Question about Dynex 32 in. LCD Flat-Panel HDTV
When I turn on the TV it restarts every ten to twenty seconds. No physical damage done to the TV.
  • 32 Answers
You probably have a leaking capacitor in the power board easy fix if your handy also should be pretty cheap even if you have to take it to a shop
Posted on Jan 03, 2011
  • cmburson83 Jan 03, 2011
    Have a handy man/computer geek at home and that is the first thing we checked for. Saw no popped capacitors on power board or anywhere. No burn spots or popping noises to identify any problems. Power supply checked and power is flowing through everything.
My i pad is stuck in sleep mode
Perform a hard reset: Press both the Power and Home buttons and hold them down. Keep holding both buttons down until you see the Apple logo appear on the screen. The logo should appear between ten and twenty seconds after you start holding the buttons. After the Apple logo appears, your iPhone or iPad will boot back up normally.
Charge your iPhone: Connect the iPhone to the iPhone's USB power adapter and let it charge for at least ten minutes.
Get iPhone into Recovery Mode: Turn off you iPhone and just plug the USB cable into computer > Hold the HOME button when you connect USB to iPhone > Release the HOME button when you see the iTunes logo.
The Most Common iOS 9 9 2 1 9 3 9 3 3 9 3 4 Problems and Solutions
Aug 17, 2016 | Apple iPad (16 GB) WiFi Tablet PC
So my computer randomly went to a boot menu and from there it shut down. since then, I wasn't able to turn it back on. how do I turn my gateway ms2370 on?
Try , removing battery , press and hold power button for ten to twenty seconds , reconnect battery , connect mains and try to restart , doesn't sound good though
Jan 08, 2015 | Gateway Computers & Internet
Why dose the power light come on and will go off in ten to twenty seconds ?
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ .
Sep 16, 2014 | Sanyo DP32649 31.5 in. TV
Electrolux washer showing locked key on display how to remove?
Hello - Trying pressing OPTIONS and SELECT at the same time holding down for twenty seconds until "LOC" is no longer displayed. If it is not success, reset the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issue.
Jan 13, 2013 | Washing Machines
My insignia NS-LTDVD19-09 turns off 3 seconds after I turn it on.
that"s very difficult thing without any test by multimeter & just look at it yes you right no any physically damage at least . maybe power supply working fine. maybe done gone in already.you need a technician for troubleshoot it.
Sep 07, 2012 | Insignia NS-LTDVD19-09 LCD TV
Wont do nothing but initializing
Hi.
The procedure below is the full troubleshooting when the RCA Opal is completely irresponsive and not completing initialization.
Try first holding down the Power/Menu button for over ten seconds. This is called soft reset, and will reset the player to default factory settings. This reset will not delete personal files.
Depending on the model you may also have a reset button. In that case hold down the pinhole switch using a paper clip for more than ten seconds to perform an hard reset. It will take one or two minutest to restart the Opal after this reset, as files must be reinstalled.This reset will delete files and personal settings.
If that does not work, it means that system files are damaged. In that case you will need to reinstall the Opal firmware. Firmware for some model may be available online, but better calling or contacting RCA and asking them to provide you with an updated firmware for your unit. If the wrong firmware is installed the Opal may result damaged.
RCA can be contacted at the number listed on Opal documentation. Number in US should be: 1-800-878-5779 (RCA Audio Products Repair Centers and Warranty Info).
You can also get the firmware asking a question online. Use the following link: Create an Incident or ask a question.
See also: Information on RCA Opal M4001 MP3 Player.
To update firmware follow procedure below:
Download the firmware upgrade file.
Hold down the play/pause button for about twenty seconds .
Hold down menu button for more than 10 seconds
Keep holding play/pause button and attach Opal USB cable to computer at the same time.
The firmware upgrade will start
If you get an error saying that Windows cannot write to the Opal drive, that means that the Opal internal drive must be re-formatted. In that case go to Computer, click the right button of mouse on the Opal, and choose Format from the dropdown menu.
After formatting, restart both units, and restart firmware upgrade procedure.
Regards.
Mar 31, 2010 | RCA OPAL M4001 MP3 Player
Image goes out after twenty seconds
my did the same i just hit on the side of the tv and it,s working ok not sure try it.
Apr 03, 2009 | JVC AV-27D303 27" TV
Chainsaw floods out after about 10 mins
sounds to me that the needle in the carburator is bad.you need to rebuild the carb. and check the settings when your done
Jan 01, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Blue light in the front blinking no picutre no sound
This is the shutdown code for the lamp ballast. I would have a technician verify ballast is bad and replace. This can be a tricky repair for a novice because installation of the ballast requires that you remove the light engine. Hope this helps.
Mar 28, 2008 | JVC HD-52G886 52" Rear Projection HDTV
Dynex 32 in. LCD Flat-Panel HDTV Logo
110 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
