Question about RCA Televison & Video
TV wont recognize lower channels - RCA Televison & Video
  • RCA Master
  • 2,098 Answers
Your Tuner might be faulty but before replacing it there's also 1 thing to be checked.
You need to bring your unit to repair to checked the band switch I.C. before replacing the tuner.
Tuner is divided into 3 bands (VL,VH,UHF) since you have no reception on the lower channels, it seems that your VL bands is faulty that might be cause by defective tuner or Band switch I.C. located near your tuner.
Posted on Jan 03, 2011
Lg tv wont recognize pc
You may want to lower the resolution on your laptop and try again !!!
Aug 31, 2012 | Televison & Video
I have a universal remote..but my sanyo wont recognize all my channels. The remote wont work the menu.
the universal remote normaly have more than one code for the same brand, keep trying deferent codes for that brand and you will fine the right that will work.
Aug 29, 2011 | Sanyo DS31520 31" TV
The tv wont pick up cable channells 2-6 and i cant figure out why
From your description it sounds like the lower channels 2-6 are not working, this indicates a tuner problem in your tv, to fix this will be expensive. But if you have a vcr you could use it as the primary channel changer eliminating any costly expense.
Feb 28, 2011 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Toshiba 26AV500U This is being used as a 2nd set connected to a DishNetwork receiver. The set must be tuned to channel 73 to receive the signal, and no matter what I try the TV will not recognize 73 as a...
Tries tv unplug,replug it back like about an hour later.For forcing the tv do a resetting itself back to the factory setting.The tv now should be recognizing channel 73.
Feb 26, 2011 | Toshiba 26AV500U 26 in. LCD HDTV
I have a sanyo tv. Slightly older. Not hi-def or New
Hi:
This may be due to the possiblity that the you are on the wrong input source, If you watch HD Channels then the input source would either be componet or HDMI input. Try changing the input source of the television with the TV's remote until you see the Channels again. IF you are not watching HDTV then the television is on the wrong reception channel for the Direct TV's box. Try channel 4 or 3 or even 73.
May 06, 2010 | Sanyo AVM-2509S TV
LG HT502 wont recognize hdmi cable. it says hdmi
go into the video setup menu, and select HDMI set up and select "ON" that should do it
Jul 15, 2009 | LG LHY-518 System
CANT TURN TV OVER USING REMOTE CONTROL
Hi, use another set of batteries.
May 15, 2009 | Televison & Video
Sanyo Model AVM 3659G won't recognize DVD player
Let's try the easy one first:
  • verify the connections, normally yellow for video, white & red for audio. TV has to be set to Video 1, A/V or Channel 0;
  • in some instances, it could be a single coaxial cable. If it were so, the TV has to be set to Ch 3.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 05, 2008 | Sanyo AVM-3659S 36" TV
RCA F27664 27" TV Problem: HELP
Intermittent loss of lower frequency channels ie Ch:36, higher channels ok
Dry joints in UHF tuner, resolder the PCB to casing earth connections inside tuner
Channel reception lost if tuner socket moved
Dry joints on IC522, IC521 and IC541 (located in the big heatsink about middle of the main pcb)
Nov 24, 2007 | RCA F27664 27" TV
Televison & Video Logo
77 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
