Question about GPS
Unitrol 131 wig wag flasher - GPS
natengel
  • 19 Answers
SOURCE: wont spin
may be lid problem
Posted on Nov 01, 2007
SOURCE: new 208 dodge charger with
To activate factory wigwags in a 2007/2008 Police Dodge Charger, connect pin 1 of the 24way upfitter connector found at the console (near the radio) to battery voltage -- the 47k series resistor is only required for MY2006.
That connection causes the VSIM module (located under the AM/FM radio) to send a CAN message to the FrontControlModule, where the front control module drives the headlights in the wigwag mode.
Pin 2 of the upfitter connector does the rear wigwags.
Some of the pinout of the 2008 upfitter connector from the VSIM to the console is different than 2006/2007 -- a Chrysler harness booboo for 2008.
Note that the VSIM (also known as PTIM) module is only on factory police Chargers -- civilian cars do not have this module.
Posted on Sep 09, 2008
  • 46 Answers
SOURCE: shakes violently durring spin cycle as if load were out of balance, but it's not.....
get a level and make sure that the machine is level by adjusting the legs with a cresent wrench or a pair os channel locks
Posted on May 25, 2009
  • 1810 Answers
SOURCE: I am looking for a diagram of a 9 volt wig wag
if you just want the light to blink use a flasher reley and a circut cut reley if you wire it properly it will flash
it is simple to wire it
there are 2 output wires and 2 input wires on the power reley just hook the flasher reley to the power wire and conect the lights up to eithor wire coming from the reley
remember the reley will require power and ground the litess are hooked positive side to the reley and neg to the neg wires of power supply
Posted on Sep 16, 2009
roniecon
  • 6826 Answers
SOURCE: i need a wiring diagram for wig wag lights
Three wires,the middle one to the switch in the car,and the other two,left,and right,go to each headlight
Posted on Jun 06, 2010
Just beeps when wig wag pulled but wont move
It could be the Wig-Wag needs replacing. But are there any fault bleeps or flashing lights. If so count how many and check in the trouble shooting guide of your user manual to tell you what the fault is.
Mar 24, 2015 | Health & Beauty
Why when mobility scooter not moving when engaged but when disengaged moving slightly
The unit is not made for "medical approved" market and does not have a POST (Power On Self Test) to confirm wig-wag (throttle) is in neutral when it first turns on. SOLUTION: Put the scooter up on blocks so the drive wheels are off the ground. With the SPEED KNOB turned fully clockwise, adjust the wig-wag (throttle) so the cart will not run and the brake is engaged when the cart is in neutral. There are usually Allen screws in the wig-wag handle that can be loosened and re-tightened once the wig-wag pot is properly centered for neutral.
Aug 09, 2014 | Electric Strider Maxi 4 Wheel Mobility...
What does the 7 beep code mean on my Pride Victory 10 scooter mean when I turn the key on ?
This is a speed pot or throttle control problem (wig-wag) have you had some speed issues with the scooter before this happened, if so the wig-wag needs replacing. Make sure it is in the centre position at rest and switch the scooter on again.
Jul 11, 2014 | Pride Mobility Products Pride Victory 10 -...
Whirpool imperial series will agitate but will not do spin cycle
If that is the old belt driven modle I would check the lid switch. If it is bad then no power will get to the wig-wag and the transmission will not be shifted. If the switch is fine check for corrosion on the shift pins or an open wigwag coil. The wig wag has 4 wires. 2 white wires that are common AND 2 other wires for wash and spin. A neat trick is to swap the 2 control wires and see if it washes in spin and spins in wash. That way you can determine if the wig wag coil is bad.
If the washer is a newer model without a belt I would say your lid switch is bad.
Oct 29, 2011 | Whirlpool Washing Machines
I Am A Vol.Firefighter And Have A 85 Fleetwood Cadillac D'elagent FWD I Have Been Able To Strobe Out The Markers,Tail Reverse,And Turn Lights But Have Always Like The Wig-Wag Affect On The Head Lights Is...
Your best bet is to check with Galls. They have a wig-wag flasher that should work with your vehicle. The main thing you need to determine is whether your vehicle has positive side switching or ground side switching. Since it is a domestic vehicle it should be positive switched.
Check the following link for more info:
http://www.galls.com/documents/FS039_Galls_Wig-Wag.pdf
Feb 23, 2010 | Car Audio & Video
Spin cylcle not working. Makes a funny sound and does not spin
There is a part called the Wig Wag. It is 2 solenoids on a metal bar about 6 inches long. It has a hole in the center of the bar and 3 electrical wires go up through the center. One is a common wire and the other two go to each selenoid. One selenoide when activated causes the WIG WAG to shift the Transmission into WASH MODE or SPIN MODE. They are powered by 115 VOLTS AC and is enough to KILL YOU.
What you will find is the 3 wires are held together by a few wraps of electrical tape. Because the WIG WAG moves while the machine is running, the wires are all the time FLEXING. Eventually a wire will break and in this case it was the SPIN Wire to the SPIN solenoid.
Replacing all 3 wires is the best fix. Splicing near the wig wag could cause the wires to break again, They could then pinch or touch the moving metal parts and if the washer is NOT properly GROUNDED someone could get ELECTROCUTED and KILLED.
USE CAUTION doing this repair. The replacemet wire needs to be FINE Grain Flexable wire. If you use something like Lamp Cord that is not designed to be flexed hundreds of times will soon break.
Check with Sears Parts and ask for a Wig Wag Wire Harness.
You can lay the machine on it's back and see this problem. Caution plugging it in on it;s back, something could break.
The Wig Wag can take your fingers off..... CAREFUL !!!!
Do this repair at your own risk. It is dangerous.
At least you will know what to tell the Repairman.
Apr 26, 2009 | Washing Machines
Kenmore heavy duty washer wont spin but does everything else corr
you really still have a belt model? that unit is close to 30 years old now.
anyway if the unit looks like all is moving, then you may have a bad lid switch or most likely an open coil on the wig wag assembly.
it is the part the has 2 coils on a metal bracket on top of the transmission. it moves back and forth when the unit is running.
does it drain but just not spin? if so then you could just have a broken wire to the wig wag or the coil could be bad. wires do break to the wig wag , but you usually hear the coils engaging then shutting off if the wires are bad. so check the coils and try to replace the wig wag second if you dont find a bad wire.
Jan 31, 2009 | Kenmore 22422 Top Load Washer
Would a new basket drive help?
not that unique, whats happening is the transmission has a wig wag and shift cam bars that are not moving at the right time. you probably have an open coil on the wig wag and its normal for them to do this when a coil fails. just take the 5/16 screw out of the wig wag and lift it off the plungers, then replace it with a new one. all should work correctly after that.
ok so now i have seen your ? 4 times and you dont need a basket drive either.
you might want to make sure you didnt unhook a wire from the wig wag when you changed the motor and it could also be the cam bars are just stuck, which ever, just look at the wig wag and bars. that will be your area to repair.
Jan 06, 2009 | Whirlpool GSC9455 Top Load Washer
Spinning basket while agitating
Jan 05, 2009 | Whirlpool GSC9455 Top Load Washer
Kenmore 70 series top load washer - no spin
the older belt drive washer has a cylanoid under it on the top trans missin called a wig wag eather broken wire to it are bad wig wag can still be found ck lid switch also
Mar 19, 2008 | Washing Machines
GPS Logo
163 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
