AO SMITH HOT WATER HEATER PROBLEM Model: GCV 40 100 Serial #: B05A062383 Questions/Comments: originally problems with pilot light goes out every time the heater shuts itself off  after heating up...so i replaced the gas control valve and it still does the same thing...i guess now its the pilot assembly?...im pretty sure this heater is still under warranty....CONTACT ME PLEASE
Mack says check to see if you have a blockage between the discharging flue pipes and chimney stack.Maybe this unit accumulated rust/soot/or settlement restricting the full flow of carbon/air,ect. from the unit itself.
Posted on Sep 29, 2011
Same problem. Replaced the thermocoupler and the pilot light still goes out. I've done research and a lot of people are having the same issue with the brand/ model. Haven't been able to find a solution.
Posted on Feb 22, 2011
  • 472 Answers
Thats what it sounds like to me you have a bad thermocoupler...as far as being under warranty alot of the components usually have bear minumum warranty the tank itself will still be under warranty based on your info... the thermocoupler are inexpensive and fairly easy to change most home depot or lowes building centers carry these in the water heater department....good luck
Posted on Jan 03, 2011
Why would gas stop flowing to the water heater?
if thermocouple goes bad(pretty common) then pilot light goes out and gas stops flowing.
Aug 01, 2015 | A.O. Smith GCV-40 Promax Residential Water...
Water heater pilot turns on but burner won't light. 4 blink meaning high temp shutdown. What can I do?
We have a Model 2801052103 Franklin Electric submersible pump, 1/2HP 230 Volt. It starts and stops when using water frequently. System is 30+ years old, could the well be bad?
Jan 05, 2014 | AO Smith Plumbing
Rust in water, ao smith promax
It may be what is called iron bacteria it will sometime grow in a water heater. It is present in some water and will actually thrive in water temps up to 120 degrees.if this is the case one solution is to increase the water tempurature of the heater to 130 -140 degrees this will kill the bacteria that is causing the rust problem.You Must install a tempering or mixing valve which will add cold water to temper or cool the water back to 120.
hope this helps.
Dec 02, 2013 | A.O. Smith GCV-40 Promax Residential Water...
Does the pilot light always stay lit on this water
Many water heaters today are pilotless.
Call manufacturer with model and serial number
Gene.
Sep 04, 2013 | RTO W4 A.O Smith Gas Hot Water Heater...
GCV 40 100 Burner and pilot shuts off when heating up
Get more fresh air to the unit.
Clean the air intake/ flame trap/ flame arrestor located on bottom of tank.
http://waterheatertimer.org/images/Flame-trap-inspection-325.jpg
Post question on pro water heater forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add a comment with type of gas control valve, for possible troubleshoot.
Copy following link to read service manual by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Aug 17, 2012 | A.O. Smith GCV-40 Promax Residential Water...
AO Smith Water heater FPSH50-260 keeps blowing fuses
FPSH series is a power vented residential gas water heater.
1) The blower is plugged into 120Volt outlet. If blower has short, then it will trip breaker.
Blower could be Fasco model 7021-10195, or 7021-10770. Call AO Smith: 1-800-527-1953. They will need model number and serial number located on label on side of tank.
2) Before calling AO Smith, check outlet with circuit analyzer. Outlet must have correct polarity and must be grounded. Unplug cord to water heater and run continuity test from ground prong on electrical plug to manifold tube on gas valve.
3) Also if a fluorescent light fixture is on the same breaker, that can cause burner to short cycle.
4) Connect water heater to different outlet and see if problem continues.
5) AO SmIth has service manuals for the FPSH series that download to your computer:
http://www.hotwater.com/resources/product-literature/service-handbooks/
Sep 20, 2011 | Water Heaters
Just bought gcv 50 300 series. see lots of problems with gcv 50 100 pilot light not staying lit. my new water heater has different control on it. Did they fix their problems with this new controller?
You offer much opportunity for research and discussion.
This would be a good topic for the Tank forum as there are professional plumbers with specific and general expertise on different model numbers.
http://www.waterheaterrescue.com/TheTank.html
Fixya is not a forum since we parcel an answer, then move to next question.
Discussion is not common, and typically one person answers this question, and then that question is removed off the question board.
If you are wishing to diagnose pilot light yourself, assuming product is not defective, and you are not already professional in the field, then following links offer resource:
http://waterheatertimer.org/images/Negative-pressure.jpg
http://waterheatertimer.org/pdf/Gas-venting-specs.pdf
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 30, 2011 | RTO W4 A.O Smith Gas Hot Water Heater...
I have smoth's hot water tank. problem is pilot lite is off. how do u turn it on?
You have tank-type gas water heater with standing pilot light.
Instructions for lighting pilot light are usually on front of water heater.
Since water heaters vary widely, if you want specific information without guessing, then add a comment with model number that appears on label on side of tank, and also describe the gas control valve on front of unit.
This information will let expert located manual and look up specific information plus troubleshoot steps for that model.
Aug 24, 2011 | RTO W4 A.O Smith Gas Hot Water Heater...
Gvr 40 100 will not stay lite
The Cold air screen on the bottom of the water heater is partially plugged. That is if the pilot light can be lit and stay on, but goes out when the heater should be functioning normally. This is not the removable plastic screen but a round white-yellow grid with 1/32" holes. You can try to clean it through the bottom but you may have to remove the gas line from the controller to the burner, pilot gas line, and thermocouple connection to remove that complete assembly to get access to the screen. The AO Smith booklet warns of this but they pretend the plastic screen will keep this second screen clean but it won't. After three years it was two thirds plugged.
Dec 12, 2009 | RTO W4 A.O Smith Gas Hot Water Heater...
Heating & Cooling Logo
1,143 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
