Question about Apple PowerBook G4 Mac Notebook
Multiple restarts required to get laptop running. It will run if I restart it about 7 times; prior to that it hangs up at each restart, then finally takes a couple more restarts to get the airport signal to come in.
    Problem Solver:
  • 19 Answers
Your harddrive may be failing.
Insert the CD that came with your computer originally and hold option (alt) when you turn on your computer. Then click on the CD icon and then the arrow below it. Once you have booted from the CD, open up the utilities menu bar and choose Disk Utility. Click on "Repair Disk" and let the program run, if the disk is not able to be fixed, you need to backup your data and then replace the hard drive.
There are plenty step by step guides on youtube. All you need is a 2.5 notebook hard drive and a Torque screwdriver set and you are good to go.
Posted on May 31, 2011
My windows loading takes so much time
Slow Windows Machine! Sounds like not enough resources such as RAM and CPU. Check Performance in Task-Manager (CTRL-ALT-DELETE). High CPU levels causes hang ups like freezing. Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate. Consider increasing RAM. Uninstall any extras like those pushy toolbars, and add-ons.
Nov 23, 2012 | Computers & Internet
My Lenovo U165 hung, and after waiting for the system to resume, the laptop suddenly freaked, screen went blue (with white text) for a split second, before the laptop restarted. What happened?
Remove all USB attached devices like drives.
  • Roll back system with System Restore. Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
  • Uninstall last program(s) that was installed, again in safe mode.
Oct 26, 2012 | Lenovo IdeaPad U160 Laptop Computer...
If i switch on it is showning os loading and hanging
Try restarting in safe mode by hitting the F8 key during the boot.
You now have options. Test one at a time. One of them should get you going again.
  • Disabling startup programs from loading in the first place. Go to Start > Run (search in Win 7) and type MSConfig. Go to Startup tab and uncheck anything that you don't want Windows to load automatically.
  • Use System Restore and rolling back to a earlier date. It can be found in help. F1 key loads help.
  • Uninstalling problem software. Usually the last thing installed prior to problem.
Sep 22, 2012 | Computers & Internet
Hi Expert, Whenever i am going to start my system, it will be hanging two to three time, each time i have to restart my system. Just would like to know what is the issue causing this...
Vivek, you may have a virus (there are many that causes this action) as a suggestion try these programs first:
1. Go to www.SuperAntispyware.com and download the free (yes I said free) program, after doing so run at least the quick scan to see if it finds anything. Do this even if you have a anti-virus program in place. If it's clean good if not then clean it.
2. Go to www.MalwarebytesAntimalware.com and download this program (also the free one) then run the quick scan on this program.
Usually these two programs will clean out the viruses that causes the problem you have. If this doesn't work then you need to Restore your computer to a time when your computer was working properly. I'm assuming you have some kind of Window's program. Go to start, click on Control Panel, click on Systems & Security, then click on back up and restore, follow instruction on restore to prior/previous date. Your computer will either automatically shut down & restart or it will ask you to shut down & restart. This should do it. If not I hope you have a back up DVD/CD that you can use to restore your system. If you have Windows 7 or Vista and you did what is suggested to do about saving a repair disc or a Mirror Image disc that I suggest doing either of those to restore you computer to when it was like when it was bought. I hope this helps. Be patient this all takes time.
Sep 17, 2011 | Sony VAIO VPCEA36FM/W Laptop
My computer is working slowly.And got hang many times while running.I also have already scan my computer.
Hi
For some reason computer getting slower because of faulty driver installed, multiple driver with the same driver installed, faulty installed software.
I suggest you run your laptop on safe mode to correct the faulty drivers and it will automatically fix it and also run the disk defragment on your C drive. Just go to start menu, choose accessories, system tools, choose disk defragment and after it restart your computer again. It will run faster that before.
Jan 13, 2011 | Compaq Presario Notebook
Vista hangs on restart at end of sp2 upgrade
Take advantage of Microsofts offer to go to Windows 7. You will solve this one problem now only to encounter more later.
Jan 09, 2010 | Lenovo ThinkPad T500
Qosmio G35-AV600 boot problems
You will have to reinstall both its BIOS and operating system, only that can properly solve the problem. I my solution was helpful, Kindly accept it.
Thank You, Arjun
Apr 01, 2009 | Toshiba Qosmio G35-AV600 Notebook
Intel Desktop bord D845GVSR with Windows XP hanging frequently
Sometime this happens when you use the drivers on XP you may need to down load the correct drivers and a good place to start is driverguide.com you may need to enter details for free registration
Jan 22, 2009 | Intel D845GVSR Motherboard
Jan 22, 2009 | Intel Motherboard
PC Booting problem
format the pc and reinstall os be sure to load all the drivers
Apr 09, 2008 | Computers & Internet
Apple PowerBook G4 Mac Notebook Logo
43 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
