Question about Nespresso Aeroccino Automatic Milk Frother
Hi! I cannot start my Aeroccino. There is definitely not a problem with my outlet. Not sure if the base is getting power, but whatever it is it is not working. The green light is not turning on. Help! I miss my wonderful warm milk!
  • emilyhellstr Jan 07, 2011
    Hi, the post from before was about Espresso machines. I need help for my Aerocino milk frother which is not working at all.
    Emily
    But it's not a foamer on an espresso machine. It is a separate machine which foams milk in a separate pot. The moving piece is totally clean and there is nothing to become clogged since it is self contained.
SOURCE: My Aeroccino keeps overflowing even though the
I am having the same problem but not every time. I went back to where I bought it and spoke with one of the reps and was told that if there is moisture under the rubber seal on the lid this will happen. To solve this I remove the rubber seal and clean it and dry it off after I am done using it. Also turn the lid over on top when not in use. Hope this helps.
Posted on Mar 07, 2010
  • 21 Answers
SOURCE: nespresso aeroccino doesn't work after milk was
The company will tell you to turn upside down for 24 hours to reset. I did and this did not work, you may have gotten base wet, which can break machine. Try turning upside for aeroccino upside down for 24 hr. you do not need to do this to the base. They told me if this does not work, I need to buy a new one. I hope you have better luck.
Posted on May 08, 2010
SOURCE: Lost my Nespresso Aeroccino Milk Frother Hot Milk Whisk
Call Nespresso customer service at 800-562-1465. Replacement set of 2 wisks were $2.95 + shipping
Posted on Jul 01, 2010
SOURCE: Where can I find a
Contact the Nespresso Club at 800.562.1465. The replacement frothing/steaming whisk set, item number 13192/6, is currently available for sale at $2.95. .Shipping is flat fee of $6.95
Posted on Dec 03, 2010
SOURCE: Burnt Milk at Bottom of Aeroccino
Try this - make a paste from bicarbonate of soda and water and let it
sit in the bottom of the frother for ten minutes or so. Then use a sponge
to clean off the milk stain and rinse and dry thoroughly. To prevent it from
recurring, rinse and dry the inside after each use and don't get the base
of the frother wet.
Posted on Dec 12, 2010
Just purchased Model LD651EBL - 65 pints. Followed instructions to operate/start but it will not start. Checked breakers and tried alternative plugs. Seems to be no power. What should I do?
Make sure the bucket is installed properly. It you are CERTAIN it is installed properly and you still get no power to the unit (you said you definitely have power at the wall outlet) return it to the store and either get it demo'd or replaced. Definitely rule out the wall outlet by testig with a light or a radio before you load the unit into the car.
Any more than what I have suggested may void any warranty you may be entitled to. Don"t wait.
Thank you for your question @ FixYa.com
Aug 15, 2011 | LG Dehumidifiers
My aeroccinno just won't turn on... I took the base apart & cleaned it, but no luck.
After being sure that the inside is thoroughly cleaned (We use a slightly abrasive sponge with plenty of elbow gerase.), dry by hand and let it air dry for 72 hours upside down. Keep the base unplugged during this time. When using in the future, clean throoughly after each use, unplug the base and dry the pitcher upside down.
Mar 30, 2011 | Nespresso Aeroccino Automatic Milk Frother
"mixer" in cover does not
Nespresso stated in the past that perhaps moisture (water) had gotten into the bottom of the frother and that might have been the reason it had stopped working.Try turning upside for aeroccino upside down for 24 hr. you do not need to do this to the base
Aeroccino jug being stored on the Base. The base does not have an on/off switch; therefore it is drawing full power at all times when plugged-in. If the Aeroccino jug is stored on a plugged-in base it can short-circuit. Once this has occurred there is no troubleshooting that will alleviate the issue, and replacement is the only option.Don't leave the base plugged-in when not using the unit.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Feb 09, 2011 | Nespresso Aeroccino Automatic Milk Frother
Nespresso aeroccino doesn't work after milk was overflowing. Is there some kind of security which can be resetted?
Apr 12, 2010 | Nespresso Aeroccino Automatic Milk Frother
Panasonic KXTG2344 Phone 2,4ghz malfunction with microwave
You can change the channel used by the phone in the settings, but the better option is to make sure the charger base is nowhere near the microware.
Also, make sure that the microwave and the charger base are NOT plugged into the same outlet. I would even try a different outlet than you are using now as interference would definitely pass through the line.
Dec 02, 2009 | Panasonic KXTG2344 Cordless Phone
Frother not turning on though there is power to the base
just wanted to comment on the issue with the Aeroccino when it stops working. As has been mentioned, Nespresso stated in the past that perhaps moisture (water) had gotten into the bottom of the frother and that might have been the reason it had stoped working. This was not my problem---I was very diligent in preventing ANY moisture entering the unit. But Nespresso has finally acknowledged the real issue. This is Nespresso's partial reply to my query: "Another possible cause for the Aeroccino to not turn on is the result of the Aeroccino jug being stored on the Base. The base does not have an on/off switch; therefore it is drawing full power at all times when plugged-in. If the Aeroccino jug is stored on a plugged-in base it can short-circuit. Once this has occurred there is no troubleshooting that will alleviate the issue, and replacement is the only option." There you have it. Mine would turn on for a several seconds, and merely warm the milk, instead of frothing it. I guess it took us 9 months to short-circuit it. Luckily ours is still under warranty, so a replacement is being shipped. Good luck to all of you with the same problem...I hope you are still under warranty. For those of you with a working Aeroccino: Don't leave the base plugged-in when not using the unit.
Dec 09, 2008 | Nespresso Aeroccino Automatic Milk Frother
Nepresso aeroccino doesn't spin fast enough to froth the milk
The company will tell you to turn upside down for 24 hours to reset. I did this but it did not work. Try turning upside for aeroccino upside down for 24 hr. You do not need to do this to the base. They told me if this does not work, I need to buy a new one. I hope you have better luck. I am on my third one. you may be covered under warranty- call Nepresso soon..they cover them for about 1 year. Good luck
Nov 30, 2008 | Nespresso Aeroccino Automatic Milk Frother
I have an Nespresso Aeroccino that will not make froth
Sorry, but it looks as though you have the classic Aeroccino-problem. Nespresso states that leaving the Aeroccino on its base while it is plugged-in to the wall, will cause it to short-circuit (because there is no off-switch on the base, it is continually feeding full power to the frother), and the result is that it makes only warm milk. Replacement is the only solution...I hope you are still under warranty.
Jul 28, 2008 | Nespresso Aeroccino Automatic Milk Frother
Not making froth
Had the same problem, but called Nespresso. Their tech suggested the following: 1) always leave off the base - will stay on even if button not pressed 2) invert the Aerocinno for 24-48 hours to "reset" the thermostat in the device. I began leaving the base plugged in, but immediately after using and cleaning (don't get ANY water in the bottom of the machine!), I invert the Aeroccino and leave it that way. My machine began making great froth with any tyoe of milk, and continues to do so a month later -
Sounded crazy to me initially, but it works.....Never returned the device, and no need to do so now - Good luck!
Jan 05, 2008 | Nespresso Aeroccino Automatic Milk Frother
On/off problems
Found out if you just leave it for 30 seconds after turning the power on but before activating it works fine.
Dec 16, 2007 | Nespresso Aeroccino Automatic Milk Frother
Nespresso Aeroccino Automatic Milk Frother Logo
171 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
