Question about GE JVM1630 Microwave Oven
Just stopped like i unpluged the power, i checked the outlet that it is plugged to and have 120 volts on my meter, are there any fuses if so where are they
  • GE Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Jan 03, 2011
Brada microwave
please make this test and fix it. God bless you
  1. Inspect the power cord Unplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switch If your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fuses To determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motor Locate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Dec 16, 2013 | Sanyo Microwave Ovens
It wont turn on
Dec 10, 2013 | Sunbeam Microwave Ovens
I bought a mircowave and i plugged it in and it wont turn on
make this steps and fix it. God bless you
Panasonic microwave will not power on
follow this steps and fix it. God bless you
Nov 27, 2013 | Panasonic Microwave Ovens
Why does light come on, no motor or cook. Display is good
please follow this steps and fix it. God bless you
Nov 27, 2013 | Microwave Ovens
JES1290SK No motor or inside light when turned on. Display works. Light works until turning on unit.
please see the steps and fix it. God bless you
Nov 27, 2013 | GE JES1290SK 1.2 Cu. Ft. Countertop...
MICROWAVE FUSE BREAKDOWN
follow this test and fix it. God bless you
Nov 26, 2013 | Microwave Ovens
Not turn off
Nov 23, 2013 | Whirlpool MH3184XP Microwave Oven
GE Microwave (Over the Range: Model HVM1540DPBB) was stopping operation. It would beep, and the display would show garbage. I would unplug it, then plug it into the outlet, then it would display "keypad...
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Nov 02, 2013 | GE Microwave Ovens
Microwave is not getting power
may i please ask you if you have a meter? check that 120 volts is going in? check the buttons that you press. also check the fuse check the mains cable for any breaks. also you may want to test the display to see if any power going in?
Apr 07, 2009 | Maytag MMV4205 Microwave Oven
GE JVM1630 Microwave Oven Logo
51 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
