Question about RTO Paslode 902000 IM250 Ii Cordless 16 Gauge 3/4 2 1/2 Inch Straight Finish Nailer
Paslode im250 fan running slow. light goes solid green when pushed to shoot, or pull trigger like it wants to fire. But fan runs slow and it wont fire! hot wired fan and it's fine . Changed the fan wire and molded circuit board. The only thing left is the spark assembly with the led circuit board, but it costs 90 plus bucks. Don't want to drop that and still have the problem. Any ideas?
  • RTO Master
  • 43,501 Answers
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Posted on Mar 06, 2011
Paslode finish nailer fan has problems starting and the light goes from green to red then it wont do anything?
It will probably be the head switch assembly. Top Gun still sell the parts or you could try ebay which would be the cheaper option.
Jul 08, 2014 | RTO Paslode 902000 IM250 Ii Cordless 16...
Have a Paslode IM250 regularly serviced. It has suddenly stopped working. Green light is flashing when battery is in but no fan etc. when trigger pressed. Replaced trigger switch assembly but still...
I would look at the head switch - this is located inside the tool just blow the trigger switch in the handle. There is a slide switch with a spring that actually makes the switch - make sure this is not broken and is in the correct position.
Also, check the fan connector in the head, I have seen these loosen up and back out.
If these don't solve the problem, I would suggest your problem is the molded circuit assy that contains the trigger switch and the head switch.
Nov 02, 2013 | RTO Paslode 902000 IM250 Ii Cordless 16...
Plaslode im250 second fix nail gun fires intermittently. Gas is loading fine and trigger working only fires about one in every ten pulls of trigger
heatman101
Dec 31, 2010 | RTO PasLode 900420 Impulse Framing Nailer
My paslode wont shoot i cleaned the gun recently and oiled also the light is green and i compress the tip to shoot and it wont but the fan still comes on to vent the gas i also put a brand new gas in
strip it down again and put the battery in and whilst holding the nipple down pull the trigger (just mind your fingers as the fan will start) and as you squeeze the trigger see if sparks each time
Mar 05, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode nail guns won't shoot
piston is probably jammed
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
Hope that helps
Feb 18, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
IM250 Paslode straight brad nailer, fan wont shut off
My paselode was doing the same thing, and I followed all of the cleaning instructions, but the problem continued.
If it was left alone for a minute, it would fire again, so I removed the cover over the trigger assy, and checked the spark plug wire connection. The trigger came out, and during reassembly, I noticed that the electrical switch was hanging, and slowly pushing back out.
I cleaned and lightly spray/oiled the switch pin, and voila.........works like a charm.
Jul 26, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode framing nailer 1998 yr. model when engaged wont fire
you have spark and cleaned tool correct, but fan won't turn that freely, if so the fan motor is bad, it should come on when you pull the trigger or move the roller lever for the safety. The fan is about 80.00 Let me know if I missed something and how did you check the spark?
Jun 10, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode im250 f-16 only able to drive 2 nails .
Bad Fuel cell!!! New cyliders now have expire date on bottom of cannister. If old will not fire properly. Put new fuel cell in should be fine.
Feb 21, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
RTO Paslode 902000 IM250 Ii Cordless 16 Gauge 3/4 2 1/2 Inch Straight Finish Nailer Logo
718 people viewed this question
Top RTO Tools & Hardware - Others Experts
Are you a RTO Tool and Hardware - Other Expert? Answer questions, earn points and help others
