SOURCE: My GTO model Andis clippers
YOU HAVE TO OPEN DEM UP. TAKE OUT THE SCREWS ON THE TOP DEN TAKE OFF THE BLADE. ONCE YOU HAVE THE BLADE OUT THERE ARE TWO MORE LIL SCREWS UNSCREW THOSE (NOT ALL THE WAY OFF, JUST ENOUGH SO THAT THE BLADE WILL MOVE) ADJUST THE BLADE HOWEVER YOU WANT. IF YOU WANT IT CLOSE FOR A MORE DETAILED CLOSE LINE (NOT TO CLOSE AS DEY WILL CUT YOUR OR THE CLIENTS SKIN). YOU MUST TRY THEM OUT ON YOURSELF SEE IF THEY ARE TOO SHARP, IF THEY ARE TAKE THEM OFF AND ADJUST THEM AGAIN. EASIEST THING TOO DO IS USE A MIRROR, HOLD THE BLADE AGAINST THE MIRROR DEN MOVE IT AT AN 45 ANGLE DEN TIGHTEN THE SCREWS DER (BARBER TRICK).
SOURCE: adjust blade
On the Andis T-Outliner or Outliner if you have use the trimmer for more than 3 hair cuts or 3 time or more I do not recommend moving the blade, reason why is that you have all ready start or have a sit in or a grooved, I have found that by moving the blade it won't cut at all.You need to resharpen the blade with a professional sharpener and have them reset the blade for the type of hair cut you want. The blade can be set to shave or do line ups, and Fades. This type of trimmer is for that kind of hair cut the professional barber use them all the time. Call Mannys Sharpening 323 263-4697 They have a good rating on Yahoo Local.
I have try many sharpener and had no luck, until a friend of mind told me about Mannys Sharpening, They know what they are talking about highly Professional in thier work.
SOURCE: how do I adjust the blades or sharpen blades.
Clipper blade sharpeners are availale but the cost of these typically start at about $300 and go as high as several thousand dollars. This makes it unaffordable for home use.
For affordable, professional clipper blade sharpening, I suggest you contact the folks at clipperparts.com
Your clipper moves at just one speed. There is no way to 'speed it up' if it is working correctly.
SOURCE: how do i get blades closer on the pivot pro t
You really can't move the cutting edge on any andis trimmer blades without throwing them out of spec. I say this to say that if you try (and the blades are not precisely set) it will scrape and cut the skin when you attempt to use them. They are factory set for optimum cutting. If you have found that they aren't cutting as closely or as cleanly lately, it just might be time to replace the blade entirely. I have a set of those, and a styliner II, but I prefer the cutting power of my T-Outliner over all.
