MY FUJITSU MODEL ASTB09LDC TIMER LIGHT IS FLSHING 5 TIMES, HAVE TURNED POWER OF TO RESET, NO LUCK.
  • 2,133 Answers
Indoor coil thermistor shorted. Replace it.
Posted on Jan 03, 2011
ASTA09JEC Fujitsu model number operation light not on but time light (red/orange) flashing turns on then turns off automatically I have tried the reset button and turned the timer off on the remote
This is a serial signal error which means the outdoor unit is not talking to the indoor unit or vice versa. Most likely the outdoor board is stuffed but you need to count how many times the timer flashes to be absolutely sure which error it is. If you turn power off at the isolator for 5 mins then restart, this can sometimes clear an error caused by power supply fluctuations. If not, you will have to replace one of the boards. Indoor board allow around $200 - $250, outdoor board allow around $300 - $400.
May 09, 2015 | Fujitsu Heating & Cooling
We have fujitsu inverter plasma airconditioner mpdelastb09ldc ths fan runs but timer light blinks 3 times but outdoor does not start
Hi Rajneel,
I hope this link is of some help to you
Good luck
http://www.climatecenter.co.uk/wcsstore/ClimateCenter/Attachment/downloads/fujitsu-trouble.pdf
Feb 10, 2015 | Fujitsu Heating & Cooling
How to turn off the timer on the Fujitsu AC Model AR-RAC3E?
Hi Rismita,
I hope the following link is helpful for you
Good luck
http://errorcodeairconditioning.blogspot.com.au/2010/10/fujitsu-air-conditioner-error-codes.html
Jan 18, 2015 | Fujitsu Heating & Cooling
Fujitsu airon ASTA24LCC 2 flashes green and red then 5 red flashes any idea what it means
Had similar problem (ie. 2 green & red flashed followed by 5 red flashes - Fan blowing but not cooling ... I also noted that the outside unit fan wasn't going). Tried restarting several time after waiting only a minute or two after turning the mains power off but with no change. So turned the unit off at the mains power and then fired it up about 2hrs later and it was all working fine.
Jan 24, 2013 | Fujitsu 24C1 Air Conditioner
The timer light flshing
That means, you have set atimer on and or off. To reset it, remove battery from remote and power off to the unit. Now reset it.
Dec 16, 2010 | Fujitsu Heating & Cooling
Could you please advise how to reset lamp timer on a fujitsu LPF 4800 when I turn it on the green light goes to red and the lamp light indicator goes to red too and blinks
hi
You can reset the lamb timer as follows.
While pressing the MODE button, press the POWER button three times.
all the monitors flashes for a few second , The lamp timer is initialized to[ 0 hours] .
ok
Dec 15, 2010 | Fujitsu LPF 4800 Multimedia Projector
After a power failrue . my 65" Mitsubishi keeps flshing green light. I cannot turn it on. Reset couple times, did not help.
Replace the DM capacitors. That will often happen after a power failure, as the capacitors will be bad and the set will continue to operate fine untill the power is lost, then they can no longer charge due to their being weak so the timer led will blink repeatedly because the DM cannot complete the boot sequence untill the capacitors charge.
Jan 22, 2010 | Mitsubishi WS-65712 65" Rear Projection...
Manual for Fujitsu plasma inverter Model ASTB09LDC
Fujitsu Plasma ASTB09LDC, has the operation and timer leds flash 4 times then the timer led flashes 3 times then cycle repeats. What does this mean?
Jul 28, 2009 | Fujitsu Heating & Cooling
Heating & Cooling Logo
130 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
