Question about Bose Audio Players & Recorders
Amp out and amp in for bose eq.hook up - Bose Audio Players & Recorders
    Sergeant:
    Champion:
  • 232 Answers
  • 1
    Examine your receiver to be sure it has a tape monitor loop. Receivers with a tape monitor loop will have a button or switch on the front for "Tape Monitor," and have two sets of RCA connections on the back, one labelled "Tape In," and the other "Tape Out."
  • 2
    Take the two cables that are provided with the 901 speakers and insert one end of the first cable into the "Amplifier Input" jacks of the equalizer. Connect the red connector to the R input and the other connector to the L input. Connect the other end of this cable into the "Tape Out" connections on the receiver. Again, hook red to R and the other to L.
  • 3
    Connect the second cable between the "Amplifier Output" jacks of the 901 receiver and the "Tape In" connections on the receiver. Follow the guidelines in Step 2 for R and L connections.
  • 4
    Plug the 901 equalizer into a 120-volt electrical outlet. Your 901 equalizer is now installed.
  • Read more: How to Install a Bose 901 Equalizer ' eHow.com http://www.ehow.com/how_4813156_install-bose-equalizer.html#ixzz19vfsJTQu
    Posted on Jan 03, 2011
    I have a Crest Audio V900, a set of Bose 901, a Gemini EQ-3000. Do I need a PREAMP? Or can I hook up the Crest AMP to the Equalizer?
    You could use the EQ but it won;t sound as good as it will with a pre amp and also could make it a bit trickier when adjusting the volume and getting it to sound right.
    Mar 10, 2012 | Crest Audio Audio Players & Recorders
    I have bose 901 series 2 speakers, marantz 8200 and 2 marantz ma700 monoblock amps how do i hook everything up? Thankd
    Do you mean SR-8200? You can't omit the details of a model number if you want a good answer.
    Assuming it is...
    http://www.retrevo.com/support/Marantz-SR8200-Receivers-manual/id/511ci775/t/2/
    Run the 901's with the Active EQ between the receiver Front L and R Pre-Outputs and the mono block amps, one chanel to each.
    Pre Out Channel X >>> Bose EQ Amplifer IN, then Bose EQ Amplier OUT >>> Monoblock IN
    http://community.klipsch.com/forums/storage/74/1341919/200w%20mono%2005.jpg
    I can't find a manual for the MA700. Set them up to a certain volume and then use the speaker setup routines of the SR to match everything up volume-wise. Control will be in the AVR.
    Aug 22, 2011 | Bose 901 VI Main / Stereo Speaker
    I just bought used bose 901 series six speakers, hooked them up and they sound great. I was using bose bookshelf speakers before now. If I wanted to reconnect them for a home theater connection, without...
    http://worldwide.bose.com/productsupport/en_us/web/901_series6/page.html
    If your system is equipped with a tape monitor loop, you can switch the EQ out of the circuit by disengaging the tape monitor switch. If the EQ is connected to the pre-out / main-in jumper, you would have to defeat the EQ before you hook up a conventional speaker. I don't believe the EQ has a defeat switch - you'd have to rig a bypass.
    Once defeated, if you have a system equipped with a Speaker A / Speaker B selector, the smaller speakers could hook up to the second system. If that's not possible, speaker switches are available for reasonable money. It is very important, though, that the 901 EQ i defeated when using conventional loudspeakers.
    Jan 22, 2011 | Bose 901 VI Main / Stereo Speaker
    Can I hookup a Bose 901 EQ to my receiver and amp?
    Your instincts are correct. In fact, the only way the 901's can live in an A/V system is with dedicated amplification.
    Put that old amp back to work.
    This is exactly how mine are connected.
    For connection I would run a pair of RCA cables from the Front L&R Audio Line OUT to the Active EQ's Line IN; then the EQ's Line OUT to a separate amp's Line IN. Attach the 901's to the new amp, run through the receiver's setup procedures for volume, etc and you're done.
    Aug 19, 2009 | Bose 901 VI Main / Stereo Speaker
    How do i hook my bose 901 equalizer into deno
    The Bose EQ connects to the tape out and tape in on the amplifier or reciever. If you were using these for a tape deck, you will then have to connect the tape deck to the tape in and out on the Bose EQ.
    Beemer530
    Mar 22, 2009 | Bose 901 VI Main / Stereo Speaker
    Bose 901 hook up
    Assuming you really want to have a working surround system you will need a separate stereo amplifier for the 901's to accomodate the need for the Active EQ. There is no way to separate your receiver's front L&R channel preamplifiers from their amplifiers.
    I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver and the 901's amp channels. My receiver controls everything and just drives the Center and Surrounds. You would probably just get a nice 2-channel amplier for the 901's. However, the TX-SR606 doesn't provide power for a Subwoofer, should you decide to get one, so you would need another amplifier channel for that, too. Therefore, you might look around for a powerful 3- or 4-channel amplifier so you could drive the Sub, too.
    Modest amps would work but at very loud volumes may go into clipping, which is bad for any speaker. I'm using only 100W for mine and it has plenty of steam for the 901's.
    For connection I would run a pair of RCA cables from the Front L&R Audio Line OUT to the Active EQ's Line IN; then the EQ';s Line OUT to a separate amp's Line IN. Attach the 901's to the new amp, run through the receiver's setup procedures for volume, etc and you're done.
    Not what you might want to hear but 901's have special requirements. I've had mine for 25 years and have no regrets.
    A seperate subwoofer channel on the amp could be used. Just run a single RCA channel from Sub OUT to one available channel IN on the amp and attach the subwoofer to it. Two would work, also. That's what I do. You could use a 1-2 RCA splitter to feed two avaailable channels on a 4-channel amp. The iterations are many. Have fun.
    Feb 28, 2009 | Bose 901 VI Main / Stereo Speaker
    Bose 901 Active EQ Loop
    There's good news and bad news. The bad news is that a multichannel receiver with Bose 901's will only sound right in STEREO on stereo analog material. For one thing, the other speakers around the room are not designed to recieve its Active Equalization and for another, if you engage your Tape Monitor you will not be able to play digital sources. Tape Monitor is for analog stereo material only and on my receiver it disables any digital inputs.
    The good news. I have a setup similar to what I think you're trying to do and it works great!
    A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers. You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W).
    Run the dbx and BSR in tandem with each through the tape monitor loop on the receiver but be advised you can only use them on analog source stero material. However, you can still employ the various DSP options to spread the sound around the room.
    At my PC workstation across the room I have a stack of analog processors and sources including dbx 3bx-ds, dbx 120x-ds, BSR Spatial Enhancer, BBE 462 Sonic Maximizer, SS-525x EQ, Carver C-9, dbx-224x, JVC cassette deck, Dual 1249 Turntable running through a Garrard MRM-101 Preamp, Pioneer PDR-509 CD Recorder and the Media Center PC stereo analog channels all running through a dbx 400x Program Route Selector (a godsend) which is attached to my ONE TAPE MONITOR on my Pioneer VSX-36TX Receiver. Of course, I have some of my analog processors running in tandem, too, since the 224x only has three processor and three tape loops.
    For listening/recording anything 2-channel analog I engage the stack through the Tape Monitor. For everything else I turn the Tape Monitor off. The nice thing about the stack being separate is that I can doodle with recording and use headphones while the TV/DVD/Blu-Ray do something else.
    Jan 10, 2009 | Onkyo TX-SR705 Receiver
    How to hook up bose series 2 eq to onkyo tx sr 875 receiver.?
    I wrote most of this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
    There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
    The good news. I have a setup similar to what you want to do and it works great! I see on the SR875 there are Pre Audio OUTS. This is easy.
    You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
    ** Front Pre Out >>> Bose EQ Amplifer IN, then
    Bose EQ Amplier OUT >>> new amplifier IN.
    Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
    Jan 07, 2009 | Bose 901 VI Main / Stereo Speaker
    Connecting Bose 901 series iv to Harman Kardon AVR 254
    Most HK av receivers have pre amp out,power amp in with metal jumpers connecting them for the main or front channels. that would be the best place to hook up the EQ on a AV receiver. If your receiver doesn't have pre out, power in jacks , you can use tape monitor .record out playback in. The tape monitor option is best for stereo use , as the active EQ will charge all speakers in tape mode, possibly damaging other speakers.I run my 901 s with a seperate pre-amp,power-amp hooked up to my Denon AV receiver that way i can run in surround w/standard speakers
    Jan 06, 2009 | Bose 901 VI Main / Stereo Speaker
    Cannot hook eq to my receiver
    The speakers will not sound right. You dont have two tape monitors on this receiver? You can simply use the tape otput to the EQ input, and then the Tape monitor input to the EQ output leads. Good Luck
    Jun 09, 2007 | Bose 901 VI Main / Stereo Speaker
    384 people viewed this question
    Top Bose Audio Players & Recorders Experts
    Electro Med Services...
    Ben Armstrong
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
