Question about Garden
12 volt pump is getting very hot but not pumping. water comes through when being primed but pump is not engaging.
  • chris wheeler
    chris wheeler Jan 03, 2011
    what is the make and model of the pump ?
    c...
    Brigadier General:
  • 4,088 Answers
The pump may be turning in the wrong direction--the pump impeller blades must tun toward the outlet port. DC motors (12 volt) are sometime sensitive to which polarity the power is connected depending on their design. Try reversing the power connections to see if it works better. Make sure the impeller is being turned by the motor. Hope this helps!
Posted on Jan 03, 2011
Do you fill sand filter wth water to get filter primed
no just fill pump basket some you should add water before sand just get pump primed you should be fine
May 12, 2014 | Hayward 1 12 Hp Super Swimming Pool Pump...
When you turn the ignition switch on what sends 12 volt power to fuel pump fuse on 86 gmc s15 2.8
The pump relay powers the pump for 3 seconds, then again after oil pressure comes up above 5psi.
Jan 15, 2014 | GMC Cars & Trucks
How do you prime the siena?
Schaerer Siena machines can become airlocked from time to time leaving the pump running yet sounding rough. Easiest way of remedying this is by running the hot water (either by pressing the jug button or turning the hot water knob on the side depending on which model you've got) option through the silver wand. Once you get a strong water flow through this then the machine pump has been primed and you can then begin making coffee as normal. You'll notice the sound the pump makes will change as the water comes through.
Dec 08, 2012 | Schaerer Siena Espresso Machine
My flojet pump runs but it pumps no water . It is a 25 gallon sprayer
Sounds to me like it just needs priming (or in other words) the air bled out of it.
Using the force of gravity, force water to run STRAIGHT DOWN from the 25 gal tank, through the gate valve & into the running pump.
While doing this, close the bypass valve slowly until it's about 3/4 of the way shut.
You should begin to hear the sound of the pump begin to deepen as the air escapes.
If you don't, then there may be an air leak somewhere along the hose line, typically at the filter, causing it not to prime.
Correct the air leak, then you'll probably have better luck.
I recommend not running an electric pump like a Flojet for very long when it's not primed. Doing this may overheat it & shorten its lifespan considerably.
May 19, 2010 | Flojet Ag Sprayer Pump 2.1 Gpm 12 Volt...
Flotec 1/2 hp pump won't run. 124v line voltage. But L1 to L2 shows -00.1 to -00.4 Power supply line is 12/2 to a on/off switch and 14/2 to pump from switch. Distance to service is less than 100 feet
With your volt meter, check the voltage at the circuit breaker or fuse to the neutral bar. If you have 120 volts there, then go to the switch and check the 12/2 hot wire to the neutral wire, if you have 120 volts, then check the 14/2 hot wire on the switch to the neutral wire.
if you have voltage going into the switch and existing the switch, then check all the connections between the switch and the pump.
When you're testing for voltage, do not test the hot wire to ground. You have to make sure that the neutral wire is not broken someplace in the circuit
Nov 08, 2009 | Flotec Corrosion Resistant Shallow Well...
How to check electrical problems whit the fuel pump
first turn the key on and listen for the fuel pump to come on for 15 sec.this is to prime the system before you crank the engine.no sound,with only a rubber mallet( no metal hammers )hit the bottom of the gas tank,no fuel pump operating go to the fuel pump relay and remove then test for (2) 12 volt power supplies with key on,if ok check ground at relay if okay remove gas from tank and drop gas tank to check for voltage at pump.replace pump if 12 volts is present.
Oct 23, 2009 | 1996 Chevrolet Cavalier
Pump has no pressure
scrub up the check valve within the pump really well, that should help restore the prime! use dish soap and a toothbrush!
Jun 30, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
How do you prime the pump?
all you have to do is open the lid fill the basket with water close the lid and start your pump and then open your air relief valve on top of the filter until you see water coming out of it
Jun 14, 2009 | Waterway 1 Hp 115 Volt 2 Speed Side...
On my 1994 plymouth voyager the 3 wire harness to fuel pump (blue wire) doesn't have 12 volts; should it? fuel pump quit then worked once when hot-wired with 12 volts. fuse and relay is good.
The wire should not be hot until the relay is triggered. The relay does not get triggered until the ignition key is turned on. It will run for 3-5 seconds or until the system pressure it at max.
Apr 26, 2009 | 1999 Plymouth Grand Voyager
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
