Question about Qualcomm GSP-1600 Cellular Phone
Having car kit mic problems. when phone not plugged into car kit all is good. when plugged into car kit the 1600 can hear person called, but person called cant hear the person on the satellite phone. we have tried cleaning the connections, checked wires, etc. wont work on boom mic or handset. we have tried unhooking the handset and using just the mic and the speaker, no luck. we have tyried unhooking the mic and the speaker and using the hand set, no luck.
Nokia 1600 i can hera the calling/ called party but they cannot hear me
You just need to follow this step.
* Your mobile as some problem with it.
* You just need to change the MIC of your mobile.
* For that you need to contact you are nearest nokia service center.
* There they will take few minutes to change the mic.
* After getting repaired check once.
If you are satisfied with my answer then rate me.Thanks for your question.
Jun 25, 2011 | Nokia 1600 Cellular Phone
Whenever i make calls from my mobile . The person whom i have called or the person who called cant hear my voice . But i can hear their voice . Kindly help me out
Its an mic problem once check with voice recorder. Record a sound and playback if no sound surely its a mic problem
Feb 28, 2011 | Cell Phones
When I make calls or get calls I can hear the other person but they cannot hear me.
hello sir,
it seems to be problem in your mic of your phone.
replace a new mic in your phone by contacting the customer care of your mobile dealer.
they will replace an exact mic for your phone.
then your problem gets solved.
have a nice day
thank you
Jan 01, 2011 | Sony Ericsson XPERIA X10 Cell Phone
When i make or get call I can hear them but they can't hear me. I get this yellow swiggly object on my screen.
There is some problem with your phone mic only.please use your headset to check it.Connect your headset and answer phone with your headset.If the person don other side hear you then the problem is with the mic only.Please take the mobile to NOKIA CARE centre and they will repair the mic.
The yellow colour swiggly object which comes next to the battery bar is nothing unusual.It shows that your call is been connected with the person on other side.This symbol will not appear when the other person's phone is ringing,When the person picks up the phone this yellow colour symbol will apear.]
Thank You
Thank You
Aug 12, 2010 | Nokia 6300 Cellular Phone
Called person unable to hear me
the microphone in your phone has probablt gone bad, check to make sure it is not plugged with dirt; if not have it checked out at your carrier
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
May 16, 2010 | Samsung SPH-A660 Cellular Phone
I ca n hear the person i called or called me but they cant hear me
the mic contact point in your phone is the problemarea. just open ur phone and re solder the mic point and the problem will b resolved
Apr 17, 2010 | Innovage Touch-panel Phone 1502084
The other person can't hear me
the problem is of ur mic u can get it done through mobile repair shop...
Sep 09, 2009 | LG KG800 Cellular Phone
Can't hear
Can you dissambling your phone? if you can doit , please check the MIC part.
1. Sometime the MIC connector doesn't contact well with the phone PCB.
2. Chekc the mic part to sure if that thing work well with Multitester, if the mic not in good condition, please change that part.
3. Otherwise... If the mic and it connector work well, i think the AUDIO IC is in bad condition. Try to change that part.
But if you cant do or dont have any experience to disamble or fixing the phone by your self, I suggest you have to go to Cellphone Rapair Shop nearest your place.
I hope it can help your problem.
br
Aug 05, 2008 | Pantech Duo Smartphone
Motorola v3i mic problem
your head unit probably does not have a mic you have to get one for the radio not the phone
May 22, 2008 | Motorola Mobility V551
Dropped cell and people cant hear me
I had the same problem as the person in the original posting -- I dropped my phone after which callers could no longer here me.  So I tried dropping the phone again, as the original poster suggested, and afterwards the problem was solved.
Nov 19, 2007 | LG VERIZON VX5200 Hands-Free Headset...
Qualcomm GSP-1600 Cellular Phone Logo
42 people viewed this question
Top Qualcomm Cell Phones Experts
William Alequin
Are you a Qualcomm Cell Phone Expert? Answer questions, earn points and help others
