Question about Lands Phones
IN 120 base keeps flashing CL - Lands Phones
This is due to the base unit losing power and needs the clock resetting.
The handsets retain their clocks under battery power so this is a little misleading.
To reset the base unit clock:
- press the OK key
- press the 'down' arrow twice until "DATE/TIME" is displayed.
- press the OK key again, this will display the year. Enter the correct year on the handset numeric keypad and then press OK. (Only the last two digits of the year need to be entered).
- The date is then displayed in MM/YY format, enter the correct date on the handset numeric keypad and then press OK.
- The time is then displayed, enter rhe correct time on the handset numeric keypad and press OK.
- The handset then beeps and displays "SAVED".
- Press the "C" button and replace the handset on the base unit.
The base unit should now stop flashing "CL".
Posted on Jan 21, 2009
This indicates that you need to set the time and day on your answering system. During initial setup and any time there is a loss of power to the base, you will see this flashing indicator. Consult your User's Manual for instructions on setting the day and time.
Posted on Dec 04, 2008
Why does base station flash cl
Why does the base station keep blinking?
Dec 13, 2011 | Clarity D613C Cordless Phone
Need to reset phone after power outage. CL keeps flashing - alternately flashes with CL and 0
Here is the procedures on how to reset the phone:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances
Thank you for visiting FixYa! We answer your concerns promptly for FREE. Please spare a few seconds to click on YES button in return. Have a good one!
Jul 15, 2011 | Uniden Cordless Phone
My att digital keeps flashing "CL" what does it mean and how do I stop it?
Problem Why is CL ( or C ) flashing in the base message window?
Solution(s) This indicates that you need to set the time and day on your answering system. During initial setup and any time there is a loss of power to the base, you will see this flashing indicator. Consult your User's Manual for instructions on setting the day and time. Manuals for most models can found on this site. Go to our MANUALS section, then search for your particular model.
http://telephones.att.com/telephones_ui/support/dsp_faq_gen.cfm?faqid=233669
Dec 01, 2009 | Uniden Cordless phone EXS9950
Flashing CL?
A flashing CL means that you have to set the clock.
Nov 11, 2009 | Lands Phones
On my ge answering machine, the CL red light keeps flashing even though there is zero msg. so how do I clear this CL red light flashing
Your time needs set on your answering machine. If you have buttons on the top of your base, press and hold the day/check button to set the day of the week. Press and hold the hour button to set the hour. Press and hold the min button to set the min. If you don't have buttons on base, press flash button on handset to enter answerer remote mode. Press the 8 key to enter time set menu. Set hour and min using number buttons and set am/pm using caller id buttons. Press # pause to confirm the setting.
Nov 02, 2009 | Uniden Cordless Phone
CL keeps flashing in the base window and I don't know what to do to correct it
Your time needs set on your answering machine. If you have buttons on the top of your base, press and hold the day / check button to set the day of the week. Press and hold the hour button to set the hour. Press and hold the min button to set the min. If you don't have buttons on base, press flash button on handset to enter answerer remote mode. Press the 8 key to enter time set menu. Set hour and min using number buttons and set am/pm using caller id buttons. Press # pause to confirm the setting.
May 01, 2009 | GE 25942GE2 Cordless Phone System
CL flashing on base unit
I reset the day and time and then reset the phones by putting them in the base unit
Jan 09, 2009 | Uniden Cordless Phone
Cl and 0 flashing
Dec 28, 2008 | Uniden Cordless Phone
System keeps flashing with CL
Program the clock. There are a some buttons on the back of the base unit that sets day of the week, hour, and minute.
Dec 18, 2008 | General Electric 28031EE3 5.8 GHz 1-Line...
Need instructions to make cordless twin set work
If you had a power failure the memory may have been affected. Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You may need to register the handset to the base by following the instructions in the user's manual
Sep 12, 2008 | GE 25952 Cordless Phone
Lands Phones Logo
418 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
