Question about Bunn Cuisinart Coffeemaker: Pour-Omatic Coffee Brewer ( O Matic)
I have a bunn axiom machine that doesnt brew when i hit the brew button
3 Suggested Answers
mcdevito75
  • 1970 Answers
SOURCE: bunn axiom coffee machine over flowing brew basket
mcdevito75 here It may need to be cleaned. Refer to owners manual on cleaning your coffee maker.
Posted on Jun 20, 2010
EsWorld
  • 1618 Answers
SOURCE: how do i adjust the
Remove the front panel there are instructions on increasing the water level.
Posted on Feb 19, 2011
Do I calibrate my coffee machine? I have a axiom 15-3
The programming is done on the front of the machine. Here's a link to the Service Manual. https://catalog.bunn.com/public/docs/41154.0000/E17/00/000/41154.0000.pdf
Oct 02, 2016 | Bunn AXIOM AXIOM-15-3 (38700.0000)
I have a bunn CW series brewer. I filled the reserve with water and allowed to get hot. I then add additional water (1 glass pot) and it just starts to dispense without me hitting the "start" button. I...
Sounds like the switch is stuck in the operate position. Therefor once the machine hits temperature it just brews. Your local Bunn distributor should be able to recommend an engineer to replace the switch or supply the correct t,hope of switch if your confident enought Tom replace it yourself.
May 11, 2014 | Bunn CW 15-APS Coffee Maker
Hot water faucet adjustment?
The Axiom uses a water level probe to keep the heater tank filled with water at a set level. The hot water facet takes water directly from the top of the tank. It's gravity fed with only the weight of the top portion of the water (the hottest area) to flow into the faucet. It is possible that your faucet 'Boot' or spring is bad and needs replacement. But it's designed to give you a single cup of hot water. Do not expect to fill a pot (or large french press) with this faucet.
* Call your vendor for service.
Aloha, ukeboy57
(the parts manual) https://catalog.bunn.com/public/docs/39131.0000/E17/01/000/39131.0000.pdf
Apr 03, 2014 | Bunn AXIOM AXIOM-DV-APS Coffee Maker
How do i adjust the water level on my Axiom Bunn coffee maker? It only brews about a half of a pot.
Feb 18, 2011 | Bunn AXIOM-35-3
Bunn axiom coffee machine over flowing brew basket
Jun 20, 2010 | Coffee Makers & Espresso Machines
I have a Bunn VLPF that does not stop at the end of the "brew cycle" but just continues to run and run and run and . . . (you get the point)! Thanks for your help Phillip S. Hull
Hello, you have a problem with the inlet valve or timer. hit the brew button and then once the water starts running through the brew cone pull the plug, if after a couple of minutes the brew stops your problem is going to be with the timer (you should replace it) if the brew does not stop at all then you have a problem with the inlet valve (it has a piece of calcium stuck in the valve) you should replace the valve kit in this instance. You can buy parts from either bunn or a company called holiday house in cali. if you have any further questions please feel free to comment again. Good Luck!! Mike
Sep 28, 2009 | Bunn VLPF Coffee Maker
Coffee Makers & Espresso Machines Logo
21 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
evans_lloyd
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
