Washer
Duet washer needed part number for pump display says"sud &f2" hose not clogged wont spin
AP3953640 is the part number at www.appliancepartspros.com they are 128 dollars and some shipping. what happened is that the pump is worn out and the water has not drained in the amount of time it was given and the pressure switch say its still has water in it. if you replace the pump it will start working again. if not replace pressure switch. but pump should fix it
Nov 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Waher stopped with an sud code and will not do anything. water is in washer.
too much suds in washer--
try using HE detergent-
reset to rinse cycle I think will work-been awhile since I had that code-
ready to throw my GHW 9150 off a cliff-FDL codes-door locks up.
Nov 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front load waher will not drain
Hi, your washer water pump, could be burnt out, or clogged up, but first check drain hose for kink, remove back of machine, locate water pump, device that your drain hose are connected to, remove all hoses, pump from washer, and clean, sometimes foreign objects get into it, and prevent pump impeller from spinning, also check water pump winding (coil) with ohm tester, place tester lead, one on each terminal on pump (motor) if you hear beep sound, pump motor o/k, if not, pump burnt out, replace it, but first remove pump, and clean it. after cleaning replace pump, try machine. you could put drain hose, close to floor, into buck, and water will empty by gravity, if water is not emptying, that's evidence your water pump is block, small object (handkerchief, coins etc.) gets into them, from time to time, first clean your water pump, `and check for kink, in drain hoses. . always disconnect power, before attempting any repairs. good luck.
Aug 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer won't spin out the water
This is a drainage issue. the spin cycle works in conjunction with the draining pump. they both work at the same time during the spin. if the drainage hoses or pump are clogged with debris, it will prevent the water from being drained properly.
Check the following to address the faulty drainage issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
May 31, 2009 | Maytag Washing Machines
Spin problem
you probably have a partial clog in your pump not allowing all the water to drain out the first time.id check the pump first
Jan 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Waher
ckd pump lean washer back against wall pump next to front ..2 clips hold pump to motor 2 clamps on hoses pump slides off motor ..also ckd hose from pump to drain underneath
Sep 10, 2008 | Roper RAX7244KQ Top Load Washer
How to get the back off a waher
The back is resting on some slots, try lifting the plate out of these slots.
Jun 28, 2007 | Whirlpool GSW9800PW Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
