Question about Classe CDP-300 DVD Player
Noisy louding of discs and I can hear discs spinning
Loud squeaking.
To me, I think I am hearing a dry bearing.
However, an old worn out belt can make the same sound!
You could take off the belt and try spinning the pulleys to hear which is noisy, or you could use a mechanic's stethoscope to find out.
A mechanic's stethoscope is a really long screwdriver or metal rod about 2 or 3 feet long that they put on different parts (put the handle end to your ear) to hear the noise each part is making.
If your belt is good, try the alternator bearings.
There is also an idler pulley or maybe 2 that could be noisy.
Be blessed.
Feb 07, 2013 | Cars & Trucks
Bosch Maxx 5 very loud noisy spin
the spinner to motor coupling is damaged by the wear and tear..please replace it
Aug 24, 2012 | Bosch Washing Machines
Noisy Spinning
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Mar 29, 2010 | Washing Machines
Very noisy when on spin. The machine seem to be balanced however the noise on spn is like a jet taking off. it gets louder as the spinning speed increases.
Mar 28, 2010 | Maytag Washing Machines
Excessive noise during the spin cycle. we have owned the washer for 16 months. problem started 1 wk. the machine is level.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 03, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Very noisy on spin
hello there.....the noise you hear is most likley due to failed drum bearings or something trapped in the drum....test as follows....isolate machine....open the door...test the drum for up and down lift...there should be no movement at all....if all is well here...remove the lid and remove drive belt....spin the drum by hand and listen for any bearing noise (rumble). or metallic sound of something trapped in drum..if all is well here refit the lid temp...Then select spin and start machine...if motor is noisy then the problem is with the motor bearings
regards Sir Galahad
Sep 21, 2009 | Hotpoint WMA64 Front Load Washer
Loud noise when aggitating code says motor not rotating properly
or something stuck up in spinning motor assembly.
thanks and plse do not forget to accept the solution.
Apr 02, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
NAV6800AWW - noisy
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
Nov 04, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Noisy Spin Cycle
hi there,
Jun 12, 2008 | Whirlpool LSR9434PQ Top Load Washer
Danby washing machine noisy only during spin cycle
hi there,
Jan 13, 2008 | Danby DWM99W Top Load Washer
Televison & Video Logo
52 people viewed this question
Top Classe Televison & Video Experts
Electro Med Services...
Are you a Classe Televison and Video Expert? Answer questions, earn points and help others
