Question about Vivitar ViviCam 8400 Digital Camera
Card Error After coming back off holiday my Vivicam 8400 is displaying "Card Error2 on the LCD screen. When i remove my SD Card and put it into my card reader it asks me if i want to format. Is there any way i can recover my pictures please?
  • V Halla Jul 09, 2008
    I tried both software that you suggested but could not recover anything. Thanks for you help in this matter.
    President:
  • 1,114 Answers
First do not panic! It is possible to recover your pictures if you take care. Take the card from the camera (powered off) and if it has a "write protect" tab then lock it now. Do not try and write anything to the card or you risk causing more problems.
If you are comfortable with using a PC then you can download a FREE utility that will recover your photos from the following link:
http://www.cgsecurity.org/wiki/PhotoRec
If you need something a little more "user friendly" then you will need to buy the software. If you search the web for photo recovery software you will find many.
One I have used successfully is RescuePro that used to be bundled with some Sandisk products. Now you can get it from the link below:
http://www.lc-tech.com/software/prwindetail.html.
You can try the demo to see what you can recover before buying.
Remember - Do NOT try & write anything back to the card until you can recover your pictures to your PC safely!
Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Jul 09, 2008
Can i use any sd card in my vivicam 8400 camera
Yes, you may use any SD card. Make sure it's an SD card and not an SDHC card.
Dec 29, 2012 | Vivitar ViviCam 8400 Digital Camera
I bought a new SD card and put it in and the screen display keeps sayd SD card error. Please help.
If you're using an SDHC memory card, the camera doesn't support it according to the specs. If it's the correct card, try another one - you may have a bad one.
Feb 15, 2011 | Vivitar ViviCam 3746 Digital Camera
My vivicam 8225 keeps saying 'card full' when you
the card reader of the camera is defective,so get it repaired or replaced.
Mar 06, 2010 | Vivitar Vivicam 8225 Digital Camera
Cannot download pic.s from camers to pc.
I would remove the memory card and use that to transfer the media to your pc.... I can't tell you why it is not showing up on any of the pc's. The only thing I can think of is possibly the usb cord is bad or that vivicam has special software you need to download. But you can definately get the media onto to your pc by bypassing the usb cord and remove the media from the card and place it in a folder on your pc .. hope this helps... good luck
Oct 19, 2009 | Cameras
I bought a 4GB Kodax memory card for my vivitar digital camera and it's not working. It said card error.
Check the little tab on the side of the SD card to make sure it is not locked. If that doesn't do it, take the batteries and SD card out, wait 30 seconds, then re-insert the batteries and SD card. If all else fails, read the manual on how to format (or reformat) an SD card. In either case an pictures stored on the card will be lost.
Jul 14, 2009 | Vivitar ViviCam 8400 Digital Camera
Cd for vivicam 8400 ruined
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program, such as Picasa.
Jun 21, 2009 | Vivitar ViviCam 8400 Digital Camera
Unable to download pictures from a Vivicam 6200w
I have he same problem with the vivicam 6200W as well. The only solution is to remove the card from the camera and use a SD card reader to read it to the computer. The included driver in the CD ROM will not allow direct access to an installed SD card. Removing the SD memory card will allow you to access the camera memory itself.
The better solution is to cluck the camera away and never ever buy a vivitar again. Get a FUJI or cannon with an underwater water casing.
Jan 13, 2009 | Vivitar ViviCam 6200w Digital Camera
Unable to transfer pictures to Computer.
I believe you can do that, it should not be a problem ( moving your sd card to another camera). Worst case scenario, you would have to go buy an sd card reader ( pretty cheap, probably won't have to spend more than $50 for it, not even that) and take the sd card out and put it in the reader and download from there. Good Luck!
Sep 15, 2008 | Vivitar ViviCam 4100 Digital Camera
Card
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 31, 2008 | Vivitar ViviCam 8400 Digital Camera
Formatting SD card
Possibly either- or Take it back to the shop and ask them to check by inserting another card or card into another camera Get which ever it is play up replaced
Sep 04, 2007 | Vivitar ViviCam 3730 Digital Camera
Vivitar ViviCam 8400 Digital Camera Logo
41 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
