Question about Acer Aspire X1300 (PV.SCC0X.002) PC Desktop
How do I put in a CD? Pushed eject button but nothing happens.
    Problem Solver:
  • 11 Answers
Hi. Windows can take over the CD drive in certain instances effectively locking you out. Try rebooting the computer and then press the eject button before Windows starts. If this doesn't work, there is most likely a hardware fault with the CD drive.
If the drive is faulty, you'll probably need to replace it. To rescue a stuck CD look for a small hole on the front of the drive and poke a straightened paper clip in the hole to release the tray manually, best this should only be a last resort.
Good luck. Cheers.
Posted on Jan 03, 2011
  • 97 Answers
It is possible that the drive is temporarily jammed. There should be a release switch, a small hole the size of a pin.use a paperclip to open. If it doesn't work after that, replace the drive.
I can't get the CD to eject.... in fact, I can't get the unit to acknowledge there is even a CD/mp3 option... IT just flips back and forth between tuner and aux. It was cold last night when I put a Cd in...
When you remove the faceplate you will find a small little black hole in the deck.Insert an opened paperclip to over ride the eject and make it come out.Please let me know if this helps
Jan 19, 2011 | Clarion CZ200 Car CD USB MP3 Player
CD-ROM not opening
The eject mechanism is driven by a seperate belt. You'r's is worn or broken, however, there is a small pinhole in the face of the player that you may stick a paperclip into and the tray will open.
Oct 09, 2009 | E-Machines emachines (emachinees) CD-ROM...
My cd/dvd drive is not working.
You could reinstall the CD/DVD drive software, but it sounds like the CD/DVD drive is faulty. You'll need to replace the drive.
Jun 12, 2009 | Averatec 1000 Notebook
Stuck cd discs
I think there are a couple of faults here. The first one is maybe a faulty motor on the eject mechanism. The second one is a faulty laser unit as it is not scanning the disc. Hope this helps.
Jul 25, 2008 | Sony RCD-W500C 5-Disc CD Recorder
CD won't eject....
you need cleaning and maintenance on your radio if you want to eject the disk theres a little tiny button on the face you will need a pin push it in and this should eject your disk
Sep 27, 2007 | Kenwood KDC-215S CD Player
Cd player problems
I installed a dual xdm7510 reciver in my car and it worked fine for a day but now it will not play anything. Sometimes it will play and sometimes it will just eject any cd that I put in it. write me at jefferysprouse@yahoo.com
Sep 07, 2007 | Alpine CDA-7995 CD Player
Jammed cd drive
  • Touch the eject button on the PLAYSTATION 3 system front for 10 seconds or longer to force the disc to eject. After removing and before reinserting a disc into the PLAYSTATION 3, turn off the system, and then turn on the system again to resume use.
  • If the disc cannot be inserted, you may need to send your system in for service, please click on the link below.
  • Aug 27, 2007 | Sony Playstation 3 (PS3) Console
    I receive error msg and cant eject magazine
    The magazine in our Sony CD player would not eject. I tried pressing two buttons at the same time etc., with no result. I uplugged the player, removed the screws that hold the black metal cover on and took off the cover (pull the metal up, out and away at the back bottom sides, then slide it back to release the lip from under the front pane.) Looked down inside and saw the problem, a CD disc extended about 1/2 inch from the magazine, blocking ejection. I pushed the extended edge of the disc back into the magazine with the tip of a kitchen knife. Plugged the player back in, pushed power and then the eject button, and the magazine ejected. Replaced the metal cover and it works fine. If it won't eject again I know what to do. Be sure to unplug before you work, you don't need an electrical shock.
    All the best, Sonia Murray
    Nov 28, 2006 | Panasonic CX-DP801 8-Disc CD Changer
    5 cd changer locked on cd and stays ejected
    . Nope no loose springs.. Its a problem that happens alot of times when you dont follow the manufacturers instructions. What happens is when you pushed on the tray assembly, you pushed the nylon cam gear out of mechanical timing. Unless you get the mecanical manual for this player, you most likly will not be able to adjust this yourself. probably a shop would charge you more then it is worth. Sorry. Good Luck.
    Aug 12, 2006 | Panasonic SC-AK29 CD Shelf System
    Acer Aspire X1300 (PV.SCC0X.002) PC Desktop Logo
    78 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Steve Sweetleaf
    Steve Sweetleaf
