Question about Dell Inspiron 1525 Notebook
My Dell 1525 has stopped being able to use the power cord for charging all of a sudden. Could it be a short or something?
    Genius:
  • 1,288 Answers
Hi
Check that the charger is outputting the correct voltage by testing the DC jack on the charger ( if you have the newer jack with the large outer and small inner pin, the red of the multimeter probe goes to the inner pin and the black to the outer pin.
See if you get a reading, if you do, charger is ok..
Make sure the battery is firmly locked in the housing
If no joy, post back
Posted on Jan 03, 2011
  • 53 Answers
Sometimes this happens to "generic" chargers, which come with the laptop. Also, it could be a shortage in the wire, check it to see if there are any rips, tears, holes, etc. If you see/hear sparks, your charger is definitely ruined. The most I can say is buy a replacement charger and also don't share your charger with people who have a laptop of a different manufacturer/brand, it shorts it out real fast.
Hope I was a help!
Inspiron 1525: "plugged in, not charging"
Not charging means the battery is not being charged. Batteries only have a useful life of so long, then they die and will not take a charge so you have to replace them.
If the laptop works fine when the power cord is plugged in, then just replace the battery. if the laptop does not work on the power cord, then you need to either replace the power cord or look to see if the DC Jack where the power cord plugs into the laptop is broken or wiggles. When the DC Jack it bad the battery will not charge and eventually the laptop will not turn on if the power cord can't make the connection correctly.
Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
May 22, 2012 | Dell Inspiron 1525 Notebook
My Dell Inspiron 1525 battery won't charge. The plug powers the PC but is not recognized by the computer and will not charge the battery. I have tried replacing the battery and cord, but no difference.
hi , it sounds like internal hardware problem , if you replaced battery and power supply then next the mother baord power relay for charging battery is out . you have take too a tech. . it will be high in price . thanks hope i been some help
Sep 25, 2010 | Dell Inspiron 1525 Laptop
Bought a new battery for Dell Inspiron 1545 and it's not charging.
You may want to try a new power cord to verify the power jack on the laptop is okay. If you have a battery plus store; or something in your area. They may test it for free.
Sep 21, 2010 | Dell Inspiron 1525 Notebook
1525 dell battery not charging.
this could be one of 3 things.
Bad battery
Bad AC power adapter
Bad internal power jack (where the plug goes into the laptop)
The easiest thing to do is to try and use your laptop with the ac power adapter plugged in and no battery. This should work but if it doesnt then you know it probably is your ac power adapter. But if you feel like you have to wiggle and hold the cord in then it may be the jack on the inside. The only way I know how to fix that is to take it apart and resoder the joint holding that part together to make a stronger electrical connection.
As for the battery if you let it sit out for a day it will discharge any current it currently has inside of it and then you can try again to charge it. If that doesnt work and your cord and jack seem fine then you will need to look for a new battery to replace the one that died. This happens over a couple of years as the battery life shortens over the life of the laptop and more so if you use it heavily.
May 07, 2010 | Dell Inspiron 1525 Notebook
Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell manual identifies the battery as the cause. But, except for this optical signalisation, the laptop works...
Dell Inspiron 1525 PC Notebook Hi,\r\nAt my dell 1525 the battery... Answer Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell... (More) Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell manual identifies the battery as the cause. But, except for this optical signalisation, the laptop works well, the battery is charging, the AC adaptor is working properly. What is happening? Stefan
Feb 19, 2010 | Dell Inspiron 1525 Notebook
When i start up my dell inspiron 1521 it goes into startup mode then screen goes black.took the power cord out n it will start up plug it back in the screen will go blank again.it will run on battery n the...
I have a Dell Inspiron 1525 and had the same exact problem. I finally called Dell and they sent a tech out. They replaced my power cord and all the software. The reason for this is because Dell Inspirons has a default in the AC cords. Sounds like the AC power cord is the problem. You could find someone who has this cord and test your Inspiron with it or try calling Dell! It worked for me.
Jan 28, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
When I plug in my power cord to my inspiron 1525 it will not charge. The cord appears to be in good shape. What can I do?
check the output of the poser supply. You have power going in ... do you have it coming out??
Dec 29, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 not turning on
hi. I suspect that you have either a dead battery or just need a reset. unplug the power cord and then remove the battery. wait two minutes and reinstall the battery.
this will reset everything. now try turning it on. if it won't come on plug in the power cord and charge the battery for 30 minutes before attempting to power up.
Jun 29, 2009 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 laptop not detecting battery
Looks to me like the battery is bad, try another battery if you can and see if the laptop charges it. If it does then the battery is bad, if it doesn't then its something with the motherboard.
May 21, 2009 | Dell Inspiron 1525 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1525 Notebook Logo
70 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
