Question about Welding Tools
Wire will not feed ,I was welding with my weldpak 100 and it just stopped feeding the wire so I shut it down to look at the next day when I tried it the next day the wire fed like it was suppose to until I stated to weld again then it quit and still will not feed
  • 407 Answers
Your weldpack 100 has a duty cycle of only 20 t0 30%, meaning that your machine will weld for 2 to 3 minutes and then you need to let it cool down for the 8-7 minutes, then start again.
If the problem continues let me know.
Posted on Jan 04, 2011
I have a millermatic 175 it is new the over temp light is on . what could be wrong. and no wire feed.
You bought this brand ne from a merchant?
Take it back.
The over heat light is when you have welded too long and it shuts down to cool off; were you welding?No wire feed is too vauge; you looked at feed motor and the wheels aren't moving?
https://www.youtube.com/watch?v=ophtUI7RbmU
Sep 12, 2016 | Welding Tools
Why does my cmapells haussfield welder not feed the wire correctly (it stops feeding in mid weld then picks back up) and just stop feeding completely after 10 min of welding?
Check the "duty cycle" for your unit. If you try to run it too hot for too long, it will shut itself off to prevent overheating.
Mar 06, 2015 | Welding Tools
Lincon mig stops feeding wire
Been welding for a while, open side, check for proper tension on the feed wheel inside side panel, hit the trigger, if feed motor continues to spin tensioner needs tightened or mig wire may be getting hung up inside main cable lead. If motor is off on off on then its probbably the switch on the trigger getting a bad good connection, hope this helps o and check welding tip on gun end, may need replaced if worn or melted, unscrews.
Mar 05, 2012 | Welding Tools
I have a ProMig 175. Suddenly the wire feed motor does not work. The solenoid clicks. I have manually turned the wheel trying to reposition the contacts in the motor. No help.
Verify the polarity is correct for Flux or Mig configuration (should be on label under lid) - and ensure there are no loose connections on that polarity wire.
Loosen the tensioner + make sure the wire feed motor turns freely by hand.
My WeldPak 100 and SP-135T were tough to turn, but it did turn freely.
If it does spin freely, then inspect the contacts for the voltage selector. Make sure to unplug the power cord and keep clear of the big capacitor. My SP-135T contacts corroded while in storage.
Apr 12, 2011 | Lincoln Electric LINK2400-+2 CV-305 MIG...
Hobart handler 135 wire feeds for about a two feet then stops feed motor runs well under no load
This happens to me all the time. Wear and tear has taken its toll and everything has to be maintained for it to work. Most likely the welding tip is worn and should be replaced. Lincoln electric tips work well and I will replace mine several times during the day. Also check your tension and make sure the wire will uncoil freely from the spool. You can remove the tip and make sure the wire will feed without it. If not, your liner may be worn out. Also a welding Jell will help keep the tip from cloging. It will still happen, but hopefully not on your first weld of the day.
Jan 15, 2011 | Hobart Handler 140 Mig Welder
I have a Lincoln Weld Pak 100 that was working fine. I shut down the machine though and when I came back to it about 5 hours later the wire feed motor wouldn't turn anymore. Has anybody else had the same...
Check the voltage at the wire feed motor when the trigger is pulled.
I had a Weld Pak 100 that with 0 volts at the wire feed motor, and the problem wound up being that 2 of the big power (stud) diodes were shorted.
Feb 26, 2010 | Welding Tools
Millermatic 200 won't weld
first check on the plate that tells imfo of unit ,there is what is called duty cycle.If the duty cycle says per say 30%,that means you can weld full power for 3 minuets before unit will shut down to cool.if it says 100% duty cycle there is no limit on weld time.this is the first thing to understand,if that is not the case check the main contactor where the power imput wires go,pull the gun trigger see if the contactor is pulling in , it should if not no welding amperage.
Jul 11, 2009 | Miller Welding Tools
Snap On Ya219B No Spark
The transformer has an overtempature switch the shuts the welder down when its duty cycle is exceeded. After it cools, the switch will close and the welder will run again. However, you are not supposed to use the welder until waiting an additional cooling off period as specified in you manual(~10 min.).Also you are not suppose to weld beyond the duty cycle or damage could result. Especially if done on a continuous basis.
Apr 10, 2009 | Hobart Welding Tools
Welding Tools Logo
186 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
