Question about Toshiba TP55H95 55" Rear Projection Television
4 year old Toshiba 55" rear projection tv has no
  • 87 Answers
SOURCE: Blinking power button
You likely have bad convergence output IC's that have caused one of the supply fuses to blow. This repair will have to be performed by a qualified technician. If you were in our area and has us repair this the total cost of the repair would be about $340 if I am correct about the cause of your problem.
Posted on Aug 02, 2007
Slinteriors
  • 8617 Answers
SOURCE: PT-45LC12 Problem after startup
When the lamp flashes 4 times this is what the error code means IC 2301 pin 11 has detected an LCD error which is caused by an error in the LCD power CBA. which means the lamp voltage has become more than 130 volts or less than 30 volts. Or the lamp current is more than 5 amps, or the lamp is cracked. Its one of thos 3 reasons that will make the lamp indicator blink 4 times. Hope this helps. If you need the service manual for this model you can get one emailed to you from the following link.
http://servicemanuals.vstore.ca/
Posted on Mar 31, 2008
SOURCE: philips 55" tv
Yes I've had to replaced mine twice. here is the best price I found the second time I ordered it only $99.00.
http://www.intl-lighttech.com/store/item_GTL-OS-69374
Posted on Aug 31, 2008
  • 185 Answers
SOURCE: toshiba 55 inch hdtv lamp
this is a crt type tv- no lamps just crt's if it was moved recently then a seal could have been damaged on the crt cuasing coolant to leak down the neck getting into the socket. this will cause trouble for sure also could have a crack in the crt. look for a sticky liquid in the bottom of the unit.
sometime the crt's can ark and rip out a video output chip on the crt socket check it out.
not common but not unheard of.cheers
Posted on Oct 08, 2008
ginko
  • 19396 Answers
SOURCE: toshiba 50HX81 projection 'tv- blinking red light
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
Re:toshiba 55h70 tv i unplugged the tv to paint. when i plugged back in a wk later i have no picture or sound. nothing. can't access the menu - completely dark screen. the red lite "on" button...
I would check the fuse on the main board. Check the Capacitors on the Power Supply board. Seeing that you unplugged it and replugged it in you might have bad caps that were weak to begin with. Please learn how to safely work on a TV before attempting . Even when a tv is unplugged it has enough power to kill you. Discharge all Capacitors first. make sure its unplugged of course.
Jan 06, 2011 | Toshiba 55H70 55" Rear Projection...
No display or audio
I had the same problem after replacing several things and still having same problem, it ended up being a capacitor.
Jul 03, 2010 | Toshiba TP55H60 55" Rear Projection...
MY HITACHI CUT OFF YESTERDAY BY ITSELF. THEIR ARE THREE INDICATOR LIGHTS ON THE RIGHT FRONT LOWER PART OF THE TV, AND THE TOP ONE IS STAYING ON. YOU PRESS THE POWER BUTTON AND IT TRIES TO COME ON, I GUESS...
Shorted Hori ouput Transistor near FBT flyback Transfomer.Go towebsite online Encompass Parts Distr. they have listing for your Tv also have service manual,or Call 1-800-638-3328
Nov 19, 2009 | Hitachi 55FX48B 55" Rear Projection...
65" toshiba projection tv no picture but has sound..
if you could hear only sound in tv and not picture means it might be the picture tube problem just check it.
Sep 17, 2009 | Toshiba 55H70 55" Rear Projection...
Toshiba 55" TheaterWide TV powers on, then loses image
Normal repairs are 200-400 dollars service calls are75-150 depending on area and should go towards estimate but not refundable. It sounds like a problem that a tech should see first.
Apr 12, 2009 | Toshiba 55H70 55" Rear Projection...
Model 55X70 Toshiba Projection tv
dont know about warranties but horizontal lines means your horizontal frequency which runs about everything has drifted off sync and if too high or low it will activate shut down circuits in high voltage and power suppy, even causing HOT transistor to short. good luck and call a tech.
Sep 01, 2007 | Toshiba 55HX70 55" Rear Projection...
Jul 28, 2007 | Toshiba 55HX70 55" Rear Projection...
Picture shadow on rear projection Sony big screen TV
OUR TOSHIBA HAS A DOUBLE VISION/BLURRIE PICTURE. THIS PROBLEM IS ALWAYS THERE. SOMETIMES THE PICTURE IS GREAT, BUT MOST OF THE TIME ITS BLURRIE/DOUBLE. LOOKS AS IF IT ALWAYS ON 3D!! ANY SUGGESTIONS? WE WOULD REALLY APPRECIATE ANY HELP WE CAN GET FROM ANYONE. THANK YOU!
Mar 03, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba Theaterview HD 52"
I have the same tv and had it fixed the problem is most likely the power supply a $50.00 part but I suggest you have a repairman do the fix. Total cost should be around $250.00 for labor and parts.Also unplug your tv for over 4 hours then plug it back in to see if it works they call this a hard reset.If this does not work after 4 hours try unplugging it overnight and then try it. That is what I did to use the tv until I got it fixed. The only thing it could be is the convergence circuitv if this is the case it should cost about $400.00
Dec 02, 2006 | Toshiba 55H70 55" Rear Projection...
No sound or picture
Keith, Check fuses Then Resoder The COMPLETE board I bet there is heat related problem W/Old Soder Just a Hunch!!!!!!!! G'Luck Chance One 559 @ Yahoo . Com
Oct 24, 2006 | Toshiba TP55G60 55" Rear Projection...
Toshiba TP55H95 55" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
