Question about Acer Aspire 3000 Notebook
Acer 3001 Wlmi CMOS Dead
Hi experts,
Can someone guide me how to replace the CMOS battery for Acer 3001 Wlmi notebook..? I tried my best to get the repair manuel by googling...but couldn't so far..!
The notebook dosen't boot at all.. :(..
  • yuvaprakash Jul 10, 2008
    Can anyone please help me..:(
  • 476 Answers
The best place to search the manual from this site link
the manual is here,it covers specs etc....
Have you tried ac power pack without battery attached?
if it is a cmos fault then battery will be on motherboard
battery number should be on battery
Posted on Jul 13, 2008
Step 1:
This might not be your laptop it might give you a guide into the cmos battery
The CMOS (Complementary Metal Oxide Semiconductor) battery saves basic settings on your computer. If the date and time function on your Acer notebook isn't working, chances are your CMOS battery needs to be replaced. Separate from your laptop's main battery, the CMOS battery is about the and shape of a coin and is located inside of your computer. Changing the battery yourself isn't the simplest task that relates to your Acer, but it isn't terribly difficult either. Here's how.
Open the notebook screen until you can easily access the keyboard. Locate the plastic bar that borders the top of the keyboard. Insert the flat head screwdriver at one end of the bar and gently pry it up until you can grip the edge with your fingers. Pry the other side of the bar up with the screwdriver and pull out the entire bar, being careful to mind the ribbon cord that connects the keyboard to the computer. Remove the two screws on either side of the keyboard that secure it to the computer. Slide the keyboard up and place it to the side. Remove the four screws on the exposed metal plate that covers the motherboard and remove it. You should now see the CMOS battery in the bottom-right-hand corner of the motherboard. Remove the battery by gently pulling it up and off the motherboard. Replace it with the same model battery (available at any computer store or online). Reassemble the computer the same way you took it apart. Acer TravelMate 6592G Keyboard Replacement Guide
Apr 01, 2013 | Acer Aspire One Netbook 8.9" Notebook
Reset bios
You need to open your notebook remove first the battery and all screw at the back of your notebook. You can see there a CMOS battery together with the CMOS jamper. Just read it you can read CLRSCR which means clear cmos, just pull it with in 10 seconds and insert it back. Now you are done to reset bios.
Mar 30, 2010 | Acer Aspire 9810 Notebook
Low battery warning message on boot up
I'll give you the info for the cmos battery but afterwards observe any other issues with your notebook. Your notebook is not new anymore and may need other servicing besides a new cmos battery.
It should be housed driectly undeneath you notebook on a panel you can remove that houses the ram.
If you still cant find it, you may have to physicaly take apart the unit. I would search under the keyboard and all four corners of the motherboard and center. Just in case.
Let me know how it goes.
P.s: Be very careful If you are not use to opening up notebooks then I suggest taking unit to a professional for them to replace the cmos battery.
Mar 07, 2010 | Acer TravelMate 244LC Notebook
I have a acer mini and my time keeps on changing ... What do i do? And if its COMS battery... how do i replace it?
There is every chance that the CMOS battery is dead and it needs replacing.
As far as i know you have to disassemble the laptop to get to the battery, I'm sure its next to the memory. The battery looks like this >>>>>>>
Here is complete guide to disassembling the notebook. Don't worry about references to other manufacturers or the title of the below link , just click on the link and follow the instructions till you can remove the battery and replace it. >>>>>>>>>>>>
Nov 16, 2009 | Acer Aspire One A150-1006 Notebook
How do I replace a dead cmos on acer 4520LCi travelmate laptop? The laptop no longer keeps track of system time when shut off completely. Can you tell me the exact location of the cmos so I can be able to...
what you replace is not the CMOS, but the CMOS battery.
On an ACER from those years the CMOS battery looks like a coin, or a coin wrapped in plastic and connected to the motherboard.
On most models from same series the battery is located on the lower side of the motherboard, like on picture below:
On some model the battery may be located underneath the keyboard.
Here disassembly instructions for a similar model.
Sep 11, 2009 | Acer TravelMate 2300 Notebook
Information on Acer 1642 WLMI battery
The replacement battery you mention is High capacity battery that will work with your laptop.
186508APTA 14.8 Volt Li-ion Laptop Battery (works with Acer Aspire 1642WLMi).
14.4/14.8V, 4400mAh
  • This battery only compatible with 14.4V and 14.8V version.
  • New 100% OEM compatible
  • Guaranteed to meet or exceed original specifications
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    May 15, 2009 | Acer Aspire 1642WLMi Notebook
    Acer Aspire 1652 WLMi keyboard replacement
    dear sir.
    if u need to replace keyboard as my sujetion is perchase from otherise center they replace yr keyboard and plase it to yr laptop. and there no need to seen eny videos or guide it's simple stape to replace it just open frunt LCD panel downln plastic part then it's show 2 sckru just open it then safly remove keyboard and same as put new one but be safe a wair of keyboard is very scancitive it's help u....;)
    please vote
    Jan 01, 2009 | Computers & Internet
    Need Acer TravelMate 8204 WLMi
    the drivers for the 8200 series notebooks are available on this page
    drop me a comment if you need anything else.
    Dec 13, 2008 | Acer TravelMate 8204WLMi Notebook
    Acer Extensa 3001 Wlmi / BIOS battery replace
    Your system is oddly not listed on the Acer site. It may have been built by another company and rebranded.
    You can check here:
    You might try emailing them to see if they will inform you where you can get information on your system.
    Jul 04, 2008 | Acer Aspire 3000 Notebook
    Acer Aspire 3000 Notebook Logo
    242 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
