Question about Panasonic CT-27SL13 27" TV
Model Panasonic - CT-27SL13 - All off a sudden No Power. Thoughts !
3 Suggested Answers
SOURCE: Panasonic television
I had the same problem, however mine was a 32inch. It is a blown fuse. It is not the power cord. What you need to do is find out what fuse voltage you need. Hope this advice helps. I have a panasonic model CT-32SX12C.
Posted on Jan 13, 2009
SOURCE: Panasonic 32'' TV wont power on
I just received the same model from a neighbour because it too wouldn't power on after suddenly quitting. The T.V. rrepair shops quoted $160.00 to $250.00 to fix the power supply/transformer. All I did was rremove the back and check if the circuit board was actually receiving power from the corsd - it wasn't. I then replaced the plug, plugged it back in and the set works prefectly now. This is a commonm problem with panasonic and certainly does not require the services of a technician, not the exorbatant costs quoted to repair. Simply cut off the plug and replace with a sturdy self sealing/connecting one available at any hardware store for less than $1.00.
Posted on Mar 16, 2009
Hi My wife was watching our 2002 Panasonic CT36SX12CF model t.v last night, all of a sudden there was a pop noise and the screen went black. The tv would not turn on again. Any ideas what the problem...
hey Al more than likelly it was the fuse that popped if you take the back panel off the fuse is next to the power cord and should take a 6.3 amp 125-250 volt fuse
Oct 31, 2010 | Panasonic CT-36SX12 36" TV
Feb 24, 2009 | Panasonic Televison & Video
NO POWER OR LIGHTS WHEN POWER BUTTON PUSHED
Hello and welcome to FixYa!,
It sounds like the Power Board on you TV has Died, you will need to replace it in order for your TV to work again
Hope this helps --Full Str Pka
Dec 30, 2008 | Panasonic Televison & Video
PANASONIC CT-27D30B
Maybe the vertical IC output are damaged you need to replace him
Sep 19, 2008 | Panasonic CT-27G14 27" TV
Won't turn on
Once you take the back off there is a glass gma fuse withing a few inches of where the power cord plugs into the board at. This should be a 6.3 or 6.5 gma fuse. Very common to blow in your model because the degausing coil is a little to big for it. There are other reasons for it to blow but 99% of the time you change change it and the set will work again. Let me know if you need more help or info!
Tim Nolan
Sep 11, 2008 | Panasonic CT-32HX41 32" TV
Aug 20, 2008 | Panasonic CT-36SX12 36" TV
Power Problem
Josh,
Can you hear any slight ticking noise following he click? It's one of two probabilities, either the HOT or the FBT - - The horizontal output transistor in that unit is a common failure. It uses a 2sc5902, which you can sub to a 2sd2539 or an NTE2353, either will work as well if not better than the original. And it only takes a shop a very short time to do a continuity test acress the E&B (emitter and base pins) on the HOT to determine if it's shorted.
When the HOT shorts the shutdown circuit will pulse, causing a very faint ticking sound, cycling in it's attempt to power the unit.
If you're going to have a shop do call around and ask what they charge to replace the HOT like you know what you're doing...
Let me know how it turns out..
Bill
Nov 13, 2007 | Panasonic CT-27SL13 27" TV
A lot of white noise appearing on Panasonic CT-27SL13 27 using COMCAST
You maist likely have bad ground connections inside the tuner of this TV set. Good Luck
Jun 23, 2007 | Panasonic CT-27SL13 27" TV
Buzzing sound, no picture on my Panasonic TV
You might have a short causing the set not to start. Probably in the horizontal/high voltage circuit. The buzzing sound that you're hearing is the power supply overloaded. Stargazer
Apr 22, 2007 | Panasonic CT-27G23 27" TV
Panasonic CT-27SL13 27" TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
