Question about Hoover Refrigerators
Water is leaking out of the bottom of the interior of our Contour Refrigerator.(HE430TF) It does not appear to be flowing into the defrost overflow tray. I have poked a piece of fexible plastic up the pipe up the back of the fridge but this does not appear to have fixed the problem. there is water at the babe of the internal columm at the opening at its base. thanks Richard
    Sergeant:
  • 225 Answers
Hi Richard,
I don't have any knowledge of your particular model but on mine the water condenses on the cold plate in the fridge compartment and then drips down into a little channel. From there it goes down through a fairly small tube which opens onto a little dish formed on the top of the compressor unit. This unit is warm when running, and the water is supposed to evaporate away into the room.
If water is collecting on the floor of the fridge compartment it is almost certainly due to a blocked drain pipe. If the drainage channel has become cracked this might be another cause of your problem.
One way to check that the drainage pipe is clear is to blow up it (not blow it up !) but that is a pretty yucky job. Alternatively you could pour a little hot water with dishwashing detergent dissolved in it into the drainage channel and check that it comes out onto the compressor top.
I hope this helps, but if not please defer a rating until we have had another think about it. Cheers, D.
Posted on Jul 09, 2008
I've had the refregerator for 10 months.. All of a sudden water is appearing on the floor next to the refrigerator. Where could it be leaking from?
Pull it forward and seei if the drain pan is either overflowing or empty. If it,s empty, check the drain isn't blocked, causing meltwater to leak from inside. If it's overflowing, check the door seals properly and the defrost settings are ok.
May 22, 2012 | Samsung RFG297HDRS 29.0 CuFt French Door...
Hoover Contour refrigerator HE383TF. Water is leaking inside the fridge. It appears as a puddle under the vegetable compartment and then leaks onto the floor. I have completely defrosted and then poured...
Could be the little red stopper at the back of the fridge on the inside has come off, and this is where the water is coming from, look inside on the lower shelf and you will see a round opening which should have a red stopper in it.
Dec 30, 2010 | Hoover Refrigerators
I have whirlpool 220 classic refrigerator for last two week we find water outside front door of the refrigerator or below vegetable box . what is the problem
It can be due to an overflow of the drain tank that is at the rear bottom wherein when the defrost timer works , the frost condenses down to this tank.
It can also be a leak in the pipe line to the tank that causes the water to flow out.
It can be due to condensation within the door side that is flowing out., or even the collection tray leaking over , crust of frost falling out of the tray.
Oct 05, 2010 | Whirlpool Refrigerators
Frig leaking from the bottom, a slow leak.
Most likely defrost water not evaporating and running over drip pan onto lloor.
Check the bottom coils... Dirty coils can block air flow and prevent defrost water evaporation. Also check fan. Air pulled across defrost water evaporates it. If fan is not running, refrigerator will also be inefficient, as refrigerant condenser needs air flow over the coils to work properly.
Jun 15, 2010 | KitchenAid (KSRD22FKST) Side by Side...
We have a leak inside of the refrigerator. Water
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website). If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction. Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
Mar 20, 2010 | Refrigerators
It is leaking water and the bottom of the refrigerator has water
Is water leaking OUTSIDE your refrigerator or INSIDE at the bottom of your refrigerator ? If it is inside your refrigerator the most common reason is a clogged defrost drain tube - The water collects from a defrost cycle and drains through a hole on the ceiling of your refrigerator into a cup that drains it through the tube down to the defrost pan at the bottom of your refrigerator on the back and evaporated by the compressor heat. Sometimes this tube gets clogged and water does not drain from the cup and overflows inside your refrigerator against the backwall.
Aug 16, 2009 | Kenmore Refrigerators
I have a whirlpool refrigerator and it seem to be leaking from
The bottom front of the refrigerator or freezer door Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
The back of the refrigerator Water coming from the back of the refrigerator usually comes from either the ice maker water valve or line (if there is an ice maker), or from the defrost drain pan.
Here's what to do:
  • If the water is coming from the ice maker water valve, check to make sure the water tubes are attached properly and are fastened tightly.
  • If the water seems to be coming from any part of the valve itself, replace the valve.
  • If the water appears to be coming from the defrost drain pan, inspect for holes or cracks, and replace the pan if necessary.
The inside ceiling of the refrigerator Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem. This can be a big job – you may want to hire a qualified appliance repair technician.
The inside back wall of the refrigerator In some refrigerators, the water from the defrost cycle is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain - usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Underneath the front of the refrigerator If the refrigerator is equipped with a water dispenser on the freezer door, check if the water line to the dispenser is leaking. Also, check the drip pan to be sure it isn’t out of place, broken or cracked.
Mar 24, 2009 | Refrigerators
I need a HE430TF door shelf.
Try screwing some long self-tapping screws in to hold the shelf on.
Mar 24, 2009 | Delfield Series 6000XL Remote Half Height...
Leak
It leaks Water can leak from these areas:
Here's what to do:
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Water leaking and freezing in bottom of freezer
You will have to remove the rear evaporator shroud. The drain system is accessed from the interior freezer compartment; you will see several Phillips screws holding the rear panel to the freezer rear wall. Remove the rear panel and clear the drain system by removing the ice build up and poor boiling water down the drain to melt and residual ice and to assist in removing any debris that may be blocked in the drain system. Once the drain is clear you will notice water flowing down the drain as you poor it in. Please keep in mind that the defrost drain pan located under your Refrigerator may overflow if there is an excess amount of water
Jun 17, 2008 | Maytag MZD2752G Side by Side Refrigerator
Refrigerators Logo
240 people viewed this question
Top Hoover Refrigerators Experts
Joseph Vernice
Joseph Vernice
Cris Sparks
Cris Sparks
sonic boom...
sonic boom...
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
