White Nintendo top screen has broken where it goes into the hinge it is a D.S.lite.
  • 13,433 Answers
So you need a replacement screen for your DS lite?
Posted on Jul 09, 2008
Ds goes black and white
Hi Tristan,
Does the ds still turn on, which hinge is broken? Left,right or both as you open the lid?(very carefully though if you damage the ribbon cable for the top screen it'll need replacing for sure.
Jul 31, 2012 | Nintendo DS Lite Console
Nintendo goes black and white for colour
my brother had the same problem the hinges are truly broken but if you get a bulky nerf case it will support it
Jul 31, 2012 | Nintendo DS Lite White Console
My sons ds lite will not turn on the green light comes on and a white light flickers on bottom screen and thats all, I changed the battery and still no luck. Help! thanks
it's likely that the top screen ribbon cable has either become damaged or loose, the entire top screen will probably need replacing (along with the casing if the hinge is broken).. if you are not confident with technical or fiddley things I wouldnt recommend attempting it yourself.
Jan 08, 2010 | Nintendo DS Lite Console
My ds lite is broken from the hinges
You need a new case, fiddling with it whilst the hinges are broken can lead to broken top screen speakers/mic and wifi capability
Cases are on ebay and various other web sites for 10-20
Dec 08, 2009 | Nintendo DS Lite
Hinge and Top screen of my Ds lite is broken.... T-T
you would need to replace the top screen ebay has them cheap
top lcd item no. 380136107562
a replacement shell can be bought for around £10 +
depending on what design you would like
Aug 27, 2009 | Nintendo DS Lite Console
Ds lite top screen
Yes its fixable but it depends on what has broken.
There are two possibilities the small barrel hinge has broken, this is just a case of fitting a new one by opening the case, unscrew the light and gently pulling the top of the case away till you can change the barrel hinge.
The other one is the case has broken and is not holding the barrel hinge, can bodge it with some glue sometimes but most often you need a new case.
Jul 09, 2009 | Nintendo DS Lite Console
DS Lite Top screen is all white after replaced for new one
you should use a crystal casing because every time you open the ds the wires get messed up or put some thing on the hinge so the ds hinge will not get loose.
May 12, 2009 | Nintendo DS Lite
Green screen
There is a ribbon that connects the top screen of the ds to the motherboard. It is possible that this ribbon became damaged when the hinge broke. A possible fix would be to replace the upper screen. Hope this helps.
Jan 07, 2008 | Nintendo DS Lite Console
My nintendo ds lite top screen isn't working properly
Top LCD's flex cable that passes through right-hand hinge into bottom part of case will be damaged or not properly seated in its connector socket.
Nov 17, 2007 | Nintendo DS Lite Console
Computers & Internet Logo
David Payne
David Payne
