Question about Nvidia Computers & Internet
Graphics card what is the graphics card for the Dell Dimension E520 computer?
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    Do you own this computer? And if so, can you look on the back or side for a sticker that is called the service tag #. It is about 6-8 digits long and may have letters and numbers. You see each PC is a bit different. I can look up what you have from the service tag as I and many others here are registered techs with Dell.
    Regards,
    Worldvet
    Scholar:
  • 58 Answers
Hello.
If want to see your installed devices go to:
Start - Control Panel - Double click in - System icon - Hardware - Device Manager.
You will find the graphics card under:
Display Adapters, just click on +.
Or click on - Start - click on RUN, type DXDIAG , click ok - if is your first time running dxdiag click ok till you get to the dxdiax window then click Display, there you can see almost evething in your system.
Hope this help.
Posted on Jul 12, 2008
Whining fan dell E520 computer
Replace the fan as soon as possible. If the noise suddenly stops, DON'T assume the problem corrected itself. More likely, the fan completely froze and stopped spinning entirely and you're at risk of overheating something inside. Generally, there are usually 3 fans in a desktop computer (cpu/heatsink, case, and power supply) and sometimes a 4th fan if the computer has a separate graphics card. Laptops usually only have one fan.
Apr 27, 2014 | Dell Dimension E520 PC Desktop
Graphic card location inside an E520
The Dell 520's manual can be downloaded here. The PC's motherboard optionally has a VGA Video Connector (integrated) as shown on Page 1 of the manual. If yours is equipped with this option, there is no graphics card installed - it is built into the motherboard itself. It can not be removed or separated from the PC.
Your PC may have a a separate video card installed into one of the expansion slots on the motherboard. Page 1 also shows this installed below the USB 2.0 connectors as the PCI Express graphics card.
Here's an internal view:
The video card in the picture is driving two standard analog VGA monitors (blue cable connectors) through a DVI -> VGA adapter (white and clear devices) this is connected to the video output connectors. If you look closely at the edge of the PC in the picture (directly above the USB & network cables) you should be able to see an unused VGA Video Connector (integrated). Most computer BIOS systems will automatically disable any built in video capabilities of the motherboard when a separate video card is detected. Check the manual for additional info about these BIOS settings.
I hope this helps & good luck!
Apr 17, 2012 | Dell Dimension E520 PC Desktop
I have a Dell Dimension E520 that I've used for
If the power LED is solid Amber, then the like answer is a bad motherboard or peripheral connected to it. So, remove any expansion cards (I See you already removed the Graphics card) and all external connections (Just use power cord) and see if the system will power on with any different indications. If the power LED stays Solid Amber, replace the motherboard
Aug 07, 2011 | Dell Computers & Internet
Where can i find Dell dimension E520 drivers, such as ethernet controller
Access the manufacturer's web-site: http://support.dell.com
Enter the unique "Dell Asset ID" code (black type on a white decal on the back-panel of your desktop computer), to get information about *YOUR* specific computer, including device-drivers.
Sep 15, 2010 | Dell Dimension E520 PC Desktop
I added a 4 port usb card to a dell e520. The
try updating the drivers to the card to see what happens. another solution is try it on another computer. if the same problem exists on another computer you could have a bad card.
Mar 30, 2010 | Dell Dimension E520 PC Desktop
Where do I find the usb port on my dimension E520 Dell computer?
E520 has 2 usb ports on the front right where the card readers are. It also has 5 (Five) on the back right where your ethernet cable hooks in.
Oct 02, 2009 | Dell Dimension E520 PC Desktop
I cant git sound
If your monitor is fine try changing the data cable to one you know to be working. If it still does not work then the graphics card needs to be replaced.
May 29, 2009 | Dell Dimension E520 PC Desktop
Monitor is blank when plugged into Nvidia Geforce 8600GT
is video card pluged in tell bios pci express video snaped down good
Jan 19, 2008 | Dell Dimension E520 PC Desktop
Open Questions:
Computers & Internet Logo
51 people viewed this question
Top Nvidia Computers & Internet Experts
David
David
Alun Cox
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
