Question about Zanussi ZMC30STQX Convection Microwave Oven
I have a Zanussi ZMC30STQZ microwave. When on the Microwave function it sparks behind the closure, however, when I remove the top closure it stops sparking- I can see a round metal piece glow red hot though that is situated behind the top closure. Regards Graham
How to uninstall an over the range Jenn-air microwave JMV8166BA
Remove two phillips screws from each side of the microwave. One at the very top and one at the very bottom. Remove the front cover. There will be a couple of other screws and metal stops under the microwave that will need to be removed also. After that, the back of the microwave will need to lifted and move forward just a bit to release the back. Pull the microwave forward and toward the left side, enough to be able to reach behind the right side of the oven and unplug the microwave. Remove the microwave. To reinstall, just reverse these steps. It might help to use a mirror and check out the 110v 60Hz socket in the top right corner of the oven that you will need to plug the microwave back into when you replace it.
Jul 17, 2014 | Jenn-Air JMV8166B 950 Watts Convection /...
Bulb ZMD30STQX change
Some microwaves have a small square door on the left side, some clip shut, or screw removal. If not! you will need to remove the top "unplug first" bulb is located on the side or back.
Mar 15, 2012 | Zanussi ZMD30STQX 900 Watts Microwave Oven
Panel problem
Hello
Unplug the microwave from the wall outlet prior to disassembling.
Open the microwave door. Remove the screws securing the grill above the door opening to the microwave. Remove the grill.
Remove the screw located at the top of the control panel, which is now visible with the grill removed.
Lift the control panel up to release the tabs securing it in place. Move it away from the microwave.
Look at the rear of the control panel to any disconnected wires that may have caused the control panel to stop functioning. If wires are disconnected, reconnect them, reassemble the microwave and determine if the problem is still occurring. If the problem still occurs, replace the control panel.
Transfer the wires from the old control panel to the new control panel.
Move the panel back against the microwave's control panel housing. Slide it down to lock it into position.
Install the screw at the top of the control panel.
Replace the grill on the top of the microwave. Secure it using the screws that were removed.
Restore power to the microwave.
Oct 04, 2011 | Panasonic Microwave Ovens
I have chefmate microwave and suddenly stopped working. it is showing 2:50 code on the screen only...it was working fine and dont know what happened to it and touch pad is not working..how do i make it...
HELLO.
The code on the screen indicate electric panel fault resulting from the touchpad malfunction.
The touch pad on your microwave oven acts as the brain of the appliance. It not only contains the buttons that you use to enter cooking settings and times, but also controls the function of the entire microwave. If the touch pad malfunctions or breaks completely, the microwave will cease to function. In this instance, the broken touch pad must be removed and a new touch pad must be installed, to restore functionality to the microwave.
1 Unplug the microwave from the wall outlet.
2 Remove the two screws, located on the front or top of the grill at the top of the microwave.
3 Pull the grill off of the microwave.
4 Remove the mounting screw from the top of the control panel.
5 Lift the control panel up and out to loosen. Look behind the control panel to ensure there are no metal tabs securing the control panel in place. If there are metal tabs, gently rotate the control panel to free the tabs.
6 Transfer the wires from the old control panel to the new control panel one at a time to ensure that the wires are properly installed.
7 Install the new control panel into the microwave and secure using the mounting screw that was removed.
8 Replace the grill from the top of the microwave and secure it using the screws that were removed.
9 Plug the microwave back into the wall outlet.
Thanks.
Sep 12, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
During cooking last night - (about 20 seconds into cooking a piece of fish on a microwave safe plate), it sparked, banged and quit working. Control panel is out. Can this be fixed, or should I purchase a...
I worked for a place that repairs appliances and rule of thumb is if a microwave sparks dont bother trying to fix it just replace it.Microwaves work with so many watts sparks could mean a resister is shot witch could be very dangerous and if it stopped functioning thats probably the case.
Jul 17, 2011 | Whirlpool MH1160XS Convection/Microwave...
Have a ge microwave jes1289sk01 and it is sparking from behind the small fiberboard just inside the right side of the interior of unit. I removed fiberboard and sparking stopped. Unit still heats. do I...
That small card prevents food particles from entering Magnatron but allows RF energy to pass through. The corrosion mentioned is the result of the arcing. Just replace that protector. It will be specific to that brand and model.
Nov 14, 2017 | Microwave Ovens
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
I have a Ge jvm1790sk and while the microwave is running there is no internal light how do I replace it?
Unplug unit before entering.
The light bulb is behind the air vent at the center top of the microwave. Remove two screws at the very top front of the microwave and pull the vent cover forward at the top. Sliding left is sometimes necessary to release the bottom tabs of the vent cover. The light fixture will be behind this cover.
Good Luck. Reverse the above process to reassemble.
Sep 06, 2009 | GE JVM1790 1000 Watts Convection /...
How do i change the lightbulb in my Zanussi ZCM32T Combination Oven
hi
two VERY important things... first, turn off the breaker (power) to the unit, and second, do NOT touch the bulb with your bare hands (use thin gloves or rubber gloves), you don't want to get any thing on the bulb, like grease. I don't know this exact model but, to remove the bulb, there should be a grill on top of the microwave, take that off and there should be a panel above the bulb inside, remove that and you should be able to reach the bulb now.
Mar 21, 2008 | Microwave Ovens
Zanussi ZMC30STQX Convection Microwave Oven Logo
Top Zanussi Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Zanussi Microwave Oven Expert? Answer questions, earn points and help others
