Question about Whirlpool ER6AHKXPQ Top Freezer Refrigerator
A few days before we discovered that the fridge wasn't working properly, I heard intermittent clicking sounds. The motor at the back and bottom??(not sure exactly where) of the fridge sounded like it was running, but there was no cooling going on in the fridge. I cleaned the coils at the back of the fridge and removed a couple of items that had fallen between the coils and the back of the fridge. The oil cooler was quite warm to touch.
  • 472 Answers
IF YOU HEARD THE UNIT CLICKING FROM THE BACK AND THEN A FEW MINUTES LATER DO IT AGAIN MOST likely you have a bad start relay on the compressor and the overload device on the compressor is kicking out... whirlpool is known for this particullary problem and it normally is a easy fix... go to www. repairclinic.com or apdepot.com and you should be able to enter you model number on one of those sites and your looking for the compressor relay ....
to varify it is bad and prior to buyiong pull it off should be 2 maybe three wires in some cases and shake it...if the relay rattles like something broke thats your problem.... also unplug the unit the more it trys to start with the bad relay you could eventually damage the compressor if it has not already..... good luck
Posted on Jan 03, 2011
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Try defrosting it, if this doen't work then do the following and ur problem will be solved..
BLOW AIR THROUGH THE DRIAN HOSE IN THE BACK OR BOTTOM OF THE FRIDGE FIND THE END OF THE DRAIN HOSE USE AIR COMPRESSOR .....
Goodluck,
Please don't forget to rate me as fixya..
Feb 03, 2008 | Whirlpool ET1FHTXM Top Freezer...
HELP! - My fridge freezer is not cooling - clicking sound heard but motor not coming on
Hello Michelle;
My name is Peter. I am a retired field service refrigeration technician.
Lets fix this together. The clicking sound that you hear is referred to as a overload relay. The overload relay is an electrical component that starts and stops you compressor. It is very common for the overload relay to fail over time.
First, locate and purchase a overload relay. If you have a Trible's
in your area that's great, if not Lander's, Sear's, .... If you can wait a few days you can get the part over the internet for half price or less.
I do not have your model number otherwise I would give you the part number.
Having the part, pull the refrigerator out where you can move freely behind it. Unplug the refrigerator. There is a bottom cover that you need to remove. This cover is fastened either with Philips or hex head screws. Remove the cover. Open the new overload relay parts and lay them before you. Study and observe them.
There is a black box on the side of the compressor which holds the overload relay. The box is held on with either metal or wire clips. Using a flat head screw driver pop the clips off. Compare the parts on the compressor with what you have. Note the location of the connecting components on the 3 compressor pins, and the first piece to put on the compressor is the white piece with the 'V'. Using your flat head screw driver, wedge the components off the compressor (Remember how they go back on). Do not pull on the wires - just the connector ends. Replace the components. Shake the white piece - if it rattles or is burned it is bad. If you can not get the black box cover back on - not necessary, it's a dust shield.
Note: If you have a LG, bottom freezer 599, do not bother. Both the overload relay & compressor need to be replaced. Buy new, not LG.
Oct 28, 2014 | Refrigerators
We have a Bosh KIM29473GB for some time water has been collecting in the bottom tray of the fridge and only takes a few days to fill up, this weekend the freezer stopped working and now nothing works.
If you hear a click every few minutes and a buzz / click then nothing, it would sound as if your compressor is gone, the water problem is the defrost drain pipe is blocked
Oct 06, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
I have a GE profile model # PFS22MBSAWW and about a year ago the digital display for the temperature reading would work intermittently. After some time I realized that when the condensor motor was on, the...
ou need to replace the main control board . in the back pt # wr55x10526 and you may also need the display pwb pt # wr55x10522 .. do the main board first and if diplay isn't working properly replace it also .. mm hope this helped .. feed back lps ..
Jul 10, 2011 | GE Profile Bottom-Freezer Refrigerator...
Haier hsp03wna not working
The click you heard is the thermal overload. This snaps open when the compressor is too hot.
Unplug the unit for 24 hours and don't move it.
Then plug it in and see if it comes back on temp.
Jun 02, 2009 | Haier HSP03WNA Compact Refrigerator
Whirlpool side by side, clicking noise, strange smell from bottom
The clicking is from your compressor relay on the side of the compressor it has eather went bad or a condenser fan motor is not running this will cause the walls to be warm if the fan is running in the back try cleaning the coils hope this helps
Mar 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge Problem
1. Clean the condenser coil.
2. Have the refrigerant pressure checked
3. If your refrig. has an autodefrost timer it may be failing.
4. The sealed compressor unit may be going.
hope these help
Mar 18, 2008 | Refrigerators
Own the same model, the icemaker and the dispenser work properly but the leak is top center of the refrigerator compartment.
Nov 08, 2007 | Whirlpool ET1FHTXM Top Freezer...
GE Side by Side Model: GSH25VGRECC Refrig.
I had luck with a board with a clicking relay by replacing capacitors C29 and C30, which had bulged tops. Bravo, fridge works!
Oct 18, 2007 | Refrigerators
Whirlpool ER6AHKXPQ Top Freezer Refrigerator Logo
187 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
