Question about Panasonic Microwave Ovens
Panasonic nn-sd277s over the range microwave. only 1.5years old, dead for the second time. first time, the tech said they replaced the inverter. I would think its the fuse only. how can i find the fuse on this thing. Can someone help please.
  • Panasonic Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Jan 03, 2011
My Panasonic NN-T994 Microwave oven died today. Would run for a few seconds with a clicking sound and an electrical smell. I removed the cover, restarted and found arcing from the area of what I think is...
From your description it does indicate a magnetron problem, you would be further ahead replacing the microwave oven when you consider the expense of the repair involved.
Feb 23, 2011 | Panasonic NN-T994SF Microwave Oven
I have a Panasonic NN-SD277S Microwave Oven Initially, it shut itself off after about 3 secs - this continued time after time - then I held the start button down and it shut down completely, almost as if...
I have an Amana Radar range and it did things similar to that. I finally figured it was the circuit board of the buttons and was lucky enough to find another one and replace it..
Jan 26, 2018 | Microwave Ovens
6 year old Panasonic 1250W High Power Inverter Microwave Oven (Model NN-S954WF) Manufactured May 2004 has completely died. Wondering what might be the problem and is it fixable or should we just get a...
These early inverter microwaves blew their high current power transistors quite regularly. These high current power transistors are quite expensive to replace, and if one blows, there is a likelyhood of others blowing. As the microwave is over 13 years old, I'd suggest getting a new one. Inverter technology in microwaves is now a mature technology, resulting in reasonable prices and much improved reliability.
Nov 12, 2017 | Panasonic NN-S954WF Microwave Oven
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
Panasonic Inverter Microwave, NN-H665BF, Smoking Issue
The magnatron is covered by warranty for 5 years and I just spoke with an authorized Panasonic repair center who said the inverter is covered on this unit depending on the manufacture date, like april 04 to october 05 approximately.
Jan 21, 2009 | Panasonic NN-P294SF Microwave Oven
Microwave cut off
the main control board is "seeingf" a high amprage draw from the inverter board . you have a problem with the inverter or the magntron . parts are more than a new unit . try to stay away from the inverter type , there just not ready for prime time . google "panasonic inverter reviews " and you will see just common your problem is good luck
Jan 16, 2009 | Panasonic NN-S753 Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Panasonic NN- A712 combination Microwave 1000w - Switches off after 20 seconds
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 14, 2008 | Panasonic NN-S753 Microwave Oven
Microwave shuts off after 3 seconds
Although your model number doesn't seem to show up, the NNS950-series units are powered by an high-voltage inverter. And yours has failed. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Sometimes a whole new inverter is cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized appliance / microwave repair shops and ask then specifically about inverter component-level repair and simple inverter replacement costs for your exact model number.
Dec 26, 2006 | Panasonic NN-S950WA Microwave Oven
Microwave runs for 3 seconds and shuts off
This is an inverter-driven model, and this is one way the inverter fails. Often it will tick, too, but the cooling fan may be too loud to hear ticking. If you haven't had smoke, then it may not yet catastrophic. I would bet that a thorough resoldering would take care of it. A good technician can troubleshoot and repair this, as needed, but often they will just replace the inverter. Sometimes that's actually cheaper. Troubleshooting an inverter is way too much for someone without good solid technical experience. I would call a shop and ask for an estimate to replace the inverter. Good luck.
Oct 13, 2006 | Panasonic NN-S252WF Microwave Oven
Microwave Ovens Logo
336 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
