Question about Mattel New Mattel Barbie Townhouse
The light in the kitchen doesn't come on. If you hold it sideways, it comes on. The fireplace doesn't come on and there is no crackling sound. Everything else works.
Only problem I shared with you is the chandelier... the door, upon opening, turns the chandelier on... you'll see the switch in the hinge area of the door
Posted on Jan 03, 2011
Gas fireplace won't light
Your fireplace does have a pilot. It is either millivolt, where you manually light the pilot and use a remote or wall switch to light the logs
or is IPI where it still has a pilot light but the reote or wall switch lights the pilot first then the logs. The second version has a non-standing pilot. In either case, it sounds like a pilot assembly issue. When you "throw the switch", do you hear clicking inside the fireplace? If so and it does not light, you may have a pilot assembly issue. If there is no sound at all, then you may have a bigger issue with the control module. The only sure way to know which is the culprit is to have a certified technician come oput and examine your fireplace.
Feb 02, 2014 | White Mountain Hearth Empire Tahoe 36...
Tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 | Heating & Cooling
Vermont casting fireplace vcef33
You could take a table lamp or a drop light a electric drill or anything similar,and see if you can unplug the insert and plug one of these items in and see if the plug works
I am taking for granted that you can get to the plug without having to pull the insert out or at least not all the way out
If you can't do that
Turn the breaker off to that circuit pull the switch out and make sure nothing is touching
Hook a tester to the wires and then turn the breaker on and see
If you have power to that switch turn the switch off and on watch the meter and see if it does turn on and off
If you have power coming out of the switch.
and you can't reach the plug then you only option would be to pull the insert
As for a fuse there may be one but not look like what you are thinking a fuse will look like it is usually a temperature fuse that is shaped similar to a diode the symbol for it can be two ways
it could have what looks like a c laying on its side upright and also another c beside it on its side aiming down like a snake crawling. The other symbol looks like a rocket with no fins on its side with a with a what looks like a T laid sideways coming off one end
Oct 20, 2013 | Heating & Cooling
WHEN I USED MICROWAVE HAD BURNING SMELL & BLACK SOOT APPEARED. STILL HAVE POWER BUT DOESN'T COOK
Just had the same problem. It was an electrical short and the repairman said that it could have burned the kitchen wall and been a catastrophy. Get rid of it immediately!
Mar 02, 2013 | Microwave Ovens
Barbie Pink 3-story Dream Townhouse fireplace doesn't work and the chandeler light doesn't come on
For the fireplace, if you press the back wall the fireplace backs to, and the button at the same time, it lights up and crackles.
Dec 26, 2010 | Mattel Barbie 3-story Dream Townhouse...
I cannot get the fireplace to light up or make crackling sounds on the Barbie Dream Townhouse.
The fireplace most likely came loose in shipping. If you can get your fingertips behind the fireplace and pull if forward a bit.... then it is loose. The is a bar/clasp behing the fireplace the top needs to rest/attach to.... lift up and push back on the fireplace until it 'clicks'. (you will feel it when it sets in properly) One attached correctly to the wall... when you push button to make the TV go up - the fireplace also lights up and makes sounds.
Dec 24, 2010 | Mattel Barbie 3-story Dream Townhouse...
Crackling Sound
Not sure what model but there is a coil on some LG LCDs that needs to be replaced on the SMPS.
Jul 01, 2008 | LG 42LB5D 42 in. LCD Television
Makes annoying crackling noises from intrument panel
Sounds like a chatterig relay on the relay board. Only thing you can do is replace the board
Jun 11, 2008 | LG LRE30755ST Kitchen Range
Crackling Sound
I just bought a used 60 inch rear projection tv. The picture is fine except I have a crackling sound coming from the front of the tv also. What's the deal?
Jan 16, 2008 | LG RU-44SZ51D 44" Rear Projection...
Mattel New Mattel Barbie Townhouse Logo
563 people viewed this question
Top Mattel Toys Experts
thegtw
Tracy E
Level 1 Expert
Tom Chichester
Are you a Mattel Toy Expert? Answer questions, earn points and help others
