Question about HP Officejet Pro L7680 All-In-One Printer
A piece of is jammed. WHEN i TRY TO REMOVE IT FROM THE BACK the page rippes on one corner. This happened 3 times already
  • hain_uwe Jan 03, 2011
    Thank you,
    I guess that is the answer I saw also somewhere on the web (HP??).Your answer does not address
    ? I cannot grab the remaining paper. It is in the machine and I can see the paper but not grab it.
    ? why does it happen 3 times in a row
    Might there be another problem?; if so what.
    Is there another entry into the machine to remove paper menants?
    Thnaks gain NinaE,
    the card solution sounded like a neat idea. I was able to push it through afew times.But it did not push remaining paper fitzels through. They still must be somewhere in the machine as the "jammed "message still comes up.
    As to the paper it is Hammermill and we had used a few boxes without problem already..
    Is there no other way to access the paper trail (without getting electrocuted. The back door is just too small to get ionto the small holes.
    President:
  • 3,278 Answers
Hello.
To clear a paper jam, lift the output tray and pull any jammed sheets out toward you with both hands. If the jam is not there, check the document feeder on top of the printer; lift the cover and pull any paper clear. Clear jams in the internal rollers by removing the rear access panel and pulling any jammed paper/pieces firmly out of the rollers.
Hope this helps.
Posted on Jan 03, 2011
  • NinaE Jan 03, 2011
    Give this a try to remove the paper pieces: Manually push through a sheet of heavy A4 card all the way through backwards and forwards.
    I would suggest using a better quality of paper to possibly reduce problems in the future.
    See if this helps (from HP Support):
    Required
    Tools:
    (2) Medium sized paper clips
    Preferable Tools:
    (1) Pair
    of pliers with rubber grips
    (1) Edged tool such as wall paper knife, metal
    pick or toothpick to clean out gear teeth.
    This fix applies to paper
    jams the device believes are in the rear duplexer and often occurs after a real
    jam that has shredded the paper inside the mechanism.
    Despite the fact
    you've carefully cleaned out all the visible paper from inside with the cover
    open, paper can jam the gears used to drive the rear rollers and even the
    tiniest amount of shred prevents operation resulting in the impossible Paper Jam
    error.
    After
    removing the duplexer, grip any of the four rubber rollers and attempt to rotate
    in either direction, if they don't move freely with little effort, then continue
    with these instructions.
    Begin:
    1. Take the first paper clip and
    contact the lower two brass rectangles, this fools the device into believing the
    duplexer is installed, keep the contacts bridged (don't remove your hand or the
    paper clip until Step 4.) THERE IS NO ELECTROCUTION RISK.
    2. Press the "OK"
    button on the control panel to pretend the paper jam is cleared.
    3. CAREFULLY
    OBSERVE THE pair of white gears on the left, if they seem to clutch, stall, skip
    or freeze then you have paper shards which are causing the jam.
    4. Using a
    firmer grip or pliers, grip the furthest left rubber roller and rotate in either
    direction , the gears should rotate with your efforts and look for shards of
    paper in the gear teeth.
    5. Use the paper clip, toothpick or any appropriate
    edged tool to clear the shards.
    Bridge the lower contacts again and
    observe if the gears rotate freely, if so then you've cleared the jam
    should be able to print.
Epson xp430 paper jam, but I can't find any jam!
They don't tell lies :>) Even the smallest piece of paper over the sensor will record a jam. This often happens when you have a jam and you pull the paper and it tears a piece off. Open all the doors, remove the paper tray, remove all the toner or cartridges and look with a flashlight. Always pull paper jam paper in the direction it was going, undo tensioner clips if present and pull paper evenly and slowly as not to tear the paper. If you do, keep the paper and find the piece that fits the piece that is missing.
Having said that, see the link
Paper Jam Problems - Epson XP-430 User Manual [Page 234]
https://www.manualslib.com > ... > Epson Manuals > Printer > XP-430 > User manual
Epson XP-430 Manual Online: Paper Jam Problems. If you have problems with paper jams, try these solutions: 1. Cancel the print job from your computer, if...
SOLVED: Error says paper jam, but there is not. What could cause this ...
https://www.ifixit.com/.../Error+says+paper+jam%2C+but+there+is+not.+What+could... Dec 18, 2013 - I have an Epson Artisan 837 all in one. It was working perfectly fine yesterday. Today it is telling me I have a paper jam. I went through the steps ...
How to solve paper jam or paper feed error DO IT YOURSELF ...
? 3:43
https://www.youtube.com/watch?v=kHHpVcSJvvA
Aug 16, 2016 - Uploaded by Easyprint-DZ Support
... of commons problem of printer . paper feed error or paper jam error. ... we gonna work on epson ...
Paper Does Not Feed Correctly - Epson
https://files.support.epson.com/htmldocs/pho22_/pho22_rf/trble_4.htm Paper does not feed. Multiple pages feed. The paper jams. Paper is not ejected fully or is wrinkled. Paper does not feed correctly when using the double-sided ...
Epson XP-430 ' XP Series ' All-In-Ones ' Printers ' Support ' Epson US
https://epson.com/faq/SPT_C11CE59201~faq-293729 Mar 24, 2016 - If paper jams when you load only one or two sheets, try loading more sheets at a time. Do not load more than the recommended number of ...
Epson xp430 paper jam Google Search
Oct 23, 2017 | Epson Office Equipment & Supplies
Printer jams only when I put paper into the tray, and not when I feed the paper manually
in your paper feed tray there is a paper separation pad which is setup on a spring.just scratch it with some fine sand paper and clean with IP solution.
May 27, 2012 | Brother HL-2040 Laser Printer
Unable to print or delete a document
  • 1
    Remove the cartridges from the F380 printer.
  • 2
    Position the cartridges so they are right side up and the gold leads are facing you.
  • 3
    Place a small piece of tape over the gold contact in the top left corner of each cartridge.
  • 4
    Place the cartridge back in the F380 printer. The printer automatically prints an alignment page.
  • 5
    Remove the cartridges. Place a piece of tape over the gold contact in the top right corner of each cartridge.
  • 6
    Place the cartridges back into the F380 printer. The F380 prints another alignment page.
  • 7
    Remove the cartridges from the printer. Remove both pieces of tape from each cartridge.
  • 8
    Insert the cartridges into the F380 printer. The printer prints a cartridge alignment page. Each cartridge is now recognized as a full ink cartridge.
  • Jun 16, 2011 | HP DeskJet F380 All-In-One Printer
    A paper jam message continues no paper in machine. started when printing an alignment page after new cartridge.
    Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
    First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
    If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
    Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    Feb 07, 2010 | Office Equipment & Supplies
    Brother 2920 Fax Machine keeps jamming every few pages
    Please try this and let me know how it goes
    1. Turn off the printer.
    2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
    3. Also open the back cover of the printer if this model has one.
    4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
    5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
    6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
    7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
    8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
    9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
    10. see alternative if the problem is still not solved.
    alternative :
    Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
    Jun 09, 2009 | Brother IntelliFAX 2920 Plain Paper Laser...
    HP Photosmart C6280 paper jam--won't print (of course), message reads 'add paper to main tray'
    Please try this to clear the paper jam
    alternative :
    Jun 09, 2009 | HP Photosmart C6280 Printer
    Paper jam notification after printing one page, no paper jam
    try this
    alternative :
    Nov 16, 2008 | HP PSC 2210 All-In-One InkJet Printer
    Paper Jam
    try this
    alternative :
    Sep 21, 2008 | HP OfficeJet 4315 All-In-One InkJet...
    Hp psc 1315 paper jam
    . Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
    2.
    Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
    3.
    Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
    4.
    Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
    5.
    Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
    6.
    Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
    7.
    Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
    Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
    Persistent paper jam message
    In response to a question by Fixya. I solved it by searching throgh all references to paper jams on Fixya. I found a solution which I have already described. This is a very helpful site.
    Feb 27, 2008 | OKI B4100 Laser Printer
    HP Officejet Pro L7680 All-In-One Printer Logo
    43 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
