Question about Pioneer VSX1020K Receiver
Pioneer VSX1020K 7.1, makes a noticeable "humming" sound when turned on (without being hooked to speakers). Humming is coming from the unit. When hooked into a Definitve center speaker and 2 Polk (right/left) speakers, humming sound also comes through speakers and is noticeable when volume levels are low. I tried some "recommendations" that I found on-line (plugging unit into same circuit as other devices, plugging unit into diffferent circuits, etc) but nothing seems to work. Is the humming sound to be expected? I beginning to think there si an issue with this particular unit.
techman
  • 3130 Answers
SOURCE: static and crackling sounds
Sorry to burst your bubble my freind but things do wear out as you had plenty of life out of this unit.. Your problem is a transistor or a driver IC is breaking down under a load and heat and will get worse to where you wont be able to use the unit.. It will probable cost you in a range of 200 bucks or .more!as there is no quick fix for a solid state unit that has no user serviceable parts inside. Its just not replacing the bad part , its the hooking up to the load resistors then seeing that several other parts are not up par and having to start rebuilding the amp statges of your reciver.. If its more then 8 years old Time to landfill it and get a new one .. Put it to rest. It dosent owe you anything as its been loyal to you all these years!! Good Luck
Posted on Jul 27, 2006
SOURCE: Pioneer Multichannel Receiver VSX-D508 (including cd player & tape deck)
receiver on the screen displaying power off
Posted on Apr 15, 2008
petraman7
  • 1175 Answers
SOURCE: No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown ...tech service only.
Posted on Feb 08, 2009
SOURCE: reciever only allows 2 channels(speakers) at a time.
Two solutions:
1. make sure you are sending a 5.1 signal to the receiver (my DVD player was configured to only send stereo even if I picked the 5.1 soundtrack, i had to fix that). Read the manual to see the indicator lights that would light up if you are sending a DTS signal or Dolby Digital.
2. Use the 'surround modes' to at least get pseudo surround
Posted on Feb 18, 2009
  • 39 Answers
SOURCE: pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
Posted on Sep 13, 2009
Soundbar problems
hi Michael,
no try to unplug all the connections and re plug .if doent help.you have to go for electronic repair.main problem is with power amplifier section.or power supply unit
regards,
nuwan
Jan 20, 2014 | Audio Players & Recorders
I have no sound coming from surround speakers and sub.
Some surround modes switch speakers on or off as required. It's possible that the inputs you are using have settings that remember your previous settings, ie: no sub and surround speakers. Check the inputs and also make certain that whatever is connected to them is putting out Dolby signals.
May 04, 2017 | Pioneer VSX1020K Receiver
Zone 2 Amplifier Need
Reread the detailed answer provided in response to your earlier post on this issue
Jun 10, 2013 | Pioneer VSX1020K Receiver
Low independence light comes on and a humming sound what is causing this?
Humming from subs? If from inside amp, your experiencing a problem with a driver board. It makes transistors latch on and loads down the transformer, causing light to come on. And vibrations "hum" from transformer.
Oct 16, 2012 | Jl Audio 500/1V2 Car Amp
I own a Bose Acoustimass 7. I noticed humming coming from bass more noticeable than before (although I recently moved it to another smaller room) I also noticed when I hear this humming- the higher I turn...
I was having this very same problem. I finally figured out that I was getting feedback to the system because my TV cable coming into the house wasn't grounded right.
Oct 04, 2011 | Bose Acoustimass 15 System
The humming comes from the speakers and is very low and doesn't increase with the volume.It doesn't really bother much, just during quite times of a movie.
does the hum comes in all input? if yes, check proper earth gounding from wall outlet and if ok check filter capacitor in the power supply circuit. If not in all input, check hook up wire for that input causing the humming noise, could be a bad hook-up wire only. Thanks :)
Dec 23, 2009 | Pioneer VSX-D509S Receiver
RCA Pre-Out Making Producing a Mumming and a Popping Sound.
the speakers hook to speaker wires not to any thing else no power no negative poles do you have a remote shut off switch connected to amp this would be important to cut off amp
when cut off amp if you still here the humming this can be an indicator of low power being produced by alternator alternators produce 14 anything below 12 would mean replacement of alternator
if alternator fine then you need to find new ground for amp and make sure you have a good ground for sterio this can be checked with a test light
to check a ground all you do is hook gator clip to power then touch test light end to ground on radio end light comes on got a good ground (make sure not to touch any other sterio wires just the ground wire while connected to power to check grounds)
if pulsing in test light on the ground means you have a bad ground
just disconnect move to better ground
check the amp ground the same way as decribed above
May 09, 2008 | Pioneer DEH-P3900MP CD Player
Speakers hissing/humming
Hi Nate41
you won't do anithyng
may be is a bad resistor inside, that get hot and probably start to do this problem. try disconecting the speakers, and move to other place, more cooler, and try to see if you don't get the hissing and humming sound now. sometimes dust and hot places get to this problem.
beside that, may be a path to a problem.
Nov 26, 2007 | JBL CREATURE II Computer Speakers
Pioneer VSX1020K Receiver Logo
102 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
