When we took the cover off there is a red light inside the air conditioning unit (in the right bottom corner) flashing. The aircon is not working. The ventilator is working but the cooling is not working. If we press the test/emergency it is working for a while but after that it stops again. Your help is very much appreciated.
  • 2,133 Answers
Indoor fan motor mechanism locked. Replaced bearing for motor or motor itself.
Posted on Jan 03, 2011
I have an old Carrier N1340 air conditioner that works when switched on, green light flashes 4 times, for a few times then it shuts down. There is also a flashing red light inside that unit.
There will be a list of flash codes in your manual or on the inside cover of the unit indicating what the problem is eg. low pressure or high pressure alarm
Nov 15, 2016 | Carrier Heating & Cooling
I have a split-type aircon (brand: LG) with remote control.It has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
Apr 06, 2016 | LG LSC121PMA Split System Air Conditioner
How do I fix a refrigerator that won't cool?
if you are sure the evap fans are running (the ones inside) then only 2 things left.... 1- there is ice build up around the evaporators blocking air flow..... 2- the unit is out of freon.... I really suspect that there is ice around evap, samsung's are not known for having freon leaks.....I would unplug unit for 24-48 hours, then remove ff shelving, then take 2 screws out,(located on the bottom left and right of the evap cover and the one that is behind a plastic plug located in the center about 2/3 of the way to the top of the cover....once you remove the screws, grasp the cover on the bottom right corner and gently pull out to remove cover, being careful not to break the foam that channels air..... once removed check to see where the ice is left.... usually in the top right corner, if so replace the sensor located there... Ken Hawk
Feb 21, 2015 | Samsung RF217ACRS Bottom Freezer French...
LG aircon operation light flashes 8 times and then shifts to timer light flashes 4times and then back again to operation light but aircon is not operating.
jz on the aircon manuly on inside the front door.lift the front on the indoor unit there the on/off button,jz press it.don't use remote it can help u
Apr 20, 2014 | LG Heating & Cooling
Airforce WAP-35DIH A/C unit not working
I had the same problem, i just fixed mine. it's easy. unplug it first and give it a moment to discharge the capacitors so you dont get a shock..
1. remove the back cover by unscrewing and pulling it up and out. it may take some wiggling.
2. unscrew and remove the front cover - screws are at the top inside the back of the unit
3. face the front of the unit. in the bottom left corner is a silver tube held in place by 2 screws. remove the bottom screw and slide the silver tube out to the left so its dangling on its wires.
4. beneath the silver unit is a panel held by 1 screw. unscrew it. the panel is long and flat...coax it out of the front of the machine from underneath everything it sits on. dont disconnect the wires tho. the panel is long, you can push from the back of the machine as well as pull from the front. wriggle it out.
5. a piece of rectangular polystyrene will come with it . this is the float. on top of the long panel is a (reddish) switch. as the water rises, the polystyrene floats up and pushes on the switch.
6. clean off the polystyrene and the water tray beneath it, check that the flap flaps freely.
7. carefully (live wires around!) plug in the air con and check that with the flap dropped down (not pushed up) the aircon unit works.
8 if so, hooray, reassemble everything. job done.
Jul 11, 2013 | Cell Phones
How to reset pre-def red light blinking on teco aircon unit
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
Air Conditioning Tamarac
Jun 10, 2013 | Heating & Cooling
TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Jun 09, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
Timer green light flashing when turned on but aircon isn't workn
reset the unit by disconnecting the power supply for 10 sec. then "on" again and start the unit. If it wont work you need a qualified tech. to solve the problem.Some of your safety device might be defective.
Jan 31, 2009 | Heating & Cooling
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
