Hi my name is Tom, The problem I have is my airconditioner runs and i've also cleaned filters, but it only blows nomal air...it dosen't seem to cool...
  • 2,133 Answers
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Check indoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3 degrees less than room temp.6.Check compressor is working with correct pressure.
Thanks. Helpful?
Posted on Jan 03, 2011
Airconditioner blowing not cold
Yes. its the run capacitor that is bad. as far as the filter, evaporator and condenser coil is clean and compressor is okay as you said. get the exact type and model of the capacitor and replace... let me know... all the best.
Jan 30, 2014 | Panasonic Heating & Cooling
We have a Carrier 25HBA unit and we've noticed a frost build up on the outside compressor, my husband turned the unit off and cleaned everything outside and up in the attic. It worked. No frost...
Hello
Frost or ice on the bigger outside copper line is a indicatin of possible low freon.Hopfully that is all it is.
It is also a possibility the compressor is getting ready to break,bad valves.
You will need a tech to come out and charge the system with freon.
Check your filter is clean and new first.
Sep 15, 2011 | Heating & Cooling
Just bought a 2 yr. old Danby DAC5209M window a/c unit that doesn't cool the air before it blows it into a room. The wiring looks brand new, it was barely dirty on the inside, anyway, I've...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 24, 2011 | Danby DAC5020 Air Conditioner
Hi. My 2 year old Friedrich CP10E10 window unit is not cooling the room like it should/like it has. I followed obvious troubleshooting steps per the operation guide, including thoroughly cleaning filter....
Check the OUTDOOR coil... it sounds like it is clogged up and the system is cutting out on high pressure...
heatman101
Jul 23, 2011 | Friedrich CP10E10 Thru-Wall/Window Air...
The air conditioner "sounds" like it's running
heatman101
Jul 01, 2011 | GE Heating & Cooling
Unit overheating and blowing fuses
Low gas pressur causing the unit to overwork/heat, water trap coolant service port blocked. Some machines need 1/2 liter of water pouerd into a reservoir on the rear to aid cooling the heat exchanger, if this is dry it will overheat. cheakc the filters if it has any.
Jul 28, 2009 | Goldstar GW-HD5000 Window Air Conditioner
My goodman airconditioner is not blowing out air even though the fans are rotating
could have the fan running back wards , very dirty condenser, Bad capacitor the in side unit evaporator may be froze up or very dirty is the filter clean? your question is some what vague. good luck Tom
Jul 06, 2009 | Goodman CLQ36AR49 Air Conditioner
A/C not blowing cold air (posted on 1995 maxima forum in error)
check for system leacks (lines,fittingis,comperssor,dryer,condensor )
Jun 23, 2009 | 2002 Nissan Maxima
Edgestar 12,000 portale air conditioner and heater
There are 3 possibilities beginning with the most likely problem
1) If your heater heats up for a few minutes and then quits, chances are there is a blockage in the air flow, check for dust and grime blocking the air intake coarse filter , airgun blow to clear accumulated dust and otherwise clean the coarse filter .
2) If the heater fan blows but there is no warm air, the heating element needs renewal ( this happens very rarely)
3)If the fan stalls and the heater heats up and the thermostat kicks in, then this will be not be a DIY job. This is least likely as you said the air cooler works.
Apr 25, 2008 | EdgeStar Portable Air Conditioner Heater
Heating & Cooling Logo
94 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
