Question about Dishwashers
Bottom & top draws slide closed on its own ,will not stay open model DD60DCX6
    Sergeant:
    Novelist:
  • 185 Answers
The dishwasher was not install level. You will have to level it. There are leveling screws one on each side at the front of the machine behind the bottom plate Also you may have to take the screw out of the top bracket to get it leveled. Good Luck
Posted on Jan 03, 2011
Hi the vege draw on the bottom always freezers the veges the draw above is fine i have tried sliding the open/close lever also where to purchase replacement draws and milk shelf
USUALLY A PROBLEM WITH THE AIR FLOW DAMPER CONTROL AND OR THE FRIDGE THERMISTORS> IS THE FREEZER OK? IF U HAVE A BAD DOOR SEAL OR CLOGGED DRAIN PLUG U CAN GET CONDENSATION THAT MAY FREEZE AT BOTTOM AS WELL
Mar 16, 2015 | Refrigerators
Fisher & Paykel Double Dishdraw (DD60DCX6). 1 Draw gets stuck mid cycle & continues to wash, no beeps, water not hot. Can you tell me which parts need replacing. Previously other draw
Coulg be a faulty heater. The unit will continue to wash for 2 hours before it gives an F4 fault message. Check the resistance of the heater element. There may be a solder link that is designed to fail if the temperature ever gets too high. Otherwise it could be a faulty controller board. Post back if you can narrow the diagnosis.
Jan 27, 2015 | Fisher and Paykel Dishwashers
Power cannot be turned on. led display not on
Check that the draws are closing properly and evenly , there is a door sensor just inside the frame top and bottom on the right side .
If thr machine is not level the doors can slide forward.
if this does not work , feel if the draw really locks in when closed because at the back of the draw slides on each side are two plastic lock mechanisms. when the draw has been out they need to be upwards facing so when closed thy lock the slides in on both sides . Sometimes thy only lock in one side causing it not to deactivate the door sensors and shut down .
Yes it sounds simple, but most problems i have found are
Feb 03, 2014 | Fisher and Paykel DishDrawer DS605FDSM...
Need to remove upper drawer Fisher and Pykel dd605ss
Open the top draw. On each side of the draw at the bottom / front, is a clip that releases the rails that the draw slides in and out on. Press the clips in to release and slide it back (into the machine as if you were closing the draw). Do this one at a time and then lift the draw slightly and rotate the draw anti-clockwise direction (due to the plumbing) and lay the draw on its left hand side. The draw is out!
Oct 18, 2012 | Fisher and Paykel DD605SS Stainless Steel...
Freezer drawer slides
you have to keep the white wheels on the rod even or the draw won't close correctly,pull the racks out fully open and even on both sides,you might have to adjust the wheels so both sides are even,i use a marker and mark the wheels,now when you hook the door assy on.you have to make sure the wheels stay in place or when you close the whole unit one side of the door won't close all the wa,it's a little tricky if you never tried to line them up before but if you mark the wheels part numbers 12002497 so both sides stay lined up it will close correctly. http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MFD2560HES/3048/0161000/M0412077/00009?blt=06&prst=0&shdMod=MFD2560HES this is the sears site and will show you a picture of all the parts.hope this helps
Dec 01, 2011 | Maytag MFD2560HES Bottom Freezer French...
Fisher and paykel dd603
Flood switch is at the very bottom underneath the bottom draw in the base floor.Unplug cord.Open bottom draw all the way & squeeze a towel or sponge under the draw & soak up the water..The washer should work now..Why did it flood in first place?
Check that dishes are not stacked higher than top edge of the draw otherwise it can't seal.this can happen when children are asked to stack the dishwasher.Another cause is some models the seal is an inflatable tube that seals the top edge of the draws,it gets cut or sliced buy a plate that was stacked to high when you closed the draw.there should be no clunk of dished hitting when the draw is closed.
May 30, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Top dishwasher drawer will not close
As long as there is no plates or anything stopping it from closeing i will then say that there are 2 side rails that the draw glides in & out on,get down on the floor & check up underneath the draw for smooth gliding operation.also is it possible that a fork or peice of cutlery has gotten over the top & fallen down jambing the draw from closing.
May 29, 2010 | Fisher DD603B / DD603W / DD603H Dishwasher
The DVD player slide draw will not open or close
Check for a manual eject slide on the bottom near the front of the tray
Nov 21, 2009 | Philips DivX DVD Player
My fisher paykel top draw does not close fully and therefore when it operates its floodsa nd the f1 code comes on. I know how to clean and reset it but not sure why the door will not close fully, I can...
check the draw on the sides at the front as the draw sits on runners and there are tabs on the runners at the front which hold the draw on. hold the plastic tabs both sides and slide the draw past the slots on the bottom sides of the draw.
Jul 05, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Amana ARB2117BW - Bottom Freezer Door Won't Stay Sealed
This problem was posted in the wrong section. My model didn't have it's own, so its in ABB1927DE Bottom Freezer Refrigerator - perhaps you could create a section for it.
As it turns out, I looked more closely at the baskets inside. We had noticed that if the top basket was slid all the way forward when we closed the door that it would close better. So I looked to see if they or the slides were out of alignment. They seemed ok, but then I saw that the way the bottom basket was hanging didn't seem right - it was not quite nestled into it's retainer slot. I took the baskets out and turned the bottom one around. It fit perfectly into it's retainer slot. I then replaced the top one (it was already in correctly) and closed the door. It sealed correctly the first time. I tested it several times after that and it sealed tightly. Closing the top door did not make it unseal as it had done before.
Jan 23, 2009 | Amana ABB1927DE Bottom Freezer...
Dishwashers Logo
Top Dishwashers Experts
