Question about Ruud Heating & Cooling
Furnace is 7 years old. Will not stay running for more than 5 min. Will start up again after shutting off and then run for another 5 min. Suggestions?
  • 1,420 Answers
Check the air filter. Jump out thermostat to see if it stays running longer, if so replace thermostat. Make sure all return air ducts are clear of debris. If furnace has a Fan/Limit switch, make sure tabs are set at 100, 140 and 200. Sounds like something may be heating up and shutting unit off till it cools back down.
Posted on Jan 03, 2011
Furnace kicks on and heats up for 5 min. then will shut down - no flame - main blower will run for a few min and then the whole cycle will start again. flame sensor checked ok with meter at approx 5.0
What is your temperature rise during the 5 minutes it does run? Could be overheating and kicking out on limit switch. Watch the diagnostic light for a code. (3 blinks means this, 4 blinks means that etc.)
Jan 09, 2014 | Amana Heating & Cooling
Coleman evcon furnace
How old is your furnace? Does it have a circuit board that controls everything, or are there separate controls for each function?
Nov 19, 2013 | Heating & Cooling
I have a dayton fuel trimmer furnace model # 3E438A and the problem is that upon ignition to the furnace the unit runs and after about 3 minutes the units inducer fan shuts off and the flames stays on....
It sounds to me like your draft motor is probably shuttimg off on thermal overload. They will get to hot and shut down until the motor cools down then run again.But by that time it's caused other trouble so I think you need to replace the motor first and then see what other problems it has caused.I hope this helps you and thanks.
Jan 10, 2011 | Heating & Cooling
Garage furnace (standing Pilot) pilot stops after 30 mins.
it sounds like the afc the fan control not working could be dust on the afc
Jan 10, 2010 | Dayton Gas Furnace Heater
Furnace runs OK, but blower runs again a few seconds later
Could be a defective thermostat in the plenum.
When a gas furnace shuts down the fan(blower) will run until the plenum cools to the safe range. Usually 1 and 1/2 minutes.
Intermittent operation is a defective thermostat or relay.
Mar 11, 2009 | Carrier Heating & Cooling
Gas furnace false start
Check the filter and/or air flow in general. It may be over heating.
Feb 25, 2009 | Heating & Cooling
Model EL7020 will not stay running!
Try turning the knob on top of the machine all the way to the right and try it again
Dec 04, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Heater blower motor cycles on and off (frequently). I have a class 2 LR95329 Honeywell Thermostat
The clicking noise is a relay or switch of some sort. You are right about that. I have 2 questions. 1) does the thermostat have a mercury bulb in it? 2) when the fan shuts off and on, does the burner stay on?
Nov 05, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
128 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
